EFR6258, 1884cc BP6D, 415whp/343wtq
Old 12-28-2017, 11:39 AM
  #41
patsmx5's Avatar
Total Cats: 519
Can this thread plz not devolve into an oil thread?
Greg, any particular reason you chose not to use shims on the stage 2 pump? AFAIK it comes default with 2 of them to increase oil pressure a bit. Wouldn't that have helped with the VVT at lower rpms?
No, shims would have no affect on pressure below the relief valve pressure.
patsmx5 is offline
Old 12-28-2017, 12:12 PM
  #42
TheCarPassionChannel
1993z32's Avatar
Total Cats: 136
They just raise the max pressure allowed, correct?
1993z32 is offline
Old 12-28-2017, 12:51 PM
  #43
Perhaps you've got loose clearances/tolerances and it takes the pump a tad longer to catch up. Got an oil pressure gauge?
Old 12-28-2017, 01:04 PM
1993z32's Avatar
Total Cats: 136
Just the stock 1.6L setup. I've got an aftermarket OPS but it's not wired up to MS yet.
1993z32 is offline
Old 12-28-2017, 01:24 PM
  #45
Just for reference:
Here's a fully built vvt BP with EFR6758 I recently tuned also running the boundary pump. Has no problem hitting target
Old 12-28-2017, 01:28 PM
  #46
patsmx5's Avatar
Total Cats: 519
Correct. The relief valve is functionally the same as a wastegate on a turbo. Limits max pressure possible.
patsmx5 is offline
Old 12-28-2017, 02:45 PM
  #47
Total Cats: 3,051
^What Pat said. They make no difference below max pressure.
sixshooter is offline
05pearl
Cars for sale/trade
05-17-2017 08:12 AM
Vincentmiata
Dynos and timesheets
05-07-2015 05:31 PM
railz
09-02-2014 03:25 PM
spitefulcheerio
02-24-2014 01:57 PM
Builder
10-27-2012 06:50 PM
Quick Reply: EFR6258, 1884cc BP6D, 415whp/343wtq
