Old 08-14-2017, 11:55 AM
  #1021
Ok now I understand it a bit better. That's kind of weird because the various other Skunk2 TB equipped cars I've tuned did not have this problem.
Yeah I noticed idle advance was on too, I haven't needed to use it before so when I re-do your closed loop idle settings with the new numbers I'll disable it.
Old 08-14-2017, 12:24 PM
  #1022
Stuck tb is a skunk2 thing. Seems a lot of the new ones have the issue. @curly fixed it with a new hole.
Old 08-14-2017, 12:30 PM
  #1023
psyber_0ptix's Avatar
Edit: disregard, this is just to increase spring tension, got it.
psyber_0ptix is offline
Old 08-14-2017, 08:51 PM
  #1024
miataman04's Avatar
So you got it sorted out?
miataman04 is offline
Old 08-15-2017, 02:42 AM
  #1025
So the throttle itself, without adjusting the stop, wouldn't close on it's own completely unless there was momentum behind it closing. If I where lifting slowly and coasted, it would sit at 1% TPS and high idle. If I where to jab the throttle, it would close completely. I added a spring to help keep the throttle shut, but even that isn't helping out too much now. So just to try, I adjusted the stop to the point where it barely touched and adjusted the bypass screw in to help drop the high idle. After all is said and done, it idles at 1000 without any help of the bypass.
Trying to figure out the idle with this Skunk2 throttle has been an ongoing challenge. Working around it's deficiency getting "sticky" when closing or little adjustability thereafter, I'm not certain other than trying a heaver spring to keep the throttle shut. I want to replace the throttle stop screw at some point for longevity and easier adjustment than the oddball allen key I have to carry, will try to set things back and report in.
As of current idle valve test has a range between 3 and 55%, but I'm not sure if some of that fluctuation is just idle bouncing around few hundred rpm's and the fans kicking on and off.
Also, I don't know if I used advance at Idle before, but it's enabled when I got it back from PTuning. Should this be disabled during idle test?
sent VladiTune revision #3
Old 08-15-2017, 08:32 AM
  #1026
The idle, not yet. I don't have facility to remove the cam on the Skunk2 to redrill to tension the spring tighter. Will pursue this as best it can be until winter mode allows me to start tearing things off the car for funsies.
Received. Will work on it tomorrow, the only sunny day this week.
Old 08-22-2017, 01:03 PM
  #1027
I've been meaning to ask: do you notice the boost oscillation on the boost gauge?
Old 08-22-2017, 01:27 PM
  #1028
@18psi, I'm usually white knuckle gripping the wheel with my eyelids flapping around trying to not poop myself.
I'll check next time.
Boost gauge is connected via long vacuum hose, so it may be slightly damped compared to the inches of hose on the AEM Map sensor.
For testing purposes, should I enable and use the onboard MAP?
Old 08-22-2017, 01:37 PM
  #1029
lol with that much power, I would be too.
with the way it's spiking though, you should still see the fluctuations on the gauge: it goes from 19-20 to 16 and back up, that's a pretty large swing.
I'm just trying to figure out if I should smooth/filter the signal from the map sensor because the signal is noisy, or keep pursuing this jigsaw boost issue.
Old 08-22-2017, 01:46 PM
  #1030
The cable shielding is grounded near the throttle body near where the sensor itself is mounted. Do you suppose it's hitting some sort of resonance at high RPM for it to read funny in the pressure transducer? I can always try extending and relocating the sensor to somewhere with less vibration. I don't know if it's signal noise without zooming into the log, but it I'll check the boost gauge first.
Old 08-22-2017, 01:53 PM
  #1031
yeah I'm starting to suspect resonance or turbulence or something. because your map signal is rock solid otherwise.
heck, I even suspected turbulence way back before we even started troubleshooting the wg arm. it's just so odd that it only happens up top
Old 08-22-2017, 02:01 PM
  #1032
What if we used the onboard MAP since it's only pushing ~20 psi and use the AEM as barometric pressure. You think it'll show wild oscillation despite the slight under hood pressure changes? Purely for observation.
Moving the sensor is still a non issue and may be easier to try out without having to dig into settings. I'll see what I can do this week.
Old 08-22-2017, 02:08 PM
  #1033
Whichever is easier for you to try (and then reverse if need be).
Just so we know if it's a legit
Old 08-22-2017, 04:19 PM
  #1034
I just got this idea: dug up G's 6258 dyno plot.
look at the boost plot, look familiar?
notice also that the one that jigsaw'd the most was the lowest boost setting. this is also on the internal RevMS3 map sensor.
Old 08-22-2017, 04:28 PM
  #1035
So same symptoms, different map sensors. Could it be board electronics or the EBC frequency/PID?
G => RyanG?
Old 08-22-2017, 04:52 PM
  #1036
Ryan_G's Avatar
Total Cats: 217
G => RyanG?
Not me. I never had a 6258....or a properly functioning car with an EFR
Ryan_G is offline
Old 08-22-2017, 04:55 PM
  #1037
G => RyanG?
Gordon aka EO2K
My guess is EBC frequency. He's also in open loop like you. Neither of you are running closed loop, so no PID
Old 08-22-2017, 04:58 PM
  #1038
For reference till I get home:
Old 08-22-2017, 06:18 PM
  #1039
Ok, so currently boost settings are:
Pump93
E85
Would switching to mid frequency range at 30Hz help stabilize the oscillations at upper pressures? Would this require higher duty to reach the same targets since it's working marginally faster?
Old 08-22-2017, 06:20 PM
  #1040
In my experience lower is betterer. Changing it more often makes it almost harder to tune.
Old 08-22-2017, 06:22 PM
This message has been deleted by 18psi.
Quick Reply: Turbo Smurfette - Build in progress (slow)
