Greddy BOV Flange block off plate? cant find anywhere.
Total Cats: 196
I need a block off plate for a greddy Blow off valve 2 bolt flange. i cant seem to find one anywhere, or my googlefu is not strong enough.
since im going with an EFR, which has a built in re-circulation valve, i took off the BOV, but now need a plate to block it off.
here is the flange pic:
I 3d printed one, but i dont feel it will hold up under boost. need a metal one
Total Cats: 196
thanks for the suggestion, i was kinda trying to avoid cutting my own, and rather pay $20 bucks for a precut one. but i guess i have no choice.
only cutting tool i have is a dremel.
ill use the gasket as a template, which is what i did with my 3d printed plate. and cut it out of aluminum.
Ahhhhhh, gotcha.
If I were in your shoes, I'd just have a welder cut the old extension off and weld a aluminum circle or thick cap on there for cheap.
You could tap and thread it for the EFR bov reference possibly if you don't end up using the source on the compressor... Ya know, for those mad spools x11
Total Cats: 196
just measured my Thermostat water neck block off plate, and its indeed very close dimensionally to the greddy flange, i am sure i can make it work with a bit of dremmeling.
THANK YOU.
TheBandit
03-11-2019 01:22 PM
thesnowboarder
11-07-2009 10:25 PM
