300hp to 400hp upgrade
#84
Head got surfaced and a rebuild, block machined to 83.5mm and surfaced, all engine parts got acid cleaned.
The crank is one mil smaller then spec - a decision will be made on sunday and the assembly.
Got the oil cooler adapter, oil pressure sensor and all the rest.
What ring gap should I go for ? it is a street car.
The rings manual says 0.050" I saw people go 0.043"... - aiming at 20-25psi of boost.
At what gap do they come from the manufacture ?
#98
Dropped my heart there with the backward joke...
I'll clean the head as much as I can and I'll shorten the oil filer threads there.
Next thing is getting the ARP2000 replacement for the con rod bolt that I broke with a bad torque wrench.
A double torque routine for head studs is a must ?
Thanks
Thanks
