11's on the Motor, 9's on the Nitrous
Old 01-14-2018, 07:27 PM
  #441
Full_Tilt_Boogie's Avatar
Total Cats: 407
I still looking forward to how awesome this thing is going to sound through those DCOEs
Full_Tilt_Boogie is offline
Old 01-14-2018, 07:39 PM
  #442
Total Cats: 3,051
You're going to need to come down when we do some track days. You aren't that far away and there's no good reason we haven't met since you've been on the forum so long.
He's planning on taking it to Sebring, too.
I would love to be standing next to the wall when this thing comes screaming by at 100+ MPH on the straights at Sebring. I'll take video when it happens.
sixshooter is offline
Old 01-15-2018, 12:21 AM
  #443
Total Cats: 407
For sure. You guys ever go out to the FIRM? One of my buddies used to work there as a rally instructor. It sounds like they have a nice asphalt roadcourse where its pretty easy to get a lot of track time in.
Old 01-15-2018, 08:45 AM
  #444
miata2fast's Avatar
Total Cats: 174
A few years ago they did a news segment about rally instruction there. Looks like a pretty cool place.
miata2fast is offline
Old 01-15-2018, 11:53 AM
  #445
pdexta's Avatar
Total Cats: 183
Is there a goal for completion on this thing? I'd definitely like to be at the track to see you make some passes.
I dug through the thread a bit and didn't see anything about the transmission. What are your plans there? Manual or auto?
pdexta is offline
Old 01-15-2018, 02:18 PM
  #446
Total Cats: 3,051
He's staying with the stock 5 speed for now. It's lighter than most other options.
Is there a goal for completion?
Yes. There is a goal he will eventually complete it.
Old 01-15-2018, 03:21 PM
  #447
pdexta's Avatar
Total Cats: 183
Haha, figured as much. I'm just getting excited seeing some progress being made.
pdexta is offline
Old 01-15-2018, 04:45 PM
  #448
miata2fast's Avatar
Total Cats: 174
Yeah, me too.
I have a small stack of 5 speeds. Once they all go from shed to car to scrap pile, I will come up with a solution.
Old 01-19-2018, 06:50 PM
  #449
miata2fast's Avatar
Total Cats: 174
So, after much thought, I decided to make a few small changes to my cooling system to make the factory oil filter cooler more efficient. Before I make the change, how often is the factory cooler/heater eliminated on track cars?
Old 01-19-2018, 07:37 PM
  #450
Total Cats: 857
If an oil cooler with adaptor plate is used, the factory oil cooler is needed to allow space for the fittings. Else some other spacer is needed anyway.
Now that is not to say that the coolant lines remain.
DNMakinson is offline
Old 01-21-2018, 10:16 AM
  #451
miata2fast's Avatar
Total Cats: 174
Here is my latest update. Because I am waiting on parts for the fuel system, I decided to tackle the rest of the cooling system. There were a few problems with my initial welding of the water neck. I had to have the bung enlarged a bit to fit the coolant sensor, and I cut off the 4-AN fitting and had a 6-AN installed.
I also had an issue finding a hose that would go from the bottom of the radiator to the water neck on the electric water pump. First, I had to shorten the water neck to have the correct radius and angle from radiator to water neck. I found a stainless J tubing the size of the water neck at Summit Racing. I cut it down to size, and used scraps from the lower radiator hose I butchered earlier in attempts to make the original longer water neck work.
Old 01-21-2018, 10:18 AM
  #452
miata2fast's Avatar
Total Cats: 174
Here is the mostly finished product.
Old 01-21-2018, 11:38 AM
  #453
Ryan_G's Avatar
Total Cats: 217
So much progress! Let's keep it on going.
Ryan_G is offline
Old 01-21-2018, 12:51 PM
  #454
miata2fast's Avatar
Total Cats: 174
I am spending a few hours on it today. I need to make brackets for nitrous and fuel solenoids, and start plumbing the fuel side of the nitrous system.
Old 01-21-2018, 06:50 PM
  #455
miata2fast's Avatar
Total Cats: 174
I decided to ditch the oil cooler/warmer.
The one that came on my motor has continuous threads the entire length of the nipple, so it was easy to cut down to size. The other unmolested nipple in the pic came from an NB motor.
Old 01-21-2018, 06:58 PM
  #456
miata2fast's Avatar
Total Cats: 174
This is where it gets a little more interesting. After experimenting with various mounting configurations, I am mounting all nitrous hardware under the carburetors. Instead of a loud and proud aesthetic, I am going with a more stealthy approach.
Attached to the distribution blocks are poly tube adapters. Being the foggers are underneath the intake, it will make servicing the jets easier
I just need to make brackets to mount to the carburetor mounting studs.
Old 01-23-2018, 11:17 AM
  #457
LownSlow616's Avatar
Total Cats: -23
I like that oil warmer delete. Now you're just going to have a sandwich plate directly against the block? Oil filter will screw directly on to that threaded piece? No aftermarket threaded adapter, less failure points.
LownSlow616 is offline
Old 01-23-2018, 12:25 PM
  #458
miata2fast's Avatar
Total Cats: 174
Oil filter seats directly to the block.
Old 01-23-2018, 01:50 PM
  #459
Total Cats: 857
You'll just have to be careful no to spin a bearing due to cold oil and wicked high RPM's on the strip. Or so I've been told.
Old 01-23-2018, 03:52 PM
  #460
Total Cats: 3,051
have you seen his cooling system? How about the nitrous octopus he just posted? And then there's the aftermarket fuel lines, multiple regulators, and dual carburetors. Troy is all about simplicity, LOL
Quick Reply: 11's on the Motor, 9's on the Nitrous
