Adventures in PTE/TTE
#1042
Can always ask for a TTE* reclass and see how light Greg will let you get, but seems like you should be able to make more than 120whp. My buddy runs a junkyard motor in his 99 points build and it makes 130whp with stock ECU on dynojet. Can't remember if he has a header (I think so), but he's using a janky installed CXRacing intake (it's for an NA) and SM exhaust.
#1043
What are peoples thoughts on the Mazdaspeed in TTE? It doesn't seem like it's handicapped enough to make up for having Torsen, decent enough suspension, and an extra ~50hp. I was running against one yesterday, that had a turbo-back exhaust, CAI, and Toyo RR's. I can't imagine it was scaling north of 2600lbs either... I could drive circles around the guy through the tight sections of the course, but he put multiple lengths on me every time the track went straight. No joke, he put 15+ lengths on me down the front straight after I exited final corned 4-5mph faster getting right to his bumper on exit.
Now, I'll admit my car is FAR from prepped towards TTE success, but this just doesn't seem right.
#1044
The real advantage of a turbo motor in a HP limited class is you can do some trickery with the boost curve to make that max HP at any RPM so you end up with more power under the curve than a similarly rated N/A motor. Just think of having that grunt off the corner that you have at 6500rpm but at 4500rpm...... There's never the wrong gear.
#1045
What are peoples thoughts on the Mazdaspeed in TTE? It doesn't seem like it's handicapped enough to make up for having Torsen, decent enough suspension, and an extra ~50hp. I was running one yesterday, that had a turbo-back exhaust, CAI, and Toyo RR's. I can't imagine it was scaling north of 2600lbs either... I could drive circles around the guy through the tight sections of the course, but he put multiple lengths on me every time the track went straight. No joke, he put 15+ lengths on me down the front straight after I exited final corned 4-5mph faster getting right to his bumper on exit.
For starters:
Miata MX-5 turbo ('04-'05) TTE** 2600
Miata 1.8L ('99-'00) TTE 2410
Miata 1.8L VVT ('01-'05) TTE* 2400
Then add the turbo penalty:
FORCED INDUCTION VEHICLES will add an additional five (+5) points to the total number of Modification Points to determine the final competition class. (Forced induction vehicles that have been classed or re-classed by the National TT Director based on Dyno testing are exempt from this additional five (+5) point assessment.)
You can get back 7 points by running a 205mm, since the TTE base tire size is 235mm.
Now you're a stock MSM with +12 points in TTE.
The easy button Hoosier R7 is a 10 point mod, so that's out. Your only options for tires are:
6) The following DOT-approved R-compound tires: Toyo Proxes RR, Hankook TD, Pirelli Trofeo R +5
7) The following DOT-approved tires and those R-compound tires with a UTQG treadwear rating over 40: BFG Rival S, Bridgestone RE071-R, Maxxis RC-1 (examples: Kumho V700, Kumho V720, Michelin Pilot Sport Cup & MPS Cup 2, Nitto NT01, Pirelli PZero Corsa, Toyo R888, Toyo RA-1, Yokahama A048, etc.) +4
8) DOT-approved (non-R-compound) tires with a UTQG treadwear rating of 120-200 (examples: BFG g-Force Rival, Toyo R1R, Dunlop Direzza Sport Z1 Star Spec, Bridgestone Potenza RE070, Kumho Ecsta XS, Yokohama Advan A046 & Neova AD08, Hankook R-S3) +2
#1046
^ When I said I was running, I meant I was running against. I was in a 94' base model. If I am reading your post correctly, this MSM should have been DQ'd as he would have blown through points with the addition of the exhaust and intake work?
Do we really think a near stock MSM is weighing 2600+ pounds? Seems extra porky.
#1047
*Minimum Competition Weight is the vehicle’s lightest weight with the driver and safety gear, during any competition session.
Another reason I HATE this points BS. Just make it TT6 already and go off weight : power!
I would also think he would be over:
8.1.2 Minimum “Adjusted Weight/Power Ratios” for each Class
Each competition class has been assigned a minimum “Adjusted Weight/Power Ratio”. Regardless of how many points a car has, or which base class it begins in, it may not exceed the minimum “Adjusted Weight/Power Ratio” for its competition class. Any vehicle found competing with an “Adjusted Weight/Power Ratio” less than the minimum level assigned below will be disqualified, and additional penalties (Section 14) may be assessed.
TTE 16.50:1
TTE 16.50:1
#1048
Total Cats: 319
MSM can't be competitive in PTE/TTE, imo. Too heavy and not enough points for crucial items.
#1052
Are there any well done E* base class or points Miatas there though? It's so hard to tell if things are competitive at regional events because of low turnout or the whole field could be underprepped. I've completely cleaned house locally for years but I know I'd get destroyed in a heartbeat at nationals.
I feel like that setup still wouldn't match a reclass Miata since same tires and same power to weight but Miata has much better weight to contact patch ratio. Would definitely get beat by a proper points Miata though.
#1055
The previous track record was held by Jason Kohler's Miata which was a well built car with a driver to match. The Great Lakes region has two main Miata camps, points builds and straight E reclass with wings and air dams. Gingerman was the first event for Neuman with the new setup, he previously was not running the wing and splitter at 2680lbs.. August Mid Ohio will have at least 3 points build Miatas along with 4 or 5 E reclass full aero Miatas, should be a good time.
#1057
With the announcement that PTE is here to stay for at least 1 more year, I've decided to re-build my crashed 99. Bought a clean NB tub this past weekend and will be taking it to Mcmahan for another cage in the next few weeks. As busy as I've been with work lately, I doubt I'll have it ready for any races in 2017. Looking forward to PTE 2018!
#1058
There are three regularly run NB1 points cars. They're all on stock ecus and running squaretops and Hoosiers. I'm one of them. Neuman has the best car (prep) out of the ones who normally show. He's a damn good driver too. He's much improved his racecraft from last year.
Yeah kind of what I thought. Any points build without a standalone, not on e85 and without a zero points motor has a long ways to go to be competitive.
I wish that ST5/6 would have come out this year so that NA chassis will be on a level playing field.
#1059
I'm not sure I could match Kohler's time even if I finish my car on a NB2 PTE* build. Best I've done @ VIR is 2:17.2 on a pretty perfect day. He did a 2:14.9 at ECC. I'm only 2390lbs, would need to throw a cam on the motor to get the power to increase the weight, would also need a better LSD as well as 0 point front end aero. There is a bit more chassis setup work to do, and I only run on SM7s while I have the points for R7s. All in all, I don't think that's 2+s of improvements.
