cop conversion, no spark from ms?
Old 06-25-2018, 04:50 PM
Leepi Leep's Avatar
ive been away at work...any way off next couple days determined to solve this.
looked over all the previous posts i read....
i may have found the issue in the cop wiring... these 2 dont match in the Upgrading to coil on plug thread (both are supposed to be 1.6 wiring)... which am i supposed to be wired as? i followed the first, but after rereading the post, most of the connections are wrong?
testing via multimeter now..
Leepi Leep is offline
Old 06-25-2018, 05:02 PM
wackbards's Avatar
Total Cats: 266
wackbards is offline
Old 06-25-2018, 05:09 PM
wackbards's Avatar
Total Cats: 266
This assumes wasted spark config. If you want to do sequential spark, you'll have to add a couple signal wires from the ECU too.
Old 06-25-2018, 05:11 PM
Leepi Leep's Avatar
Originally Posted by wackbards
thanks where did you get this ? just want to understand what im doing before i go moving wires again..
Old 06-25-2018, 05:16 PM
Leepi Leep's Avatar
thinking this wont work.... pin 3 is providing the +12 to the coils...
Old 06-25-2018, 05:20 PM
wackbards's Avatar
Total Cats: 266
The info is from the "definitive 1.6 to VVT swap" sticky. The 1st mega post has the incorrect pic you posted, but the text below has been corrected. I built this version of the picture for my own use, and it's been in my build thread for a while. I kind of think that the sticky would confuse people if the picture was updated, because there are references to the original pic being wrong throughout the whole thread. The attached pic is correct for deleting your igniter on a 1.6 for COP. It will maintain wasted spark config (which is not a huge deal), and should supply tach signal to your gauge cluster. I got uppity, and decided to wire for sequential spark. If you wanted to wire for sequential spark, this wiring remains the same, but you'll have to add a couple wires from the ECU to support 2 additional coil drivers (which your ECU might not even have).
Old 06-25-2018, 05:23 PM
wackbards's Avatar
Total Cats: 266
here's the thread:
https://www.miataturbo.net/engine-pe...athread-80469/
Old 06-25-2018, 05:40 PM
Leepi Leep's Avatar
im not worried about sequential at the moment, just want to get the ms controlling the engine.
so this mod is just extending the connection for the spark outputs to the original coil connector on the 1.6 chassis, instead of the ignitor.. and by not using pin 3 and 6 the +12v and ground are coming from somewhere else?
trying now...
Old 06-25-2018, 05:45 PM
Total Cats: 4,126
where did you come up with this mess?!
you literally x'd out the two most important wires.
Braineack is offline
Old 06-25-2018, 05:47 PM
Total Cats: 4,126
what doesn't match up? what is your actual issue?
Old 06-25-2018, 05:55 PM
Leepi Leep's Avatar
i was confused about the white to cyl 2+3 and red 1+4 wire, but realize now go to old coil pack which arent used.
just tested the mod he provided, it just loops those wires back to the original coil connector instead of the ignitor wires
my issue is im not getting spark to any coil with the megasquirt. i have continuity from pins 31 and 36 to the correct pairs of coils..
wackbards's Avatar
Total Cats: 266
I got it straight from the VVT swap sticky:
"Route 1 (white) to 2 (brown/yellow) (trigger for cyl 1/4, the text in the pic above is wrong, see post #156)
Route 7 (brown) to 8 (red) (trigger for cyl 2/3, text in pic above is wrong, see post #156)
Route 4 (yellow/blue) to 5 (black/white) (connects ECU directly to tachometer at gauge cluster)
Terminate 3 (blue) (unused +12v)
Terminate 6 (black) (unused ground)"
I'm running GM coils sequentially, so maybe we're not talking the same things??? IDK. Here's a pic I took of the deleted igniter.
Old 06-26-2018, 08:23 AM
Total Cats: 4,126
maybe that's why so many people are having issues with the simplest engine swap in human history?
Old 06-26-2018, 03:23 PM
leboeuf's Avatar
Total Cats: 54
It would be like baking bread and having no idea what the yeast or flour was actually for; you would just know that if you follow the recipe, magic happens and bread comes out.
To point out directly: Your coils are obviously being powered in some other way.
leboeuf is offline
Old 06-27-2018, 01:08 PM
Leepi Leep's Avatar
that blue wire, which he cut at the ignitor, still has power at the original coil pack connector. there is nothing "wrong" with this method it just uses the 2 signals and power from the coil pack connector instead of ignitor.
my car now doesnt start even with stock ecu, no changes made... im thinking its a bad cas at the moment.. itll fire and stumble out. wondering if this cas was going bad, and causing my no spark issue on the ms... will resolve soon enough
Old 06-27-2018, 01:12 PM
Total Cats: 4,126
okay, that makes more sense.
SpeedBump
14
09-13-2014 02:39 PM
Mr.Pibb
4
06-13-2013 07:51 PM
91_miata
4
03-26-2013 10:52 AM
N3v
07-27-2008 09:53 PM
cardriverx
04-24-2008 11:15 PM
Quick Reply: cop conversion, no spark from ms?
