Old 08-22-2017, 06:23 PM
  #1041
I used dual port Turbosmart with a 4 port mac valve. cannot help
Old 08-22-2017, 06:25 PM
  #1042
psyber_0ptix's Avatar
So if I buy a turbosmart dual port, and a Mac 4port, can you halp? lol
psyber_0ptix is offline
Old 08-22-2017, 06:26 PM
  #1043
Dunno. My boost control sux right now. I'm having trouble getting a good balance. If I tune it for a pull starting in 4th at like 2500rpm and get a good curve, it overboosts really hard on quick throttle application. And if I tune it for quick throttle it overboosts when doing a long pull. So I've got some work to do still. Havent had a lot of time/motivation.
Old 08-22-2017, 06:27 PM
  #1044
or let's go bug @Savington because I think he's still on the OG EFR bcs in his car
Old 08-22-2017, 06:34 PM
  #1045
Lexzar's Avatar
Total Cats: 41
Originally Posted by 18psi
or let's go bug Savington because I think he's still on the OG EFR bcs in his car
How many miata owners does it take to set up EFR boost control?
Many. Many miata owners. I'll hopefully have time tonight to mess with things and since I'm not on "poop" levels of boost, it may be easier to test
Lexzar is offline
Old 08-22-2017, 06:37 PM
  #1046
I started making a new thread in the MS section specifically about EFR bcs and MS3 1.4.0 boost control.
Then I accidentally closed the page. I'll probably make it tonight
I think its getting common enough for us to develop a proper approach.
Old 08-22-2017, 06:40 PM
  #1047
if I had an EFR car in front of me (and not over da intrawebz) I'd write up a how-to
Old 08-22-2017, 06:59 PM
  #1048
If lower is better, there's a 20Hz and 15Hz options under High Frequency Range
19.5Hz and 15.6Hz under Low Frequency Range
Any rhyme or reason to such close operating frequencies under two different advertised ranges?
Old 08-22-2017, 07:36 PM
  #1049
For sake of documentation, here is where preload is currently sitting. If it's more or less about boost control, I may back it off a turn.
Old 08-22-2017, 11:19 PM
  #1050
Total Cats: 2,103
That is a shitload of preload.
Savington is offline
Old 08-22-2017, 11:34 PM
  #1051
Before this all started, it was only showing a thread. I'll back it back out tomorrow, but am still stumped on the oscillating.
Would it make any sense to pull the line off the wastegate to see if it flutters without the EBC?
Old 08-23-2017, 02:02 PM
  #1052
shlammed's Avatar
Total Cats: 51
I would suspect its because open loop boost control.
Being that you have your open loop table pretty close, going to closed loop should remedy your problems. That said, I don't have experience with MS boost control and how it references different tables. That's the whole purpose of going closed loop though (to remove oscillations and change in boost levels from environmental fluctuations and change in load)
Spend some time and go closed loop.
shlammed is offline
Old 08-23-2017, 02:20 PM
  #1053
Closed loop is to handle changing environments. You should be able to get stable boost control with open loop at a specific temperature, etc. If you have unstable boost control its going to be hard for closed loop to fix that, it will constantly be fighting itself.
We need logs. Post them plz.
Old 08-23-2017, 02:43 PM
  #1054
Here are some. Sometimes D.C. area is not conducive to lengthy stretches of clear road. Or speed cameras, or belt way cameras, or EZPass, or State Troopers, or gradual right mini vans.
File Type: msl
File Type: msl
File Type: msl
Old 08-23-2017, 02:51 PM
  #1055
Total Cats: 1,685
What he is trying to say is that anything over 80mph means a real possibility of pound me in the *** prison. VA has some great gun laws, not so much driving laws.
shuiend is offline
Old 08-23-2017, 02:55 PM
  #1056
yes. try it.
nope.
I suggest that you provide input/suggestions from experience rather than just random guesses (no offense, but we're actually trying to diagnose an issue here)
Correct. This has nothing to do with open or closed loop boost control. also his is set up such that the flex fuel blending also blends boost.
He hits his target boost numbers, and he even holds them til redline.
There's just that jitteriness up top that we're trying to diagnose here. Pre-load seems to be ruled out.
Old 08-23-2017, 03:46 PM
  #1057
Should that e85 table have 85/100% duty cycle that high in the last two columns? I think that was last ditch efforts at PTuning to get it to peak over 28psi, but it never did. Should that be reduced or tapered otherwise?
Old 08-23-2017, 03:55 PM
  #1058
I don't think theres anything wrong with those duty cycles, at least for now until we figure out why it's not going any higher, but we'll certainly re-visit that table once we move on to e85 tuning.
Old 08-23-2017, 03:57 PM
  #1059
Will unplug and try to take a log tonight on wastegate only.
Old 08-23-2017, 04:23 PM
  #1060
yossi126's Avatar
Total Cats: -14
Reduce solenoid frequency to get higher duties.
yossi126 is offline
Quick Reply: Turbo Smurfette - Build in progress (slow)
