Front Main Seal Disaster
Total Cats: 38
Looks like my FMS folded over on it self while using the FM tool. Has this happened to anyone before?!
What can I do to prevent this from happening agian?
Make sure you lubricate the crank and seal before you slide the seal over the crank and drive it home. A bit of engine oil, assembly lube or wheel bearing grease will do the trick. You should not put it on dry. Same for your cam seals if you changed them.
Total Cats: 1,214
You still have to put it on correctly before using the FM tool. All the tool does is drive it straight and to the correct depth into the oil pump bore, it does nothing to install the seal on the crank correctly.
soflarick
11
06-10-2008 03:23 PM
neogenesis2004
01-22-2007 12:29 AM
mx5 squirrel
12-23-2006 11:05 AM
