Creampuff's Rotrex
Old 10-17-2017, 07:09 PM
  #41
Blackbird's Avatar
Total Cats: 412
Ended up ordering a couple of them from Rockauto for a whole lot of $4.23 each, should be here in a couple of days.
Plumbing done other than the connection between the IC and the TB which I'm just waiting for the coupler to arrive -
Blackbird is offline
Old 10-17-2017, 07:14 PM
  #42
Blackbird's Avatar
Total Cats: 412
Forgot to add - Rotrex cooler not pictured but it sits side by side with the oil cooler.
Old 10-18-2017, 01:50 PM
  #43
Art
Art's Avatar
Total Cats: -251
Art is offline
Old 10-18-2017, 02:14 PM
Blackbird's Avatar
Total Cats: 412
It has 3 mounts, you can't see the outer one.
Old 10-31-2017, 06:48 PM
  #45
Blackbird's Avatar
Total Cats: 412
Dyno appointment on Thursday, we'll find out what it puts down!
Old 11-01-2017, 12:38 AM
  #46
Mobius's Avatar
Total Cats: 365
Very pretty.
Are you not concerned with the "bottom" of the intercooler chafing against the steel tubing? Or is that accounted for in some way that isn't shown, or is accounted for by items not shown?
I'm going with 255/185 @ 7200 rpm.
Mobius is offline
Old 11-01-2017, 12:59 AM
  #47
Blackbird's Avatar
Total Cats: 412
Thanks!
There are a couple of brackets that you can't see on the IC, so I am not concerned at all.
The rev limit will need to be set at 7K to avoid over spinning the blower with the 75mm pulley.
Old 11-01-2017, 07:20 PM
  #48
k24madness's Avatar
Total Cats: 95
Don't be afraid to push the Rotrex a bit over the limit. The C30-74 is known to be robust. OJ said they over spin em all the time without issues.
Good luck with the dyno. On pump I guess 230-240 on E85 250-260
k24madness is offline
Old 11-01-2017, 08:04 PM
  #49
Blackbird's Avatar
Total Cats: 412
Having some issues getting the car to fire up, dyno session has a 50-50 chance of happening tomorrow, might need to be rescheduled.
Old 11-01-2017, 08:07 PM
  #50
Timing wheel on backwards?
Old 11-01-2017, 08:32 PM
  #51
Blackbird's Avatar
Total Cats: 412
No power to ECU, probably cut the wrong wire somewhere while chopping away at the harness.
  #52
Thats the worst. Good luck.
Old 11-01-2017, 08:33 PM
  #53
Blackbird's Avatar
Total Cats: 412
Thanks, I'll need it to make the dyno tomorrow.
Old 11-01-2017, 09:58 PM
  #54
Blackbird's Avatar
Total Cats: 412
Dyno appointment rescheduled to Saturday.
ECU refuses to speak to laptop, my head is getting tired of being bashed against the wall.
Going home, will get an early start on it tomorrow morning..
Old 11-01-2017, 09:59 PM
  #55
k24madness's Avatar
Total Cats: 95
Cant you just tap and re-feed it with something temporary?
Old 11-01-2017, 10:03 PM
  #56
Blackbird's Avatar
Total Cats: 412
Power restored, but laptop can not connect to ECU.
Old 11-01-2017, 10:58 PM
  #57
oregonmon's Avatar
Total Cats: 12
Worth a shot?
oregonmon is offline
Old 11-01-2017, 11:00 PM
  #58
Mobius's Avatar
Total Cats: 365
Ryan, you have to read the whole thread before responding ...
Mobius is offline
Old 11-01-2017, 11:02 PM
  #59
oregonmon's Avatar
Total Cats: 12
Curious of dyno too as I'm running C30-74 with 75mm, we pushed it to 7200rpm but I understand not wanting to damage the Rotrex. I heard the 75mm should make more power on a VVT than mine did at 234/1845ish. Good luck!
Old 11-01-2017, 11:11 PM
  #60
Blackbird's Avatar
Total Cats: 412
Originally Posted by oregonmon
Worth a shot?
Have not touched it since the engine last ran.
