#1062
Total Cats: 560
I guess I'm gonna have to put the ridiculous phone holding contraption back in my car for you guys. Look out for more super duper high as a kite quality phone videos, coming to a build thread near you
#1066
Total Cats: 560
I have been over thinking the dead times. The 60psi numbers work great. I should have just listened to what 75 Datsun Ted said a few pages back. My differential pressure across the injectors is always 60psi, so vacuum or boost reference doesn't make any difference from the injector's perspective.
#1067
Total Cats: 560
And this little hill climb for Thumpetto, only about 250kpa because I tried a huge gap in my plugs this morning and it's not working out well.
This is a pretty steep hill for the freeway. Couldn't get a clean pass, hopefully it won't rain on Wednesday and I can get a real pull. The contraption is in my car now anyway. If it rains, I am going to get 5 gallons of e85 on Wednesday so I can get my car starting and running on it before I show up at the station empty.
#1070
Total Cats: 560
Truth is, I am still struggling with spark above 30psi or so, sometimes less if it's cold out. I pulled some old plugs out this morning and decided I would try an .040 gap. Just because I have been shrinking and shrinking the gap and couldn't remember the last time I ran bigger than .025 so I figured WTF. As I imagined, it got worse, but I kept considering it and now I won't.
I plan to start project mega ground soon. I also wonder if somehow taking power from the alternator is causing me a problem.
My ignition wiring and grounding is pretty massive already. Might try some fancy Taylor wires too.
#1078
Total Cats: 560
It's kinda tight, that's what she said
Just pay attention to #1 & #2 IIRC. You need to get the hood bracing between them but avoid the PCV valve with #2. There's a nice hump on my NB hood that makes plenty of space for #1.
I don't think spark is escaping to the hood if that's what you're getting at, I suppose it's possible though. I specifically oriented the coils so the plug wire terminal would be as far away from everything as possible.
