Parting out CSP/TTE/PTE build Penske, rb, wheels, built motor ect
The time has come to help a friend sell off his 99 Miata that he has spend the last 7 years building. He is moving on to bigger and better things.Please call text or email me. DO NOT PM.
516-204-2282 or clarkchristopher01@gmail.com
Complete long block $3,000
Motor has 1,500 miles on it, zero on track just a few autocrosses
Specs: 99 block 10:5:1 Weisco, pistons (I will post the rods when I see his paperwork which was around $3,000)
acl bearings throughout,
arp hardware all around
cometic head gasket
new timing belt water pump ect
Head was stock 3 angle valve job with new seals and Supertech springs retianers
Ecu- 99 Megasquirt for e85 made 145whp on the mods above. $1200
Wheels: 15x8 Konigs with 205-50-15 bridgestone re71r tires $700
Shocks: Penske 8300 with 800-500 springs(will check) external reservoirs $3000
Custom3 piece front sway bar $600
oem 5spd with about 50,000 miles $500
Happy meal clutch same mileage as engine $ 450
Red hardtop $800 (goes when the shell does, local only)
Oem lsd with approx. 50,000 miles $600 4.3 gears
track dog racing radiator $180 shipped
rb header $350 shipped
Megan Racing OE-RS Exhaust meant for MAzdaspeed but I made a pipe to use on a 99-00. $350 shipped.
There are totally odds and ends I am forgetting about. Shoot me a call or text. Everything is for sale. I would like to keep the shell in 1 piece same with electronics.
Thank you
was built off of a running 99 from his car with 47,000 miles for a turbo build that never happened
cometic head gasket
Thank you
