523whp boosted K20 swap NB2 project
Old 09-08-2017, 11:58 PM
  #121
Total Cats: 560
Originally Posted by aidandj
It's embarrassing that I can't tell if you are being sarcastic...
Yep
sonofthehill is offline
Old 09-10-2017, 06:40 PM
  #122
HHammerly's Avatar
Total Cats: 63
thinking of a K turbo, interested to see how this one comes
out
HHammerly is offline
Old 09-11-2017, 11:13 AM
  #123
KMiata's Avatar
Total Cats: 322
Brand new Type R valve cover was a requirement, especially paired with the white car and the red Elise seats. I'd really like to bring this thing to MRLS, it will be running this week and it's pretty. But the logistics of getting three cars from Chicago to CA is the main hurdle.
KPower Industries
info@kpower.industries
KMiata is offline
Old 09-11-2017, 11:27 AM
  #124
oh myyyyyyy please bring it
Old 09-11-2017, 01:09 PM
  #125
Joseph Conley's Avatar
I volunteer to drive it from Chicago to CA.
Joseph Conley is offline
Old 04-11-2018, 01:30 PM
  #126
KMiata's Avatar
Total Cats: 322
It's been too long without updates on this car!
While we haven't been doing turbo things with it yet, we've used it for a couple other big projects. We completed A/C kit development on this car over the winter. We have a 100% bolt-in A/C solution ready to hit the market. The production A/C lines are done and on the way to our warehouse now, and you'll be seeing this all for sale on the website really soon.
We also used this car to complete our E46 6-speed transmission package, which is also ready to go on sale this month.
Current state of the car:
To recap, the drivetrain is a K20Z1, paried with an E46 6-speed, ACT HD organic clutch, our new 6-speed flywheel (12.5 lbs) and a Getrag stage 2 rear end kit with a 3.42 (may switch to a 3.23 eventually). With 23" tall tires, the gearing is identical to an E46 M3, which will be perfect for a street car:
https://kmiata.com/pages/gearing-cal...%2C1%2C0.85%5D
The next picture you see of this engine bay will have the GTX3076R bolted up. We just had a customer make 450whp on a stock k24a2 with this turbo at 13 psi. We went with the k20z1 instead since it's more ideal for boost in stock form. We'll run 20 psi or so on e85, so it should be scary fun.
The turbo, manifold, and downpipe are getting bolted up this week and we're fabbing the 3" exhaust this weekend. No more side projects, it's time to get this thing boosted and have fun.
Any recommendations for an intercooler that will fit this car and support 600whp? This is uncharted territory for us, so I want all the good advice I can get.
KPower Industries
KMiata is offline
Old 04-11-2018, 01:36 PM
  #127
Precision 600. Fits up against the rad (might be tight with AC though....)
Old 04-11-2018, 01:41 PM
  #128
KMiata's Avatar
Total Cats: 322
Nice. A/C isn't going back in so we could make this work.
KPower Industries
KMiata is offline
Old 04-11-2018, 01:45 PM
  #129
Pictures are in an NA, so it might be slightly different, but it fit really well for me, minimal brackets required.
Old 04-11-2018, 01:53 PM
  #130
Chiburbian's Avatar
Total Cats: 203
I thought it was a bad idea to stack heat exchangers like that?
Chiburbian is offline
Old 04-11-2018, 01:56 PM
  #131
Sure, but I didn't want to build a v-mount.
Old 04-11-2018, 02:18 PM
  #132
RalliartRsX's Avatar
Total Cats: 22
Maybe I missed this (and please do slap me if it was already covered)
NB Miata - Speed sensor pickup is in the gearbox
E46 6 Speed - Speed sensor pickup is done through the ABS sensors
How is the interface of VSS being done for a K Miata with a E46 6 speed?? It seems most Standalones can use either ABS/tone rings and convert that signal. However, how is it being accomplished in this case??
RalliartRsX is offline
Old 04-11-2018, 02:29 PM
  #133
KMiata's Avatar
Total Cats: 322
We are also picking up a wheel speed signal from a single ABS knuckle, ring, and wheel speed sensor paired with a Dakota digital converter box to make it all work. So it's easy for NBs, but we're working on a custom setup for NAs.
KPower Industries
KMiata is offline
Old 06-19-2018, 01:36 PM
  #134
KMiata's Avatar
Total Cats: 322
Just ordered a Precision 600 intercooler and piping. I plan on finishing up the shopping spree this week so we can get this car up and running ASAP. I'd like to have it done in a month.
KPower Industries
KMiata is offline
Old 06-28-2018, 02:16 PM
  #135
KMiata's Avatar
Total Cats: 322
Big progress update this week. All fabrication is complete. Manifold, downpipe, dump tube, wastegate, 3" exhaust, intercooler mounts, piping, and BOV are all in place and ready to go. We basically just need to install lines and get it tuned.
For those interested, here's our current turbo setup:
-Garrett GTX 3076R
-Precision 600hp intercooler
-2.5" hot side piping, 2.75" cold side
-Turbosmart 45mm wastegate
-Turbosmart BOV
-FIC 1650cc injectors
-Walbro 450lph pump
-Fuelab regulator and inline filter
-Hondata 4 bar MAP sensor
-Xenocron 4 port PWM boost solenoid kit
-Hondata Kpro4
Shooting for around 600whp (e85) on our 100% stock block k20z1 (05-06 RSX Type S engine). E46 ACT HD organic street clutch, ZF 6-speed trans, and Getrag stage 2 diff kit should hold up quite well at that power level.
We'll be adding a better radiator and an oil cooler once we get it tuned and put some street miles on it. While it's mainly designed to be a street car, we'd like to be able to take it on track here and there too. We definitely will be adding some heat shields too.
I'm really pleased with the way all of the intercooler piping came out, as well as the fit of the Precision 600 intercooler. Everything is nice and tidy in the engine bay:
I'll have another big update in a couple weeks.
KPower Industries
KMiata is offline
Leave a poscat 13 Leave a negcat
Old 06-28-2018, 02:17 PM
  #136
I
AM
SO
EXCITED
Old 07-02-2018, 05:59 AM
  #137
Zaphod's Avatar
Zaphod is offline
Old 07-02-2018, 10:43 AM
  #138
andyfloyd's Avatar
Total Cats: 97
Looks amazing, I LOVE this
andyfloyd is offline
Old 07-05-2018, 10:06 AM
  #139
Padlock's Avatar
Total Cats: 599
meh.. its alright I guess..
Padlock is offline
Old 07-19-2018, 02:20 PM
  #140
KMiata's Avatar
Total Cats: 322
IT'S ALIVE. We fired it up last night. Dyno tune next week. Still have to wire up a couple new gauges and add a catch can, but it runs. The amount of AN lines and fittings on this car is out of hand.
The plan is to take it to AMP on 8/2 and Miatas at the Gap the following two days. Mainly for some street driving and to show it off at the booth. We still want a better radiator and hood louvers before we do much on track with it.
KPower Industries
KMiata is offline
Quick Reply: 523whp boosted K20 swap NB2 project
