Old 09-12-2017, 12:16 PM
  #10361
turbofan's Avatar
Total Cats: 1,021
@yank comes through again!
Ed@949Racing/Supermiata
www.949racing.com
www.supermiata.com
turbofan is offline
Old 09-12-2017, 12:20 PM
  #10362
rleete's Avatar
Total Cats: 1,277
I think you're going about this all wrong. If the smoke is from burning oil, you need to eliminate the source. Plug the oil line to the turbo, or better yet, drain all the oil from the engine. No more smoke!
rleete is offline
Old 09-12-2017, 03:48 PM
  #10363
Total Cats: 3,075
Hmm. First option is too much trouble for me.
Drain the oil.
sixshooter is offline
Old 09-12-2017, 04:08 PM
  #10364
Steve Dallas's Avatar
Total Cats: 70
You are missing an opportunity here. Replace the oil with water to steam clean allthethings as it runs. The trubo and engine will never get dirty inside!
Steve Dallas is offline
Old 09-13-2017, 02:50 AM
  #10365
Art
Art's Avatar
Total Cats: -251
Art is offline
Old 09-13-2017, 08:50 AM
  #10366
SadFab CEO
hi_im_sean's Avatar
Total Cats: 1,142
It happens after sitting still idling for 5 mins.
hi_im_sean is offline
Old 09-13-2017, 09:01 AM
  #10367
It's pretty much straight up and down.
Old 09-13-2017, 11:09 AM
  #10368
An octopus attacked my engine bay...
Drain line. Push-lok hose to an AN4-AN10 adapter
Routed
Reused my old feed line for regulator to turbo.
One line left to make to connect block to regulator.
I really hope this does it, but I'm also still doubting its the turbo. Last time it smoked was after idling for 5 minutes, in which time it should have been able to drain out.
Fingers crossed.
Old 09-13-2017, 04:16 PM
  #10369
Mobius's Avatar
Total Cats: 365
I still have my header and downpipe if you need to borrow them.
Mobius is offline
Old 09-13-2017, 04:24 PM
  #10370
Thanks. I should be able to piece something together. I actually found an NB1 manifold in my backyard yesterday. Probably have a downpipe in the blackberries there too.
Old 09-13-2017, 05:00 PM
  #10371
Total Cats: 1,685
Pull header off nb2 that's sitting there. Use your welder to connect it to your 3" exhaust.
shuiend is offline
Old 09-13-2017, 05:13 PM
  #10372
Pass.
Old 09-13-2017, 05:14 PM
  #10373
Total Cats: 2,201
I think your problem is that there just isn't enough stuff strewn around your engine bay yet. Up your game. Smoke goes away.
concealer404 is offline
Old 09-13-2017, 05:30 PM
  #10374
raise the boost, the extra pressure will seal everything
Old 09-13-2017, 05:32 PM
  #10375
Total Cats: 1,900
Remove PCV and vent intake manifold directly into the block. Extra pressure will help the rings and put back-pressure on the seals to help keep the oil in the pan.
EO2K is offline
Old 09-13-2017, 05:34 PM
  #10376
or even better vent it into the exhaust manifold and gain 5,000,000hp from the turbine
Old 09-13-2017, 05:36 PM
  #10377
SadFab CEO
hi_im_sean's Avatar
Total Cats: 1,142
Yea but then he'll strip 3rd.
  #10378
Total Cats: 1,900
Yeah, but if you vent it post turbine it'll help cool the exhaust. That will counter the added heat from the turbo and make the exhaust gasses contract and pressure will drop. I bet you gain 300RPM of spool as it literally sucks the exhaust through the turbine.
EO2K is offline
Old 09-13-2017, 05:45 PM
  #10379
Old 09-13-2017, 06:20 PM
  #10380
it's like E-Cool, but even cooler
