Old 05-21-2018, 09:11 PM
  #1221
Total Cats: 560
Tom, if you want to build a multi rotor, I will let you pick through all my housings and end plates. I don't have any solutions for an eccentric shaft though.
sonofthehill is offline
Old 05-24-2018, 12:16 PM
  #1222
Total Cats: 560
Haven't opened the downpipe yet, but a ton of radial play on the compressor wheel. Can't really complain, I think the turbo states 20 or 25 psi working pressure. Not to mention how many 1/4 mile passes it has endured, going on the 3rd season. Can't decide if I should try a different one or just order the same unit.
Old 05-24-2018, 01:03 PM
  #1223
Go bigger
Old 05-24-2018, 01:28 PM
  #1224
icantlearn's Avatar
Total Cats: 117
Bigger
icantlearn is offline
Old 05-24-2018, 02:24 PM
  #1225
thumpetto007's Avatar
Total Cats: -117
Efr 7168 or whatever it is. Same et but spin your all seasons the whole track
thumpetto007 is offline
Old 05-24-2018, 10:34 PM
  #1226
Total Cats: 560
Sounds like a good plan, definitely not what she said though.
$188, shipping and tax included, hopefully the spool doesn't suck too bad, and it clears my hood.
Old 05-24-2018, 10:45 PM
  #1227
icantlearn's Avatar
Total Cats: 117
so cheap....much win
Old 05-24-2018, 11:49 PM
  #1228
Blayton's Avatar
Oooh moar boost. I'm interested in the specs/size of the one you ordered. Was it the one with the .63 A/R turbine?
Blayton is offline
Old 05-25-2018, 07:56 AM
  #1229
m2cupcar's Avatar
Total Cats: 372
Link? I want to see the ad for listed specs- and what you actually get. Mine was as-advertised- essentially equal to a 50trim T4 compressor in a 50AR housing and Stage III turbine wheel in a 63AR housing.
m2cupcar is offline
Old 05-25-2018, 11:55 PM
  #1230
Total Cats: 560
I am hesitant to post a link, not actually having seen (ran) the turbo. I hopefully got a similar unit with a slightly larger .63 a/r turbine side. I would hate to think someone clicked on my link before I see the thing and a bunch of us order the wrong thing.
When it arrives, I will post pictures and the link, explaining what I looked for and if the ad was accurate or why it was not.
Old 05-26-2018, 06:18 PM
  #1231
m2cupcar's Avatar
Total Cats: 372
I get that- the first one I bought was not as advertised. It had a t3 compressor instead of a t4.
m2cupcar is offline
Old 05-31-2018, 06:12 PM
  #1232
Total Cats: 560
Here is what I looked for in the listing.
First, the crappy, almost non-existent lip on the compressor outlet.
Next, the very minor lip, on the compressor inlet.
Also, this was advertised as a cxracing brand. The description was inaccurate on the point of the compressor wheel size, claimed 3", actually 2.75, but it looked the same as mine. As far as I can tell, the only difference is the turbine housing itself, if I am not happy, I will swap out for my .48 a/r housing. The exact same turbine wheel, which was accurate in the description.
​​​​​​https://m.ebay.com/itm/CXRacing-Univ...IAAOxyUrZSzmw9
Old 05-31-2018, 08:41 PM
  #1233
icantlearn's Avatar
Total Cats: 117
you can weld beads on the ends to make a lip
Old 05-31-2018, 10:44 PM
  #1234
Total Cats: 560
It fits fine, we'll see if it performs next week.
Old 06-02-2018, 02:43 PM
  #1235
Total Cats: 560
Drove it yesterday, the spool doesn't seem too bad, seems fast (but it always does after a week of driving the work truck.) The exhaust rattled like a freaking jackhammer though. Fortunately my MKTURBO v bands allow all kinds of movement, had to loosen all 3 of them to get it right. Now the fit is nice, even with the .63 housing.
Old 06-02-2018, 09:48 PM
  #1236
Total Cats: 560
Ok, so I still get the occasional knock on the driver's side of the transmission tunnel, but only under a hard launch. It's not going any further towards the tranny, I can live with it.
I definitely gave up a little spool, need to get a flat 4th gear pull somewhere/how.
Old 06-03-2018, 08:01 AM
  #1237
ysleem's Avatar
Total Cats: 7
I took a hammer to the frame bahaha. I have to shift my dp around because thats whats hitting.
ysleem is offline
Old 06-04-2018, 07:06 PM
  #1238
icantlearn's Avatar
Total Cats: 117
Just send it.
Old 06-07-2018, 12:43 AM
  #1239
Total Cats: 560
Traffic was so bad today, I only got 4 passes and didn't want to waste one on a spool log. Soon. It's definitely faster now.
Old 06-07-2018, 11:01 AM
  #1240
m2cupcar's Avatar
Total Cats: 372
Ok, so I still get the occasional knock...
I might know why you have exhaust knock. Your new turbo has different geometry than your prior. I mentioned this in the MK thread- the .48AR and .63AR turbos have a different angle on the neck from the turbine inlet flange that moves the outlet over away from the head.
Your turbines new (left) and old/prior:
Which supports what I found after buying both eBay turbos with .63AR (left) and .48AR turbines:
As you said, the v-band adjustability allowed you to adjust for the fit. Did you happen to pull housings and measure wheel inducer/exducer on the new turbine/compressor?
m2cupcar is offline
