Old 02-06-2018, 11:31 AM
  #981
Total Cats: 560
Yeah, just curious, thanks again Vlad!
sonofthehill is offline
Old 02-06-2018, 07:49 PM
  #982
Total Cats: 859
Originally Posted by sonofthehill
Yes a 1:1 boost reference fuel pressure regulator.
Nothing too extreme, 60psi base and a boost reference to keep the fuel flowing during high boost.
My question is, can I just run a charge pipe reference instead of a manifold reference to keep my fuel pressure at 60 psi, when not in boost?
No you cannot. When the turbo spools up a little against a partially closed throttle, you will get extra fuel, as the charge Absolute Pressure will be greater than the Manifold Absolute Pressure. Next time, under a different load scenario, the same RPM and Manifold might be at a more open throttle, so then the MAP would be closer to the Charge Pipe. Now LEAN.
I really believe tuning would be a total nightmare.
DNMakinson is offline
Old 02-06-2018, 10:10 PM
  #983
nigelt's Avatar
Total Cats: 388
40psi fuel pressure at idle would be totally fine. NAs run 43.5 psi, and Mustangs (which run the same injectors) run at 38psi.
nigelt is offline
Old 02-06-2018, 11:11 PM
  #984
Total Cats: 560
Originally Posted by 18psi
fuel efficiency? like from poor atomization due to lower pressure? won't even be noticeable
Yep, started, idled, and ran just fine with a manifold reference. There may be some difference in my log but it wasn't noticeable.
What was noticeable is that I am now pig rich in boost I need to look at my log and fill up my tank now. Thanks again everyone!
Old 02-09-2018, 07:46 PM
  #985
Total Cats: 560
Wow, just wow! Is almost looks like someone dropped an iron on my VE table and it's still rich in high boost. I think I am logging about 70% injector duty way rich now, where I was at 115% barely able to hit my AFR target before. It is amazing how much difference the pump and regulator have made.
​Haven't turned my EBC on or been past about 5500 RPM. I basically stomp the throttle and watch my AFR dip into the 10's, then let off. Go examine my log, adjust and repeat. Won't be long now.
Old 02-09-2018, 10:55 PM
  #986
nigelt's Avatar
Total Cats: 388
Allofit!!
nigelt is offline
Old 02-10-2018, 08:27 PM
  #987
Total Cats: 560
Not yet. Finally comfortable stomping on it without worrying about hydro locking the thing. Still a little rich, but almost there, don't want to **** around above 250 kpa. Still a ton left on the table for the original Flow Force injectors with a proper pump and regulator. Amazing difference! Thanks for the fueling bits Andrew and George!
And yes, it is noisier than my Wally 190. I mounted my regulator under the fuel pump access panel and I think the regulator itself is pretty noisy.
Old 02-14-2018, 09:50 PM
  #988
Total Cats: 560
Checking measurements for a different bracket and slightly longer return hose, I had the panel open again so I thought I'd try the image loader once more. Mods feel free to remove this post if the picture ends up site cloggingly huge.
Aww ****! They seem huge again, WTF is up with my phone
Old 02-14-2018, 09:51 PM
  #989
Total Cats: 560
Huh, I guess they came out OK
Old 02-18-2018, 07:21 PM
  #990
Total Cats: 560
Still not perfect, but getting there. I can reach 28psi now without a misfire, my fuel pressure was causing the misfire not my coils.
Tires, real bad now!
Old 02-19-2018, 12:56 PM
  #991
icantlearn's Avatar
Total Cats: 117
You should do a virtual dyno run. Because science
icantlearn is offline
Old 02-20-2018, 12:20 AM
  #992
Total Cats: 560
There's a 1/4 mile Wednesday coming up soon, how about some time slips?
The thing's crazy now, I am out of fuel again. Hey Nigel, when can I upgrade?
Old 02-20-2018, 12:30 AM
  #993
nigelt's Avatar
Total Cats: 388
29psi... that's impressive.
Injectors are ready when you are! You'll enjoy the 50% more fuel.
nigelt is offline
Old 02-20-2018, 12:35 PM
  #994
neeeeeeeeeeds e85
Old 02-20-2018, 07:37 PM
  #995
Total Cats: 560
Well, that's the plan. I emailed Nigel.
When I do finally fill up with e85, do I need to add timing to idle or can I just multiply my req fuel 1.33 and up my cranking pulse. I just don't want to get stuck at the e85 station in SF. I think I have K24MADNESS''s e85 project we had running, maybe I will have a look at that.
Old 02-20-2018, 07:39 PM
  #996
Total Cats: 560
Maybe it would be smarter to get a 5 gallon jug of the stuff and do it at home.
Old 02-20-2018, 07:40 PM
  #997
You can, don't have to, but it helps. Esp in the startup sweep cells. You will have to adjust your cold start in addition to req fuel. That's basically it.
Target 12 flat in boost or high 11's if you want to shoot for the moon. Looking at your current spark table, you can start with at least 5* more basically everywhere.
Old 02-20-2018, 07:57 PM
  #998
Total Cats: 560
Thanks man!
Old 02-21-2018, 09:54 AM
  #999
nigelt's Avatar
Total Cats: 388
I'd like to be the first to congratulate you on achieving 1000 semi-coherent half drunken posts in this build thread while pumping an absurd amount of boost through a $200 turbo.
nigelt is offline
Old 02-21-2018, 12:23 PM
  #1000
Total Cats: 1,687
I mean I sure as hell never expected someone to put 25+psi through one of my turbo setups.
shuiend is offline
