OG Racing: PFC race pads.
#201
NEW compounds coming out soon for 1.8L endurance and track day drivers, this will be aimed at you!
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
#203
ND miata Pads Incoming from PFC!
Available compounds.
PFC 11. The daddy and the #1 choice of professional race teams. Well over 200 professional level championships won (nascar,Imsa, PWC ect..) . Soft bite to avoid flat spotting and helps keep the vehicle stable under initial braking,
Dead straight consistent Tq output, less than 4% change over 1200*. Professional drivers love this.
Easy modulation helps you nail that trail braking moment.
Recommended for tires that range in QUTG from 200-50.
PFC13 The high torq option!
The new compound offering from PFC for those with mega sticky tires, and big downforce!
High Torque for slowing the biggest of race tires. or for easing pedal effort with manual brakes.
Recommended for tires that range in QUTG from 90 and less, OR for manual brakes with qutg180 or less.
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
#204
Joey from WRL mentioned he was in talks with with a few companies to replace HAWK for contingency....Hoping one of them is PFC! Sound like there are A LOT of racers from multiple organizations that have not received any pay out from HAWK for 2017 results. I was actually thinking of trying some DTC 60's for the SM this season since HAWK owes me a few hundred "bucks", but looks like I'll be staying with my trusty PFC 97's!
#205
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
#206
The 1.8L Endurance compounds are here!!
PFC 08 compound. Used extensively as an endurance compound in Grand Am, ALMS, and IMSA now available only from OG racing for the Miata platform. These 08's share the soft bite, consistent torq output and easy modulation loved in the 11 but with more life!
Recommended tires. Anything in the 245 wide categories, QUTG must be 200 or lower. Rival s, Bridgestone re71-r, MAxxis VR-1, Rc-1, Hoosier, Pirelli P Zero. Get yours today!
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
#207
Will there ever be a 7754 pad shape option that is on the 11-12mm side of thickness instead of 16mm?
I just bought the set of 7752 to modify for dynopro (after having incorrectly purchased the 7754 years ago) and it was quite the experience to grind to clear a bridge bolt let alone the e-clip.
Not that big a deal, but it makes me want to buy a used Bridgeport
#208
that little spring is a pain. I'm still on the hunt for a 2 spring option that doesn't cross over the top.
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
#209
Ordered a set of the new 08 enduro compound and will be running them this weekend in the 14-Hour ChampCar race at Charlotte Speedway. Basically a '99 PTE car on 225 RS4s...~2350 lbs, 125ish whp. Standard 1.8 brakes with some ducting.
Will report back on how they do and how we like them.
#211
good luck guys!
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
#212
They've added a bus stop on the back straight thereby adding a pretty decent braking zone and breaking up the extremely long full throttle "straight".
Would you still recommend taping up the ducts with the added bus stop?
Also, we run $22 rotors. My only concern for the rotors is that they last 14 hours. If I'm not worried about adding thermal shock stress cycles to the rotors because they'll be tossed after the race, are we better off having brake cooling to improve pad life?
What's the minimum working temperature for the 08 compound? I guess I'd be more worried about not getting enough heat in the brakes since we're fairly low on HP and we're running only 225 RS4s. We've had no issue getting GLoc R12s up to temp and working well with the same setup at other tracks.
Thanks for your input.
Last edited by Efini~FC3S; 04-17-2018 at 02:53 PM. Reason: Phone posting is the worst
#213
@OGRacing
Min temp is around 200*f I'm not worried about the pads working. I'm worried about the $22 rotor starting to break up from repeated cold-hot-cold-hot-cold-hot-cold-hot-cold-hot-cold-hot-cold-hot-cold-hot for 14 hours. the $22 rotors have a tendency to flake off the surface material when thermally shocked too much.
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
#214
I’ve read this thread twice, still can’t decide.
180hp turbo NA. Mostly track car, driven to/from track. Occasionally use to run around or go to the mountains. HPDE intermediate driver, usually +3-5 seconds vs. SM lap times. 200tw tires on 15x8, currently 205 RE-71R. TSE 11.75 Dynalite BBK in front, 1.8 caliper with relocation bracket and Sport rotors in back. Wildwood prop valve.
So- 01/11 compound or 97 compound?
EDIT- didn’t get an answer here and needed to order. It looks like my tires are right on the line between the two compounds; decided to go with the 14/97 compound. I‘m not racing and I don’t have ABS, it looks like the 97’s will be a little easier to modulate. We’ll see how Iike them.
FOLLOW UP, IN CASE ANYONE CARES: Did a track day with the 97's yesterday, they were really great with this setup. A+
OGRacing
OG Racing
06-01-2015 04:38 PM
