First drive on MS3 Knock is bad
Old 05-28-2018, 08:44 PM
shotgreen's Avatar
Post First drive on MS3 Knock is bad
Hello all,
I just took my Miata on its first drive with MS3 running. The drive was going good until I gave it a little gas. Under light acceleration you can easily hear the car knocking bad from inside. I tried pulling a bunch of timing but it didn't seem to help much. I've already verified the timing with a timing light. It was dead on through out the rpm range. My afr's are on the rich side right now so that shouldn't be the problem. The car is stock accept for an AEM X series WB. I got my base maps from the MS extra website. Not sure if i should pull more timing or what?
Thanks
Attached Thumbnails First drive on MS3  Knock is bad-spark.png   First drive on MS3  Knock is bad-afr.png
shotgreen is offline
Old 05-28-2018, 10:05 PM
nitrodann's Avatar
Here, Your timing is far far too aggressive at lower rpm and higher loads.
Highlight the entire blue area and click the button also highlighted in blue. This will smooth the timing from 19* at the bottom left up to the higher rpm/load area. This will be a good start. If it still knocks in that blue area remove a little more timing especially around the top left of the blue area.
Dann
nitrodann is offline
Old 05-29-2018, 12:04 AM
shotgreen's Avatar
Thanks dann,
Just highlighting and interpolating the blue area significantly reduced knock. I though base maps were on the safe side but I guess not. I don't currently have any knock detection but I will be making a special headphone amp that can connect to the factory knock sensor. Then I should be able to easily hear if the knock is completely gone hopefully.
Old 05-29-2018, 12:47 AM
nitrodann's Avatar
The ecu has a knock headphone jack built into it.
Just plug in headphones and tune.
Dann
Old 05-29-2018, 01:04 AM
shotgreen's Avatar
Are you sure MS3 has a knock headphone jack? I'm positive mine didn't have anything like this although it would be a nice feature. Maybe your thinking of a different ECU?
Old 05-29-2018, 01:26 AM
nitrodann's Avatar
Here it is on MS2, maybe MS3 omits this due to cost. I assumed it had it also.
Old 05-29-2018, 01:49 AM
shotgreen's Avatar
Must only be a ms2 thing. I have the diy ms3 and it doesn't have it.
Old 05-29-2018, 03:54 AM
Reverant's Avatar
Total Cats: 361
That timing map is HORRIBLE. Didn't that ECU come with a basemap?
Reverant is offline
Old 05-29-2018, 10:12 AM
Wherever he got that map, it looks like it was created by a random number generator.
Old 05-29-2018, 06:52 PM
shotgreen's Avatar
I bought the DIY version of MS so it didn't come with a base map. This is where I got my base tune: MegaSquirtPNP by DIYAutoTune.com I had to pull a TON of timing out of that base tune and that is probably why it looks so weird. I attached a picture of what the map looked like before I changed it. If someone wants to recommend a new spark map that would be great.
Old 05-29-2018, 07:25 PM
I have no idea what you're doing, but I just opened several maps from that very link and none of them are like yours.
Either you're scaling wrong or something. None of them are as terrible as yours or have giant peaks/valleys.
which exact map are you opening?
Old 05-29-2018, 07:27 PM
shotgreen's Avatar
Which ones did you open? I got it from the 01-05 miata.
Old 05-29-2018, 07:32 PM
that's the only one I didn't open. ok wow that basemap is TERRIBLE. like, seriously
DIY should slap whoever put that up
Old 05-29-2018, 07:38 PM
shotgreen's Avatar
Just looked at the 99-00, HUGE difference. Now I know why it was knocking so bad. I will be switching over the the 99-00 spark map.
Old 05-30-2018, 02:24 AM
Reverant's Avatar
Total Cats: 361
Ho lee chit. Paging Ben.
Reverant is offline
Old 05-30-2018, 08:34 AM
Total Cats: 2,201
Paging @Ben
concealer404 is offline
Old 05-30-2018, 02:30 PM
The last time Ben actually opened MT:
Last Activity: 06-25-2017 08:19 AM
So yeah, good luck with that. Matt still logs in from time to time.
Old 05-30-2018, 10:47 PM
mj1176's Avatar
Don't want to start ****-talking DIYAutotune as Matt has been very helpful to me, but the website needs some serious updates. As of now it takes a lot of cross-referencing various instructions outside the DIYAutotune site to make sense of installing a DIYPNP, and as noted above, the basemaps leave a lot to be desired all things considered.
mj1176 is offline
Old 06-02-2018, 11:28 AM
Total Cats: 1,214
Their base map got the car started, I believe that's all they intended it to do. Although I really feel like 90-05 should have fairly similar timing maps.
curly is offline
ridethecliche
13
08-30-2017 01:28 PM
stratosteve
4
07-17-2014 10:44 AM
dirtythirtyix
6
05-04-2011 03:42 PM
miatauser884
ECUs and Tuning
6
05-05-2009 05:57 PM
zzyx7
12
02-21-2009 04:15 AM
Quick Reply: First drive on MS3 Knock is bad
