Supermiata S1 build - Vegas
Old 06-01-2018, 07:43 PM
  #201
ninerwfo's Avatar
Total Cats: 17
Hey Emilio, any pics of where the trans and diff cooler lines actually enter/exit the trans and diff? What arrangement of parts did you use to do that, and how were they tapped in?
Thanks heaps.
ninerwfo is offline
Old 06-01-2018, 08:09 PM
  #202
Total Cats: 2,387
Trans/diff coolers not installed yet.
.31 SNR
emilio700 is offline
Old 06-01-2018, 10:22 PM
  #203
Satisaii's Avatar
Total Cats: 112
We purchased, but have yet to test / install, -8 AN adapters that replace the drain / fill plugs. We still will need to figure out where to put the temperature sensors. We have fans and are planning on using the Megasquirt to control them.
Satisaii is offline
Old 06-05-2018, 12:28 AM
  #204
ninerwfo's Avatar
Total Cats: 17
awesome - hanging out to see the pics of how you do it.
ninerwfo is offline
Old 06-18-2018, 03:06 PM
  #205
Total Cats: 2,387
Default Trans & diff coolers
.31 SNR
Old 06-19-2018, 06:54 AM
  #206
ninerwfo's Avatar
Total Cats: 17
Love this forum. To go from "hey it would be nice to see a couple of pics" to this full-blown video explanation is just awesome. Thanks Emilio, very grateful.
ninerwfo is offline
Old 06-20-2018, 08:21 PM
  #207
Der_Idiot's Avatar
Total Cats: 28
Great looking setup guys, thanks for taking the time to make the video. A question when you guys get a sec - The 6spd can be filled from the shifter up top and I imagine the fluid can be forced back that way as well, have you had to work out a way to keep the fluid level under control so it doesn't come out the top?
Der_Idiot is offline
Old 06-20-2018, 09:28 PM
  #208
Satisaii's Avatar
Total Cats: 112
I am thinking that we won't have to overfill it by more than 1/2 quart to accommodate the volume of fluid that will fill the lines (not including the cooler, which I don't think will drain back). Given that, I am not too worried about fluid coming out of the top of it. I will have the pump running during the fill and will check the level as I go to make sure that I don't add way too much. The pumps will run whenever the car is running.
The differential I am not as sure about.
Satisaii is offline
Old 06-20-2018, 11:39 PM
  #209
Total Cats: 1,181
I just installed a e46 differ cooler, nearly identical to your setup except with a Tilton pump. Their instructions suggest a pre-filter (forget the micron #), and running the cooler pre-pump, to keep the hot fluid out of the pump for longevity. Food for thought. Great looking setup otherwise.
for filling, put the return line (should be attached to the diff fill hole) on the drain hole, and put the feed line in a bottle of preferred fluid, turn on the pump until it comes out the diff fill hole. Now your pump, cooler, lines, and diff are full. Plug the drain with your finger and quickly swap lines. I loose only a few drops doing it this way, and purposefully plumb the lines with enough length for the swap.
curly is offline
Old 06-27-2018, 06:15 PM
  #210
Total Cats: 2,387
This is not John's happy place. Single most time consuming part of the build is the wiring. As mentioned before, it's 100% from stock, no OEM components. All new connectors. Custom built with an eye towards possible enduro use later on. So
ABS, cool suit, radios, external LED marker lights, light under hood and interior, big LED headlights, sensors on everything, big fuel pump, twin high amp fluid pumps in trunk, twin fans in trunk. I'm probably forgetting something but basically as future-proofed as we can make it.
Shock tower reinforcement bar ended up too close to DP so we had to put a dimple in it. That will allow room for a heatshield. That brake line loop is really close to the DP so we want max insulation there.
Did a Blackstone report on the motor post UTCC and saw lots of lead and copper. Doh. Motor coming out for new bearings. We'll see if we can make adjustments to the build or maybe bump viscosity to improve bearing life.
As it stands, it's about a 25hr motor at 400whp/7800rpm. I think we can do better. Didn't burn oil and compression is great though.
Valve cover and square top PC'd orange. Many bling.
.31 SNR
Old 06-27-2018, 06:27 PM
  #211
flier129's Avatar
Total Cats: 319
flier129 is offline
Old 06-27-2018, 06:29 PM
  #212
mx5-kiwi's Avatar
Total Cats: 57
Hi Emilio
Was this motor previously in an Aero car (i have lost track sorry) and if so was it running an accusump or dry sump?
mx5-kiwi is offline
Old 06-27-2018, 06:43 PM
  #213
Total Cats: 2,387
Originally Posted by mx5-kiwi
Hi Emilio
No and no. No low pressure warning lights at any time though I think we didn't log OP.
.31 SNR
Old 08-20-2018, 05:05 PM
  #214
doward's Avatar
Total Cats: 762
Vegas’ engine was removed and used in Bullet for UTCC at VIR. That engine is now back in its rightful home and Vegas is starting to look like a racecar again.
Also, here is a shot of the trans tunnel heat shielding.
doward is offline
Old 09-07-2018, 10:11 PM
  #215
Total Cats: 2,387
.31 SNR
Old 09-07-2018, 10:16 PM
  #216
Stock's Avatar
Total Cats: 128
Details on the "sealant" on he edges of the heat shielding?
Stock is offline
Old 09-07-2018, 10:20 PM
  #217
Phat
Old 09-08-2018, 01:13 AM
  #218
Mobius's Avatar
Total Cats: 365
So very nice.
Mobius is offline
Old 09-08-2018, 02:10 AM
  #219
Total Cats: 2,387
Automotive seam sealer, brush on. Google.
.31 SNR
Old 09-08-2018, 06:57 AM
  #220
thumpetto007's Avatar
Total Cats: -117
Nice legs.
Dense and vascular.
thumpetto007 is offline
Quick Reply: Supermiata S1 build - Vegas
