New Miata Junk 2 Intake
Old 10-25-2017, 03:43 PM
  #241
99mx5's Avatar
Total Cats: 524
I posted this in Emilio's Junk thread, but it was deleted for some reason. Reposting here....
SBGarage posted these pics on their Instagram. No word on what it was compared to.
Edit: This was posted previously in this thread, but for clarification:
First plot is on Mazdaspeeder's mazdaspeed compared to the stock manifold. Stock turbo, Adaptronic, ID1000, Begi throttle inlet & downpipe, Enthuza midpipe and exhaust, ebay intercooler, AEM intake.
Second plot is a the skunk2 manifold and TB on a MSM motor compared to a `99 manifold with VICS disabled
Attached Thumbnails New Miata Junk 2 Intake-22709531_131491917556684_6542266507945050112_n.jpg   New Miata Junk 2 Intake-22709330_1941505412732825_1657257261950566400_n.jpg   New Miata Junk 2 Intake-22710917_289003868272763_379944107063115776_n.jpg
99mx5 is offline
Old 10-25-2017, 03:44 PM
  #242
Total Cats: 2,201
First one is the MSM that was referenced earlier in this thread. Second one i believe is a highly questionable non-turbo MSM motor, making hilarious record breaking power with non-functional VICS manifold, then even more hilarious record breaking power with a Skunk2 manifold.
Neither are anything close to scientific. But at least prove that it's not worse.
concealer404 is offline
Old 10-25-2017, 05:05 PM
  #243
Midtenn's Avatar
Total Cats: 275
Likely to reduce confusion later on. One can assume Emilio wants to keep his data separate from those of other companies.
Midtenn is offline
Old 10-25-2017, 06:01 PM
  #244
Total Cats: 3,051
Emilio deletes what Emilio wants in his vendor subforum.
sixshooter is offline
Old 10-25-2017, 06:38 PM
  #245
Full_Tilt_Boogie's Avatar
Total Cats: 407
Cant wait to see a comparison on setups that are not weird as ****.
The first one looks like its got boost control issues, or **** exhaust. The second one... "VICS disabled"... On an intake manifold test? Do they mean it was in one position or the other? One of those terrible gutted manifolds?
I dont need this kind of autism in my life. In for real results.
Full_Tilt_Boogie is offline
Old 10-25-2017, 06:40 PM
  #246
Total Cats: 2,201
I think i was an MSM motor with a VICS manifold, in an NA8, running a BP05 ecu. So yeahhhh.... not only garbage, but those dyno numbers are outrageous.
Old 10-25-2017, 08:19 PM
  #247
ShaZam508's Avatar
They also don't mention what throttle body they used on either set of runs.
ShaZam508 is offline
Old 10-26-2017, 06:31 PM
  #248
lsdlsd88's Avatar
Talking
Originally Posted by Midtenn
I'm just curious when it'll be in the hands of some YouTubers. No offense to Greg (CarPassionalChannel) because he usually presents a solid base of information, but if he puts one on his car, no matter the results, Skunk2's will be flying off the shelf.
this cracked me up because the first part just happened, about the flyin off the shelf, we will see
lsdlsd88 is offline
Old 12-14-2017, 08:07 PM
  #249
Total Cats: 2,387
Necro
FM just published this on their facebook. S2 against a VTCS with the butterflies removed. Bigger percentage gains than we saw but that's to be expected against a VTCS. Same pattern to what we saw N/A against the squaretop.
We saw around 4-5% with the S2 vs sqaretop in a narrow 1000rpm band, minor losses below that. They saw around 9% with the S2 against the VTCS, same losses below. That roughly 5% delta is what we have seen with a squaretop vs the VICS so the trend is as one might predict.
They didn't have a squaretop in the shop so we're sending them one to rerun the test.
Kudo's to the folks at FM for testing and publishing. They have the S2's on their site for sale now too.
.31 SNR
emilio700 is offline
Old 12-14-2017, 09:14 PM
  #250
Zsanz's Avatar
Total Cats: -11
not too shabby.
Wonder if another percent or two will appear when paired with a cnc head.
Zsanz is offline
Old 12-14-2017, 09:38 PM
  #251
viperormiata's Avatar
Total Cats: 283
Interesting.
viperormiata is offline
Old 12-15-2017, 08:53 AM
  #252
Total Cats: 4,102
They really like to use the VTCS dyno plot for which to compare everything. Anything is going to show gains against that thing :P
but it is nice to see a plot on a turboed motor.
extra kudos to you emilio for sending them a flattop!
Braineack is online now
Old 12-15-2017, 09:17 AM
  #253
Midtenn's Avatar
Total Cats: 275
I find it odd that FM never has a flattop laying around for testing. This is the second time I can remember they've done intake manifold testing and had to have a flattop loaned to them.
Midtenn is offline
Old 12-15-2017, 09:31 AM
  #254
Total Cats: 4,102
again, because all gains look better against a VTSC.
Old 12-15-2017, 09:40 AM
  #255
matrussell122's Avatar
Total Cats: 516
Take this with a grain of salt. Found a 3071 with flat top on 20psi and over laid the chart with the one above
Last edited by matrussell122; 12-15-2017 at 10:16 AM. Reason: to show amount of salt
matrussell122 is offline
Old 12-15-2017, 09:54 AM
  #256
Total Cats: 4,102
I'd take that with a grain of unsalted salt.
Old 12-15-2017, 10:02 AM
  #257
Girz0r's Avatar
Total Cats: 324
I wonder when Greg (carhotpassionchan) will post his vvt s2 efr turb dyno results.
Girz0r is offline
Old 12-15-2017, 10:08 AM
  #258
Ignore that comparison. FM is at high elevation and has a different Dyno than everyone else in the world. So pointless comparison. That's also a 2L stroker motor. No need for bench racing. Oh and 190kpa is like 13psi, not 20psi.
Old 12-15-2017, 10:46 AM
  #259
Goingnowherefast's Avatar
Total Cats: 36
Don't think he's been to the dyno yet
Goingnowherefast is offline
Old 12-15-2017, 10:53 AM
  #260
psyber_0ptix's Avatar
What A/R is his efr
psyber_0ptix is offline
