Tapered Roller Bearing Hubs--IT'S HAPPENING
#264
I have a set of the tapered roller bearings from Mazda that I may throw on the car for our next double 8 hour race in April. I already have them, so why not try them out. I'll try to follow the above videos to get them adjusted correctly. Fingers crossed.
I can't find that they have released replacement bearings cartridges. Has anyone found a source yet?
#271
Boost Pope
Total Cats: 6,918
I don't have a clue what that shaft is for. It's lying on the floor in one of the large utility spaces on the 104th floor of Sears. Most of the big pumps that drive the chilled-water system are up there, but their shafts are smaller. It's possible that it might be for an elevator- some of the machinery for them is beneath the floor near that area (basically in floor 103, but accessed from above.)
#272
SadFab CEO
Total Cats: 1,142
If I had to guess, the one posted earlier is part of a loader axle. @sixshooter?
Edit- thought we were in rando thread, i will no longer contribute to the derailment of this thread
#276
Thread update
OK, here's the deal. We spent the time (and money) on some really promising FEA, and created a front and rear hub around the largest possible roller bearing that we could fit on a Miata. The FEA numbers said that we were much, much stronger than stock.
And then we went to a tier 1 OEM supplier for hubs. They agreed to make them for us, and built a couple of prototypes for testing. We should have asked for a dozen prototypes because we just didn't have enough to test. And while the hub looked excellent, the bearings that we called out to use were not in the hubs. The manufacturer had used no-name bearings. Ugh.
But anyway, to the test. The hubs were shaken down on track, and started showing signs of wear far sooner than they should have.
OK, maybe it was the no-name bearings. SO....the bearings were changed to name brand and were thrown on an endurance car. That car went out and won its next two races. Good. Except after the second race the hubs had play. While we tried to determine if it was the bearings, the hub design, or even the grease that was used (stock grease, not repacked), the answer didn't pop out. That's the reason for the silence.
Technically the hubs SHOULD work. On paper they are better in every way than the stocker units. But they didn't. So as a result we went back to the manufacturer and said that we needed to do a broader test with more hubs---and the correct bearings with the correct grease. We never got to this test because the large OEM manufacturer decided we were just too small to deal with. It's a crushing blow.
While it's possible to start over with another manufacturer, we may be chasing after a flawed part. We just don't know. What I do know is that a turbo Miata (or V6 or V8) with fat tires requires wheel hub bearings and hubs and spindles that are more robust than what originally came on the car. While the pure racer expects to change many components on a regular basis, wouldn't it be nice to just install the hubs and forget about them? No adjustment after every weekend. No re-greasing after 20 hours, no replacement after every season. Part of what makes a Miata so much fun is that they don't cost and arm and a leg to operate.
That is the update.
That is the update.
#278
Wow, that sucks about the manufacturer blowing you off and substituting crappy bearings.
Do you feel that you're going to end up getting these made in any sort of saleable quantity? Would they be anything approaching a reasonable price without the tier 1 oem making them?
#279
Why dont we just do the easy thing and copy the stock hub design, make the flange a little thicker and make the rads more generous but use 9310 cased (probably still do like 40ish Rc for the core hardness) and use grade 10 or better SiN (or heck M50 for lower cost) ***** with factory races. All the failed front hubs from wear look like they'ed easily be remedied by using more uniformly sized ***** and with harder races on the hub side. If you insisted on spending money you could make custom races you probably could size the ***** up from 10mm to a cheaper 7/16" ball and still have plenty of meat in the hub. And if you really wanted to throw money as it you probably could get all the races hard chromed to bring the surface hardness up from like 60Rc to like 75Rc.
#280
Master Ceramic & Steel Racing Bearing List
