11's on the Motor, 9's on the Nitrous
Old 11-07-2017, 02:29 PM
  #421
m2cupcar's Avatar
Total Cats: 372
He made a brief appearance in TonyMontana's thread so I assumed this project was completed and racing.
m2cupcar is offline
Old 11-07-2017, 03:13 PM
  #422
Ryan_G's Avatar
Total Cats: 217
He did make a bracket
Ryan_G is offline
Old 11-07-2017, 05:25 PM
  #423
miata2fast's Avatar
Total Cats: 174
miata2fast is offline
Old 01-06-2018, 05:59 PM
  #424
miata2fast's Avatar
Total Cats: 174
A package showed up this afternoon, so I spent a few hours making lines for the fuel system.
The middle regulator feeds fuel to the nitrous system. I scrapped my original solenoid bracket I made way back in this thread. I will be making a bracket to hold the fuel solenoid as soon as possible.
I also made progress mounting the intank fuel pump, but ran into a small snag. Just need one small fitting to make it work.
I will be back at it tomorrow running more lines.
Old 01-06-2018, 10:10 PM
  #425
Total Cats: 558
Nice work, I love the way you run separate feed lines instead of a T and a 90 like so many multi carb setups. That's how it should be.
sonofthehill is offline
Old 01-07-2018, 12:43 PM
  #426
patsmx5's Avatar
Total Cats: 519
That is looking very nice! Question in case I missed it, but how much nitrous you going to run?
patsmx5 is offline
Old 01-07-2018, 12:50 PM
  #427
Ryan_G's Avatar
Total Cats: 217
S366 shot or bust
Ryan_G is offline
Old 01-07-2018, 12:57 PM
  #428
miata2fast's Avatar
Total Cats: 174
Eventually as much as a BP can injest. Fuel system is capable of anything I throw at it. That is a ways away.
Plan is is two stages. One stage is on poly lines and the 2nd stage on hard lines. The poly lines can flow up to about 175 hp of nitrous. They are much easier to deal with during the learning and tuning stage. Once it’s figured out the 2nd hardline stage will go on the top side of intake. Hard lines can flow much more, but I have no idea how much I can run at one time.
Old 01-07-2018, 01:02 PM
  #429
patsmx5's Avatar
Total Cats: 519
Plan is is two stages. One stage is on poly line and the 2nd stage on hard lines. The Polly lines can flow up to about 175 hp of nitrous. They are much easier to deal with during the learning and tuning stage. Once it’s figured out the 2nd hardline stage will go on the top side of intake.
I suspect you could hit 700whp with nitrous if you tried assuming the rods/pistons could take that. At that point I think the bottom end is going to wear out very quickly from overloading the bearings and not having enough stiffness to prevent distortion.
patsmx5 is offline
Old 01-07-2018, 08:26 PM
  #430
miata2fast's Avatar
Total Cats: 174
I have my doubts I could make that much power on nitrous alone. I think I can get the job done with less than 500 whp.
Old 01-08-2018, 12:48 PM
  #431
Midtenn's Avatar
Total Cats: 275
Fuel line ****
Reminds me I need to finish my re-plumbing of the fuel line project.
Midtenn is offline
Old 01-08-2018, 02:57 PM
  #432
Total Cats: 857
What is your goal?
DNMakinson is offline
Old 01-08-2018, 03:13 PM
  #433
Ryan_G's Avatar
Total Cats: 217
Originally Posted by DNMakinson
What is your goal?
It's literally in the title of the thread.
Ryan_G is offline
Old 01-08-2018, 04:39 PM
  #434
Total Cats: 857
Thx. I was thinking that is what he had already done, but in a previous iteration of the car.
Old 01-08-2018, 08:52 PM
  #435
Total Cats: 3,051
I understand the confusion. His car has just taken several generations to complete.
sixshooter is offline
Old 01-09-2018, 09:52 AM
  #436
m2cupcar's Avatar
Total Cats: 372
mod needs to add "dreaming of" pre-title, and "before retirement" post title.
m2cupcar is offline
Old 01-14-2018, 07:51 AM
  #437
miata2fast's Avatar
Total Cats: 174
Made a little more progress yesterday despite the windy cold weather. I figured out how I am running the aluminum lines, where to mount the extra long filter, and how to modify pump hanger to get the most out of the Aeromotive 340 pump.
For wiring, I will be copying Savington’s electrical bulkhead solution.
Sixshooter, TonyMontana, and RyanG came to lend a hand and for moral support.
Old 01-14-2018, 07:55 AM
  #438
miata2fast's Avatar
Total Cats: 174
The only visual I captured from yesterday.
Old 01-14-2018, 09:47 AM
  #439
Total Cats: 3,051
I took a couple of pics.
Damn, 54 degrees sure is cold! Let's build a fire!
Attached Thumbnails 11's on the Motor, 9's on the Nitrous-20180113_152750.jpg   11's on the Motor, 9's on the Nitrous-20180113_152743.jpg
Old 01-14-2018, 06:24 PM
  #440
miata2fast's Avatar
Total Cats: 174
Got a little more done today. Pretty much used all the parts I could use. Unfortunately, some of the routing ended up different than anticipated, so I ordered more parts, including the EFI Hardware bulkhead connectors.
Quick Reply: 11's on the Motor, 9's on the Nitrous
