NASA ST5/TT5
Old 12-12-2017, 11:10 AM
  #61
Total Cats: 2,102
Ah, I see what you did there. Map out the torque and you'll get a good idea of the boost curve requirements for that curve.
e: 165hp @ 3000rpm = 288wtq, so that's not going to happen without a PD blower. Move it up to 3500rpm and you still need 247wtq, still hard. 4000rpm is 217wtq, which is totally doable. You realistically need to leave the power low until at least 5000rpm, so you'd need to then re-spool and make the power from 5500-8000, which is a reasonable powerband.
...hm.
Savington is offline
Old 12-12-2017, 11:51 AM
  #62
FatKao's Avatar
Total Cats: 32
Going back to the thread I looked at, I was looking at the torque line. Not the HP line :v:
https://www.miataturbo.net/dynos-tim...r-build-87880/
This likely isn't possible at ST5 power levels with a Miata motor. Now how can we get a LS into a Miata within the ST5 rules.
FatKao is offline
Old 12-12-2017, 12:11 PM
  #63
jpreston's Avatar
Total Cats: 176
It’s a cool idea to theorize about, but it would be a waste of time and money to actually do it. Remember, PT and ST are a dictatorship. Best case scenario: the first time you get dyno’d at an event, that graph will go into NASA’s database and the rules will quickly get changed. Worst case scenario: Greg retroactively DQs you a week or two after the event is over, which has happened before, and the rules still get changed. If you try to debut this setup at nationals, Greg will be there and will likely DQ on the spot as soon as he sees the graph.
Greg isn’t an idiot… he knows that something like this is possible, and he’s going to swiftly tell you to GTFO if you try to outspend everyone else and exploit this little loophole.
jpreston is offline
Old 12-13-2017, 10:10 AM
  #64
Midtenn's Avatar
Total Cats: 275
Originally Posted by doward
"We are going to revise the +0.3 Mod Factor from 200 TW non-R compounds tires to just 100 TW or higher."
Getting .3 P:W credit back for running 225 RC1, NT01, Rival, RE71R, etc is a good thing. It completely pays for the comp weight penalty if you run at >2450lbs...
This is pretty huge news, but not quite enough to shift the tire balance. It does create a pretty attractive build option, that will be absurdly fast at the right track:
>2450lb comp weight.
14.0 Base
+.7 A arms
+.3 2450lb+
-.3 100TW+
-.4 BTM aero (No airdam/wing)
14.3 P:W allows 171.4 average whp.
Airdam/wing +.4 brings it down to 14.7 and 166 average (deletes BTM aero credit)
Splitter +.5 brings it down to 15.2 and 161 average
Hoosiers +.3 bring it down to 15.5 and 158 average
Even on a tight track, I think 225 R7s are worth more time than being 150lbs lighter on 205s. So being over 2400 is wise. Being over 2450 earns you a .1 P:W credit.
Therefore, I still think that fastest all-around car is a 2451lb, 225 R7, with aero. This build runs at 15.5:1 and 158 average.
As a someone who's planning on building a SuperMiata S2 for whenever WRL decided to start running it, using the same tires would be nice. Plus I'd like to have backup plan in case WRL S2 never happens. Just thinking out loud, but would the Toyo R888R in a 225/50R15 be a better option for TT than the RC1-?
Midtenn is offline
Old 12-13-2017, 12:26 PM
  #65
flier129's Avatar
Total Cats: 319
It might be hard to find someone who has tested the R888Rs vs RC1, NT01, R7, etc on a miata. Are you volunteering?! I think you are, thanks!
flier129 is offline
Old 12-13-2017, 12:34 PM
  #66
Midtenn's Avatar
Total Cats: 275
If have had the means and time I would. New kid has severely limited my wrenching time and funds until the wife heads back to work. I was looking for even tire-to-tire comparisons, but didn't find much yet. Most people compare the RC-1's or R888R's to NT-01s, but I can't find information on all three for the same car.
Midtenn is offline
Old 12-14-2017, 02:28 AM
  #67
ITOzann's Avatar
Originally Posted by AA-Ron
I cant even be mad, they actually thought-through the average pw/wt for 2018. They caught what everyone was doing in ST1-4 and fixed it. I need to really read the rules a couple times and build a game plan for 2018.
Interesting the MX-5 Global Cup Car starts with a 0.0 mod factor.
This.
MX5GC weight about 2100 and make 140-160whp which make it kinda nuts that you can squeeze them in ST5. The lead in E1 was running 2secs faster than an ecotec NB at 24hr.
ITOzann is offline
Old 12-14-2017, 12:02 PM
  #68
doward's Avatar
Total Cats: 762
MX5GC still has to take the .7 A-arm hit and the .3-5 comp weight hit. Then it has to run on DOT tires. Its far from an overdog. It was in PTC before, and will have to slowed down to stay in 5.
doward is offline
Old 12-20-2017, 10:37 AM
  #69
cuonice's Avatar
Total Cats: 22
I've run all three of these tires (not back to back) - lap times in my experience were RC-1 > NT01 > R888r. The R888r was the slowest of the bunch and grained if over-driven. All tires were started at full tread; unshaved. An R7 is considerably faster than all three of those options.
cuonice is offline
Old 01-18-2018, 06:20 PM
  #70
doward's Avatar
Total Cats: 762
2018 ST calculator is live. Multi-tool with a new online classification form submission system.
https://form.jotform.com/drivenasa/s...ification-form
doward is offline
Old 01-22-2018, 03:23 PM
  #71
OGRacing's Avatar
Total Cats: 33
come get me at the next nasa race. I'll let you bolt on the rc-1's. they last for years anyway.
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
Originally Posted by Mobius
OGRacing is offline
Old 02-08-2018, 09:25 AM
  #72
RyanDavies's Avatar
Looking back at this, what is the min offset required for an unmodified fender on an NB for a 15x8 w/R7? Curious if 25 actually works (or 20).
RyanDavies is offline
Old 02-08-2018, 10:31 AM
  #73
flier129's Avatar
Total Cats: 319
+20 or +25 15x8 w/ 225("205 R7") works without a rolled fender on NBs with the correct camber.
flier129 is offline
Old 02-19-2018, 05:24 PM
  #74
doward's Avatar
Total Cats: 762
NASA Arizona, Chuckwalla, Feb 2018.
We ended up having 5 ST5 cars, but no real racing battles. I was out front with a gap on my slower tires.
I set Pole, 3 ST race wins, 2 TT wins.
However, I now have some class vs class pace comparisons:
My sorta ST5 specific NB Miata
A slightly upgraded PTD "FB" RX7
A PTD E46 330CI, painter's tape class letters was added on Sunday
An ST4/SpecBoxster on a regional allowance to run in ST5.
A Spec Racer Ford.
I ran 3 seconds under the fastest Spec Miata(NASA SM on Toyo RR) on my 225/45/15 Maxxis RC1. That's a good sign for 100TWs. I do not have enough engine to take advantage of the extra .3 P:W credit from running 100TWs, so that delta should be even larger.
2:03.048 vs 2:06.095 on CW Saturday.
2:05.619 vs 2:08.562 CCW Sunday, hot/windy/dusty, everybody went slower in the afternoon.
For TT I ran 205 Hoosier R7s and went 2.1-2.6 seconds faster. This is a bad sign for 100TWs. lol
2:00.983 CW Saturday, 4:40pm.
2:01.032 CCW Sunday. 8:50am.
I would have finished 2nd(of 5) in TT4 on Sunday.
1.2s under the TTD CW record from 2012. ("Crusher")
1.1 off the TTD CCW record from 2014.
1.6 off the TTC records both ways.
I think ultimately, TT5 will match or beat TTC times, even with the lower P:W limit.
My raw P:W was 16.3:1 this weekend, adjusted was 15.3 in ST5 on Maxxis, 14.7 in TT5 on R7s.
I was ballasting the car for each wheel combo to try and stay within 50lbs on my Min. 225/45 RC1 on 9" wheel vs 205 R7 on 8" wheel. Package weight difference of like 24lbs.
Burning e85 ~40% faster than gas also makes it more difficult to gauge fuel weight sometimes.
205/50/15 R7 officially legal for cars under 2400lbs, when mounted on 8" wheel:
Keith Dee's ex PTD FB rx7, removable one piece front clip was sweet. Keith was runing 225/45 Toyo RR on 8" under 2400lbs. Not sure if he got tire templated or not, but they aren't much bigger than my 225/45 RC1s on 9" wheels.
doward is offline
Old 02-19-2018, 09:03 PM
  #75
doward's Avatar
Total Cats: 762
Socal/Arizona ST5 Field:
doward is offline
Old 03-13-2018, 01:41 PM
  #76
ThePass's Avatar
Total Cats: 1,216
Not sure if relevant for ST5 but made tire templates and started checking things we have around the shop.
225/45 NT01 on 15x9 fits 226 template
245/40 Rival S1.5 on 15x10 fits 257 template
Ryan Passey
ThePass is offline
Old 04-19-2018, 03:46 PM
  #77
doward's Avatar
Total Cats: 762
7 in class this weekend at Buttonwillow.
2 FRS
2 NB Miata
1 NA Miata
1 IS300
1 E46 330CI
doward is offline
Old 04-20-2018, 09:22 PM
  #78
doward's Avatar
Total Cats: 762
First time on sticker R7s in ST5 trim this weekend.
Couple well prepped cars too. Should be fun.
doward is offline
Old 04-22-2018, 11:43 PM
  #79
AlwaysBroken's Avatar
Originally Posted by FatKao
Is it possible to build this with a GT255R?
A motor with a high enough redline, a small enough turbo, and a class with relatively tiny HP maxes you can trip his max HP in some useless part of the power band then run way more than you should where it matters. The 'dyno' posted is based on some random MT.net GT255R dyno up to 3,000 RPM and is 149 avg whp by the rule book.
Just run an EBC, set your boost targets at each RPM so that it seeks up and down as desired. You can be totally closed loop for those RPMs on the dyno. The detailed answer is going to depend on what software you're controlling wg duty cycle with. The torque curve will look like something from a chipped diesel VW.
edit- I'm assuming that turbo can hit 20+ psi of boost at 3k rpm and then drop it to zero 500 rpm later. That might be tricky. I have no idea about the 2554 beyond it being really small. As sav basically said above, you're basically going to pick the lowest RPM possible, create a big boost spike, drop it back to zero boost for a few thousand RPM and then go up to whatever your real target is for the rest of the RPM range.
You'll need a really big external wastegate to avoid boost creep.
In unrelated news, how would they catch someone who programs their boost controller to switch to a high boost setting during a race and then switch back to low boost at all other times. You could trigger it with a radio signal or the abs sensor (so it only goes fast when the car is actually moving, etc).
edit2- they use GPS based measurement to see if you're obviously cheating
AlwaysBroken is offline
Old 05-11-2018, 07:37 PM
  #80
zigspeed10's Avatar
Anyone know if a 225 R7 fits the 257mm template on a 9” wheel? Asking for a friend...
Haven’t seen much talk about the 205 BFG R1, maybe it will fit the 226mm template on a 9” wheel?
zigspeed10 is offline
Quick Reply: NASA ST5/TT5
