#962
Total Cats: 560
The spoils from my trip to meet Miataman00.
It was good to see you again George, thanks for the goodies!
Now I can get to ordering some things from Savington.
And this for folks wondering about it, I believe this is an original Mazda assembly. Looks like a nylon zip tie directing the flow to the sock.
#963
Total Cats: 560
These bits from TSE showed up today, thanks Andrew.
This is how I get the quick connect fittings off ez pz. I managed to do it at Miataman00's place with a couple pieces of a zip tie.
I need to figure out all my plumbing details, so this won't be instant. I might go race tomorrow morning, if I get up early enough, it will be free since we were rained out last time. Not really a fan of weekend events, maybe I should just work on plumbing the fuel.
#964
Total Cats: 560
Here's a mock up of my fuel pump assembly plumbing.
It is 3/8 PA12 hose, I had to warm it in hot water to stretch over the pump nipple. Yeah, hot stretch pump nipple baby! I am waiting on some small stainless clamps but I got it on the dw300. Feel free to tell me I am nuts.
#966
Total Cats: 560
I want your input!
I think so, it is pure nylon, should be good for gasoline, ethanol, or methanol. I want to be able to run e85 and not worry about these things. PA12 is the factory NB semi flexible fuel line. Stainless clamps and I should be good, obviously there will be the biannual inspection opportunity. Or if I loose fuel pressure it should show up on my wideband. I can just use the green submersible rubber fuel hose but it seems to have it's issues.
Fair warning
Fair warning
#967
I don't fully understand why, but there is lots of hose out there that is rated to carry fuel, but not to be submerged in fuel. I don't know where nylon/PA12 falls in that area. When I did mine, I used Gates submersible fuel line for both parts (which looks like normal hose, it isn't green), because I didn't want to have to take it apart again.
#968
#969
Total Cats: 560
A bunch of us discussed it at the track today, no one seems to really know. The consensus after they learned there are only 6 screws, 6 bolts, 2 quick connects and an electrical connector. I am going to try it and inspect it from time to time with a major inspection in 2 years.
#970
Total Cats: 560
I am soaking a bunch of bits submerged in some homemade e85, about 1 part gas to 5 parts ethanol. Some PA12 line, a zip tie, some shrink wrap, a few different wires and the spiral wire loom that protected the original wires. So far so good.
I am waiting on a -6AN plug because I decided to run my FPR in a slightly different configuration. I will let the parts soak until I get the plug, I didn't want to do all this work and find out the next day my car wouldn't start because the PA12 melted right away.
#971
Total Cats: 560
Wiring done, I am using the factory bulkhead connection with 10 gauge from the battery to just inside the tank wire grommet. Yes, fused, relayed, ect...
Installed the dw300 with PA12 hose, all my soaking bits were unchanged.
I installed the FPR but I have not run the boost reference line yet.
Can I just run a charge pipe reference so it doesn't change my under 100kpa tune? Or should I run an intake manifold reference, and will that reduce pressure to my injectors under vacuum? I think it will, I will most likely upgrade injectors soon, so I don't want to waste a bunch of time tuning off boost right now if I don't need to. Thanks for any thoughts.
I was also driving a bunch this weekend and I am seriously considering the wisdom of adding the boost reference. Simply because the car is basically crazy enough already, obviously it will make sense when I am back at the drag strip.
Having a little trouble with my mobile picture upload, the images seem huge, so I left them out.
#973
Total Cats: 560
So, you are saying I should run the boost reference to my intake manifold for a vacuum/boost reference to shrink my future injectors to idle and cruise better. Then just tune the Flow Force injectors now for that.
I do incorporate AFR table, my car runs exceptionally well, I just wonder what variable fuel pressure is going to do.
#975
Tweaking Enginerd
Total Cats: 371
injectors >1000cc ... big rail pressure... something other than 1:1 FPR rate
edit: lol, in re-reading the post I am a bit confused. We are talking about the reference pressure supplied to a 1:1 fuel pressure regulator correct?
#976
Total Cats: 560
Yes a 1:1 boost reference fuel pressure regulator.
Nothing too extreme, 60psi base and a boost reference to keep the fuel flowing during high boost.
My question is, can I just run a charge pipe reference instead of a manifold reference to keep my fuel pressure at 60 psi, when not in boost?
The only real advantage is that my car would run about the same, only getting richer in boost. I will be swapping injectors soon, which I imagine will change everything, so I will have to revisit my fuel table again, just being lazy. I might as well learn how the small Flow Force injectors work with a 1:1 manifold reference.
#978
Total Cats: 560
Additionally, my fuel pressure will drop to near 50 psi at idle. I can't help but wonder if that will change fuel efficiency and emissions some, not that it really matters. I don't seem to have an issue until my differential injector pressure is below 40 psi. I will run a manifold reference.
