Injector Question
Injector Question
02 Miata MS3Pro PNP
I just installed the ID 1300x2 model. In tuner studio what value do I use for these? I ask because there's logical choices according to the chart below. This is from the slope & offset vs pressure. Do I use the 14v value since the car runs at 14v, the 12v value since it is a 12v system or the slope value? I am probably overthinking this but want to be sure.
SadFab CEO
Total Cats: 1,142
You input all the voltage values into the table that accepts them at the pressure you are running. I have data from 10V to 15V for my injectors, so my table reflects the data points and interpolates the rest.
go here
Megasquirt : Injector Dynamics Support
input the pressure you're at and it gives you all the data you need. or email them and they'll give you what you need
I think I found it:
Fuel Settings --> Injector Dead-Time/PWM
Fuel Settings --> Injector Small Pulsewidths
Then input the data from the spreadsheet?
This creates Dead time voltage % curve 1
then tell it to use curve 1 for all injectors, if this is the case the default curve sucks hard core, its at 100% across all voltage ranges. AM I understanding this correctly?
kidrabbit84
Engine Performance
80
02-15-2014 12:57 PM
WonTon
12-31-2010 12:46 AM
Cody Strife
05-05-2009 08:30 PM
