Old 06-28-2018, 01:00 AM
  #10701
Unless it snaps
My grandpa passed earlier this week so I've been dealing with all that but I took the whole week off and might try and get the car running by the end of the weekend. I miss this car a lot lol
Old 06-28-2018, 06:20 AM
  #10702
Total Cats: 859
My condolences. Perhaps working on the car can give some emotional diversion.
DNMakinson is offline
Old 06-28-2018, 07:08 AM
  #10703
Total Cats: 3,075
Sorry for your loss, Aidan.
sixshooter is offline
Old 07-01-2018, 05:48 PM
  #10704
Thanks guys.
Got some things done.
Should be running next weekend. Pretty excited.
Old 07-01-2018, 07:01 PM
  #10705
​​​​​​Gettin somewhere...
Old 07-01-2018, 11:27 PM
  #10706
Total Cats: 1,184
Hey we’re msm twins. Vvt coils ftw. Wish mine didn’t leak. Pretty sure it’s warped
curly is offline
Old 07-01-2018, 11:37 PM
  #10707
I'm gonna have the LS coils still.
Old 07-15-2018, 06:44 PM
  #10708
Old 07-15-2018, 07:18 PM
  #10709
Scaxx's Avatar
Total Cats: 884
WOOOOOOOOO
Scaxx is offline
Old 07-15-2018, 11:50 PM
  #10710
icantlearn's Avatar
Total Cats: 117
noice
icantlearn is offline
Old 07-16-2018, 12:29 AM
  #10711
Got it halfway buttoned up. It's hot here, and I fucked my ankle up so things go slowly.
Got the coolant burped and exhaust installed. Need to do a bolt check and get it back on the ground before a test drive.
Hopefully track day on the 2nd.
Old 07-18-2018, 08:21 AM
  #10712
psyber_0ptix's Avatar
Excellent
psyber_0ptix is offline
Old 07-22-2018, 01:14 AM
  #10713
Car drove today. Smokes when you get on the gas after engine braking....so I just shift into neutral.
Probably tired rings but I don't care at this point. It's nice to have a running car again.
Old 07-24-2018, 11:19 AM
  #10714
T00ning question.
Old setup was 8.6 weisco pistons, new setup is 99-00 stock pistons. (so 9.5:1?)
How much timing should I pull as a base map. I was thinking 5* in boost. 3* out of boost?
Old 07-24-2018, 11:25 AM
  #10715
ryansmoneypit's Avatar
Total Cats: 456
I dont think I would change anything under 100 kpa.
ryansmoneypit is offline
Old 07-24-2018, 11:26 AM
  #10716
Should have clarified. I meant pulling timing in boost.
I'm going to knock a few degrees out under 100kpa, but mostly i care about 0-5psi.
Old 07-24-2018, 12:10 PM
  #10717
Pulled some timing in the midrange, trying to keep torque low on stock rods.
150kpa will make 200ft/lbs, so I'm staying below that for track duty.
Old 07-24-2018, 01:25 PM
  #10718
icantlearn's Avatar
Total Cats: 117
Here is my "meh" timing map. Seems to be working alright...
Old 07-24-2018, 01:28 PM
  #10719
Why does it go up and down as boost increases?
Old 07-24-2018, 02:02 PM
  #10720
Because he has yet to comprehend smoothing and interpolation
