Old 09-11-2017, 11:46 PM
  #10341
Total Cats: 1,184
You just need a bigger/higher drain.
curly is offline
Old 09-11-2017, 11:48 PM
  #10342
It's a .6" or bigger oil drain. The whole way through.
I have all the parts for the oil regulator. Just sick of throwing money and time at the car.
#partout?
Old 09-11-2017, 11:53 PM
  #10343
Total Cats: 1,900
You sound like me
EO2K is offline
Old 09-11-2017, 11:58 PM
  #10344
turbofan's Avatar
Total Cats: 1,021
AIDAN! sorry dude. One more go, the regulator. Come on!
turbofan is offline
Old 09-12-2017, 12:05 AM
  #10345
Total Cats: 558
Sorry to hear it man. Don't give up tho, we are all looking forward to seeing you.
sonofthehill is offline
Old 09-12-2017, 12:51 AM
  #10346
Mocked it up. Should work somewhat well. Can always come back and clean it up. 4an line is dirt cheap.
Smoking cars don't get the garage....
Old 09-12-2017, 12:56 AM
  #10347
icantlearn's Avatar
Total Cats: 117
Do you mind me asking what you paid for the SV650? If you do mind just tell me to go away and kill myself.
icantlearn is offline
Old 09-12-2017, 12:57 AM
  #10348
It was $1000. 2007. 36k miles.
Old 09-12-2017, 12:58 AM
  #10349
icantlearn's Avatar
Total Cats: 117
That is a good deal. nice find
Old 09-12-2017, 01:25 AM
  #10350
thumpetto007's Avatar
Total Cats: -117
Have you tried reinstalling the stock exhaust manifold to eliminate the turbo and lines as variables?
not sure if that would really help, just thought i would throw the idea your way.
thumpetto007 is offline
Old 09-12-2017, 01:32 AM
  #10351
I don't actually have a stock manifold. I may try that sometime though. I can probably get my hands on one.
Old 09-12-2017, 02:29 AM
  #10352
Scaxx's Avatar
Total Cats: 884
No dude! Don't do it! Who am I gonna mob down to MRLS with otherwise?
Scaxx is offline
Old 09-12-2017, 02:37 AM
  #10353
Der_Idiot's Avatar
Total Cats: 28
IDK where to put the return on my pan for another fitting bung but the TS regulator will be going in my car as well. The BW tech advised that would work better and have a more consistent pressure than the 1.6mm restrictor. If I was close I'd bring some beer and help you knock it out.
Der_Idiot is offline
Old 09-12-2017, 02:53 AM
  #10354
I already have an extra 10AN bung that was used for a experimental block vent (hint: it failed horribly, and overflowed real quick a'la @Leafy), but will work perfectly for the drain. Already have an AN10-AN4 reducer. Some pushlock AN4 hose for the drain (because cheaper) and some more braided line for the feed. Hopefully I have enough feed line, otherwise I'll need to make an emergency trip over to PRE again.
Hoping to find some 4AN fire sleeve locally tomorrow, without driving too far at least. Need to re-wrap whatever new lines I make.
Old 09-12-2017, 10:15 AM
  #10355
Bannisheded
fivehundredton's Avatar
Total Cats: -1
I know you've got to be frustrated. This ^ and, at this point it, might be faster to use process of elimination.1) exhaust manifold, 2) exhaust manifold/head.
fivehundredton is offline
Old 09-12-2017, 10:19 AM
  #10356
Total Cats: 1,184
Oil filter service has all the fittings and fire sleeve your heart desires.
curly is offline
  #10357
The car is still drive able as is. Doing that would take longer than I have. I'll likely do it over the winter.
Old 09-12-2017, 10:20 AM
  #10358
Thanks. Knew they had fittings, Hadn't asked them for fire sleeve. I'll head there at lunch today.
Old 09-12-2017, 10:59 AM
  #10359
dleavitt's Avatar
Total Cats: 223
I have one you can have if you want. Not going to be up to Portland until the 22nd/23rd though.
dleavitt is offline
Old 09-12-2017, 11:44 AM
  #10360
Found some more fittings, I think I can reuse my block to turbo oil like, and route it up to the pressure regulator. Then send the feed for the pressure regulator around the heat shield and down the dipstick tube.
Again, big thanks to yank for loaning me the pressure regulator. Being able to test without throwing more money at it right now is a godsend.
