MKTurbo Sale Thread
Old 01-08-2018, 03:20 PM
  #1621
wackbards's Avatar
Total Cats: 266
Not really. It's a dark grey washable filter.
wackbards is offline
Old 01-08-2018, 04:22 PM
  #1622
nigelt's Avatar
Total Cats: 388
https://www.miataturbo.net/build-thr...3/#post1453092
Could be a similar approach on NA, or totally irrelevant.
nigelt is offline
Old 01-08-2018, 04:25 PM
  #1623
Schroedinger's Avatar
Total Cats: 188
^ thanks Nigel. The NA chassis has all the headlight junk up there, but I'm getting some ideas.
Schroedinger is offline
Old 01-08-2018, 07:12 PM
  #1624
levnubhin's Avatar
Total Cats: 12
Default Oil pan tap
Can someone confirm the correct size tap needed for the drain line fitting. Thanks
levnubhin is offline
Old 01-08-2018, 07:23 PM
  #1625
bahurd's Avatar
Total Cats: 316
This is the tap I bought and used when I tapped mine for 3/8NPT. 37/64” stub length; https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
And this is the tap; https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
bahurd is offline
Old 01-08-2018, 07:25 PM
  #1626
levnubhin's Avatar
Total Cats: 12
You the man, thanks!
Old 01-09-2018, 03:54 AM
  #1627
All-round "Good Guy"
Lokiel's Avatar
Total Cats: 259
nigelt, you have a metal intercooler pipe that's radiating a LOT of heat into the Cold Air Box.
Have you considered replacing that section with a silicone hose or wrapping it with a thermal insulator?
Lokiel is offline
Old 01-09-2018, 04:08 AM
  #1628
nigelt's Avatar
Total Cats: 388
That's a good point. Wrapping it would be super easy. Thanks!
nigelt is offline
Old 01-11-2018, 12:53 PM
  #1629
bremaine's Avatar
2 3" 90*'s from silicone intakes trimmed to fit and joined to a K&N filter by a short piece of 3" aluminum pipe.
Originally used a bigger filter, but it wouldn't clear the hood. Quick and dirty math says this filter will support ~200hp before becoming a restriction.
Amazon Amazon
bremaine is offline
Old 01-13-2018, 07:12 PM
  #1630
wackbards's Avatar
Total Cats: 266
FM butterfly brace easily clears both the DP & MP. Not even an issue with my cat.
Old 01-13-2018, 09:08 PM
  #1631
MotoCARR's Avatar
Great thanks for posting!
MotoCARR is offline
Old 01-13-2018, 09:38 PM
  #1632
cpierr03's Avatar
Total Cats: 34
Great news! Thanks for the update!
cpierr03 is offline
Old 01-14-2018, 06:57 PM
  #1633
wackbards's Avatar
Total Cats: 266
The cannon brace is in. It took a bit more doing than the butterfly brace. I had about 1/8" interference between the mid pipe and the removable section of the cannon brace designed to let through the exhaust pipe.
I ended up having to bend 3 exhaust hangers about 1/4" to get good clearance:
1) Midpipe hangar. I just put a floor jack under the hangar and bent it up a little without even removing it. Done.
2) The one hangar welded directly to the muffler. I put the hangar in a vice & malletized it with a 3 lb sledge.
3) The exhaust hangar welded to a custom mounting bracket that comes with your MK kit. I had to bend this one up a bit again using a vice & sledge.
Because the interference was right at the bend in the tail end of the mid pipe, I only had to bend the hangars about 1/4", but now the tightest clearance from the brace is almost 1/2". I couldn't get the exhaust to make contact with the brace by jerking it around, but we'll see how it do while driving.
Old 01-19-2018, 07:20 PM
  #1634
Mia_The_Miata's Avatar
Default Lars still alive?
Has anyone heard from Lars recently (like within the last week or two)? I ordered a kit from him right before Thanksgiving, and he still hasn't gotten all of the parts to me. He still owes me an exhaust manifold and the exhaust hanger. He has not responded to any of my emails after new years break. Has anyone else been able to get a reply out of him within the last week or two? Does anyone have his phone number?
Mia_The_Miata is offline
Old 01-19-2018, 07:50 PM
  #1635
Total Cats: 1,687
Shoot me another email if you are not one of the people I got back to tonight.
shuiend is offline
Old 01-22-2018, 09:42 AM
  #1636
24n46's Avatar
Slave drivers keeping you working through the brutal weather, tsk tsk ... !!
Lars Nicholson
24n46 is offline
Old 01-25-2018, 10:27 PM
  #1637
miguel.sagal92@gmail.com's Avatar
If anyone has the mkturbo with the intercooler set up for the NB1 please post some pics. Having trouble with the cold side. I have power steering and AC.
miguel.sagal92@gmail.com is offline
Old 01-25-2018, 10:45 PM
  #1638
thebigtuna's Avatar
Total Cats: 12
I have a NA but didn't sonofthehill help with how to route them for the NB? Or no? Maybe check out his build thread. Or nigel a couple posts above. His site has pictures of how its run as well, correct?
thebigtuna is offline
Old 01-25-2018, 11:36 PM
  #1639
Total Cats: 560
Lars did not model it after mine because I cut a bunch of sheet metal. Here's my previous cold side, I have made a few slight changes but this is pretty much it.
sonofthehill is offline
Old 01-25-2018, 11:37 PM
  #1640
I was wondering if anyone had Lars IC Kit. Sonofthehill and Nigel have their own custom IC set up.
And I'm sorry I misspoke, I'm having trouble with the hot side. Not the cold side.
Quick Reply: MKTurbo Sale Thread
