Old 03-26-2018, 02:35 PM
  #10601
shlammed's Avatar
Total Cats: 51
Originally Posted by aidandj
Also going to weld a new brace to the turbine housing to support the turbo on the manifold better.
ive been saying this is the way to go.
Good on you.
shlammed is offline
Old 03-26-2018, 02:37 PM
  #10602
Yeah I just couldn't bring myself to weld on that shiny new housing. Now its tired and dirty, and I don't feel as bad. If I decided to ship my turbo back sans turbine housing I'm going to get my spare block on the engine stand for now I think and work on a brace. I got some 347 round stock, and just need to figure out material for the brace. I know @bbundy had to use chromoly because steel would crack on him.
Old 03-26-2018, 03:35 PM
  #10603
shlammed's Avatar
Total Cats: 51
Steel would fail?
It probably depends how light-weight your trying to make it. a 1/8" piece of round stock wouldn't do much.
The OEM formed plate for the 1jz turbo brace is around 1/8" thick but its formed from one piece at about an inch wide and I expect its somewhat optimized for the loading. it is essentially a section of 1" channel @ 1/8" thick with the way its formed.
I would probably do 0.5" round with a 1"x 5/32" tube for the block/turbo mounting ends. no need for heim's imho.
shlammed is offline
Old 03-26-2018, 03:48 PM
  #10604
Total Cats: 1,685
Go find the pictures JKav posted of how he did his fancy one, then copy that the best you can.
shuiend is offline
Old 03-26-2018, 04:23 PM
  #10605
I like bobs better. Its a "spring board" kind of mount, that supports the turbo from underneath. Just takes the weight off. I don't want to ridgid mount it.
https://www.miataturbo.net/diy-turbo...e2/#post803095
Sorry, not chromoly. 4130.
Old 03-26-2018, 04:28 PM
  #10606
bob = actually uses the car, hard.
jkav = I don't think that thing was ever finished. so..
Old 03-26-2018, 06:07 PM
  #10607
SadFab CEO
hi_im_sean's Avatar
Total Cats: 1,142
hi_im_sean is offline
Old 03-27-2018, 08:54 PM
  #10608
Total Cats: 859
4130 is a specific alloy that is included in the general classification of "chromoly", though I usually say "chrome-moly".
So, you were good.
DNMakinson is offline
Old 03-27-2018, 10:43 PM
  #10609
Goodbye my love. Safe travels.
Old 04-22-2018, 03:20 PM
  #10610
Old 04-22-2018, 03:26 PM
  #10611
turbofan's Avatar
Total Cats: 1,021
Wait... Goodbye, or see you later? Off for a rebuild or sold ?
turbofan is offline
Old 04-22-2018, 03:28 PM
  #10612
Lol. Pics above are rebuilt turbo pics. Painted and shiny.
Current plan is to take a friends old 99 motor and toss it in stock. Run low boost until I get time/money to rebuild the real motor.
Old 04-22-2018, 03:32 PM
  #10613
turbofan's Avatar
Total Cats: 1,021
Ohhhh I see now. I missed the split in the posts.
Whew, was nervous for a minute there.
turbofan is offline
Old 04-22-2018, 03:35 PM
  #10614
icantlearn's Avatar
Total Cats: 117
MMMmhhmmmmm......I like.
icantlearn is offline
Old 04-24-2018, 10:53 AM
  #10615
Someone correct me if I'm wrong.
Things needed to swap a stock BP4W in place of my VVT motor.
Cam sensor extension harness.
New oil feed line to wrap around the block to the oil pressure port
New drain line and bung
Anything else different between the 2 motors?
Old 04-24-2018, 10:58 AM
  #10616
afm
afm's Avatar
Total Cats: 508
Motor mount plates, but I imagine you’ll get those.
afm is offline
Old 04-24-2018, 10:59 AM
  #10617
Don't the VVT motor mount plates fit on the 99 oil pan anyways? Just without the extra bolt?
I may just run my VVT oil pan on the 99 motor anyways, the 99 oil pan is already off. Might toss bearings in as well (we have a spare set).
Old 04-24-2018, 11:04 AM
  #10618
Stock's Avatar
Total Cats: 138
Per Sav's thread, yes.
Stock is offline
Old 04-24-2018, 11:24 AM
  #10619
wackbards's Avatar
Total Cats: 266
Were you running a VICS IM before? Are the connectors the same for the VICS and the VCTS solenoids? IDK.
wackbards is offline
Old 04-24-2018, 11:32 AM
  #10620
I was running VICS before. And I believe they are.
