MR-S Rear Hub Discussion
Old 04-03-2018, 01:36 PM
  #101
GeneSplicer's Avatar
Total Cats: 180
Originally Posted by flier129
Did you have your machine-shop guy do this?
yeah, he whipped it out real quick like. My hub wasn't pressed in yet
GeneSplicer is offline
Old 04-03-2018, 01:38 PM
  #102
themonkeyman's Avatar
Total Cats: 77
Nevermind. Misunderstood at first. Carry on.
themonkeyman is offline
Old 04-03-2018, 01:44 PM
  #103
Bronson M's Avatar
Total Cats: 217
That's not how this works, that's not how any of this works!
The hub OD doesn't locate anything, the center stub does locate the brakes rotor. The wheels are always located by the studs even if you have wheels with the right center bore. If you use tapered lug nuts then they locate the wheel.
Bronson M is offline
Old 04-03-2018, 01:48 PM
  #104
Total Cats: 77
I mistakenly thought they were referring to the hub center bore, not the OD, then gave the pictures a closer look. Updated my post accordingly.
However, I’ve found that even with tapered lugs/seats a mismatched hub bore without a centering ring can ride offset ever so slightly and vibrate. Sorry to thread drift.
Old 04-03-2018, 11:37 PM
  #105
Total Cats: 180
I expect you see a yt video soon of grinder against moving hub!
Old 04-03-2018, 11:59 PM
  #106
YeboGoGo's Avatar
Total Cats: -11
I got so excited when I read this title.. I figured someone solved the need to have hubs broached for axles.
regardless this is a good find!
YeboGoGo is offline
Old 04-04-2018, 09:44 AM
  #107
flier129's Avatar
Total Cats: 319
flier129 is offline
Old 04-04-2018, 10:25 AM
  #108
SadFab CEO
hi_im_sean's Avatar
Total Cats: 1,142
Updated, final
hi_im_sean is offline
Old 04-04-2018, 10:48 PM
  #109
ʎpunq qoq
Madjak's Avatar
Total Cats: 201
Thanks Sean. I hope you don't mind by I modified it for myself and figured some other people outside of the US might find this useful too.
Here it is again with metric dimensions for those Imperially challenged:
Madjak is offline
Old 04-04-2018, 10:54 PM
  #110
SadFab CEO
hi_im_sean's Avatar
Total Cats: 1,142
Was actually going to do that but was pressed for time, so thanks!
Old 04-05-2018, 01:37 AM
  #111
phocup's Avatar
Originally Posted by Midtenn
4x114.3 lug pattern maybe?
I really wish it was .. damn it.
In for some anyways with the SADFab groupbuy. Thanks OP.
phocup is offline
Old 04-05-2018, 08:30 AM
  #112
ʎpunq qoq
Madjak's Avatar
Total Cats: 201
If you can work with 5 x 100 you could try a Celica GTS front hub They are 23 spline edit: 26 spline and fit the MR2 Spyder rear hubs (same bearings). They will probably need similar modifications to the above.
Part No: Dorman 930406
Madjak is offline
Old 04-05-2018, 12:20 PM
  #113
phocup's Avatar
That's good to know. I wanted 4x114.3 for a specific set of wheel though. Thanks anyways.
phocup is offline
Old 04-05-2018, 12:48 PM
  #114
Mobius's Avatar
Total Cats: 365
Does the SadFab run have an ABS ring? Asking for a friend.
Mobius is offline
Old 04-05-2018, 01:17 PM
  #115
SadFab CEO
hi_im_sean's Avatar
Total Cats: 1,142
The ABS ring is part of the axle, not the hub. So, yes?
Old 04-05-2018, 03:03 PM
  #116
Mobius's Avatar
Total Cats: 365
Ah, yes. My coffee was weak this morning.
Mobius is offline
Old 04-05-2018, 03:41 PM
  #117
Total Cats: 180
sorry - couldn't resist!
Old 04-05-2018, 07:23 PM
  #118
Gee Emm's Avatar
Total Cats: 195
Kudos to GeneSplicer for this work! What a great contribution to the community!
Gee Emm is offline
Old 04-07-2018, 01:33 AM
  #119
mr_hyde's Avatar
Total Cats: 24
Details on this group buy?
mr_hyde is offline
Old 04-07-2018, 08:50 AM
  #120
Total Cats: 3,075
You can't haz none.
sixshooter is offline
Quick Reply: MR-S Rear Hub Discussion
