Where did this wire go?
Old 03-03-2018, 11:57 AM
miata2fast's Avatar
Total Cats: 174
Default Where did this wire go?
It’s on a 95 engine bay fuse box. Where does the black wire with terminal end do? You can see it loops to bolted black wire that comes from the starter. I vaguely recall it going back to the fuse box somewhere, or did it go to back into wiring harness? Much obliged.
miata2fast is offline
Old 03-03-2018, 01:06 PM
gooflophaze's Avatar
Total Cats: 156
Back into the box. Remove the fuses till you see one with only one leg. Theres a plastic retention "slide" that you appear to be missing.
gooflophaze is offline
Old 03-03-2018, 03:21 PM
miata2fast's Avatar
Total Cats: 174
Thank you for the help. Pretty sure the slide you are referring to is the one with the white wire plugged just to the right of the bolted black wire.
Old 03-04-2018, 08:02 AM
miata2fast's Avatar
Total Cats: 174
After fiddling with it for way to long, I am pretty convinced it’s not where it goes. That or there is something missing that would allow it to be pinned properly.
Old 03-04-2018, 08:43 AM
Total Cats: 4,102
it goes to the retractor fuse.
Braineack is offline
Old 03-05-2018, 07:53 AM
miata2fast's Avatar
Total Cats: 174
That's it, thank you.
k24madness
07-11-2011 09:02 PM
WonTon
Insert BS here
17
12-09-2010 07:22 PM
Chris Swearingen
04-15-2010 12:45 AM
92Miata
10-11-2008 06:59 AM
rmcelwee
05-06-2007 02:07 PM
Quick Reply: Where did this wire go?
