Superefficient cooling via geographic location
#147
Alright, the subframe is out and I got a professional welder coming in the next couple of days to take care of the chassis rail.
While the subframe was out I couldn't resist lowering the car on top of the engine to mock up the electrical system and see how things would fit. Gotta say that seeing it in the car gave me a bit of a morale boost.
Seeing the turbo there gets me thinking. I'm not running power steering and don't have AC. Do I still need an idler pulley or can I get away with just running the alternator off the crank? Without an idler it seems that the best IC piping route would just to go inside of the chassis rail
#149
Total Cats: 365
More details please.
Was this some Icelandic superpower you invoked? Because I picked up my block, to put it into the car to go to the machine shop, and about got a massive hernia.
I realize this question is a bit late. Progress looks good! Boost is good!
#154
Total Cats: 1,687
Wait this could be good. G3ML1NGZ is a powerlifter. ViperorMiata is a pwoerlifter. I think we are about to have the first MT.net lift off. Next Sunday my backyard. I have several different Miata's they can lift and put in a giant dumpster for me and then I can crown one of them the strongest lifter on MT.
#158
Total Cats: 365
I applaud your icelandic superpowers. That silver NB does look pretty sweet.
Plans to rebuild my (literally) disintegrating garage are progressing nicely. Having not your Icelandic Superpowers, I've opted to have an I-beam specced out for the ceiling, so I can run a gantry crane on it, with either a come-along or perhaps a cheap electric winch. Because my swimming superpower days are far behind me, and my hernia potential days are Here and Now _
#160
finally got back into working on the car after a short hiatus while getting settled in the new house.
fitted the dynapro's last night.
drilled new holes for the rear ABS sensors since the roll bar blocks their original access holes.
reassembled most of the interior
My parents gave me a dash cam and I was wondering about powering it. I seem to have lost my ohmmeter in the move so I can't check my plan so I'm asking you guys.
My hard top does not come with defroster so the plug is just sitting there unused.
Could I use the plug for that as a power source for the dash cam mounted in the roll bar and use the defroster switch as an on/off switch?
otherwise the electrical harness will be finished tomorrow and hopefully tossing the engine in over the weekend.
