Race Capture Pro Mk2 data system with Bluetooth module
Total Cats: 116
Selling my used RaceCapture Pro MK2 data logging system by Autosport Labs
This is in my opinion the best bang for the buck data logging option available.
You can easily set it up to read the CAN data from your Megasquirt and sync it with additional sensors.
It does predictive lap timing and custom warnings and works with any android device.
Bluetooth module, GPS antenna included.
There is an optional telemetry module you can add to this also (not included)
https://wiki.autosportlabs.com/index...K2&redirect=no
https://www.autosportlabs.com/wp-con...ence-sheet.pdf
I paid $500 new.
Asking $350 shipped.
RaceCapture/Pro MK2 Specifications
Input / Output ChannelsAnalog InputsChannels8 (battery voltage dedicated on channel 8)Voltage range0-5vInput impedance1M ohmVoltage protection400v (intermittent)ADC precision12 bitMaximum sample rate1000HzMappingRaw / Linear formula / Interpolated mapDigital I/OChannels3Output mode typeOpen drainOutput current capacity1A, inductive clampedInput mode voltage range0-12vInput voltage protection400v (intermittent)Maximum sample rate1000HzTimer Inputs (RPM / Frequency)Channels3Input voltage protection400v (intermittent)Maximum sample rate1000HzPWM/Analog outputsChannels4PWM output typepush/pullPWM output voltage range5vOutput current capacity50mAAnalog Output0-5vVoltage ReferenceOutput Voltage/Capacity5v / 1AConnectivityCAN BusCAN Channels2CAN baud rate125K, 250K, 500K, 1M baudCAN Termination120 ohms terminated, both channelsCAN filters14 per channelProtocol supportOBDII PID (CAN 1), custom CAN messagingTelemetry/WirelessCellular (North America)3.5G GSM 850/1900MHz (internal module, optional)Cellular (Worldwide)2.5G Quad-band GSM (internal module, optional)BluetoothBluetooth 2.0 (external module, optional)Aux SerialType External RJ11 / RS232 signalingMax Baud Rate230400Inertial Motion UnitAccelerometer Channels3 (X/Y/Z) (2G, 4G capable)Gyro3 (Yaw/Pitch/Roll) (1000 degrees/sec)GPS TypeExternal active antennaGPS Maximum sample rate50HzGPS accuracy2.5M CEPStorageMicro SDUp to 32GB (SDHC) FAT32Configuration CapacityAuto-detect track database240Sectors per track20Channel support200PhysicalDimensions5.3" (width) x 4.2" (height) x 1.2" (tall) / 135x110x31 mm(est)Mounting area5.5"(140mm) x 4"(102mm)Mounting holesDual mounting points on 5" (127mm) centers - 0.125"-0.25" (3-6mm) fastenerWeight9oz / 255gm (est)Power connectionTerminal block: 1A maxRJ45: 1A maxPower Consumption (max)Main System: 0.6W
With Bluetooth: 1.6W
With Cellular Telemetry: 8.6W
With Cellular Telemetry and Bluetooth: 9.6WTemperatureMax Internal Temperature while operating: -40°C ~ 85°C / -40°C ~ 80°C (Telemetry module)
cyotani
04-27-2017 10:43 AM
