1994, GT2554r, Low Numbers?
Been using the car right now for a couple thousand miles and several autocross's on the current tune.
Had a baseline dyno pull done and I feel like my numbers are very low.
The dyno operator said it was probably due to the ignition timing.
AFR's were rich about 10.9 all the way through in boost on dyno and from wideband. (I will lean the tune up a bit.)
The tune is all road tuning done with Tunerstudios.
Attached is the current tune on the car and the dyno results.
Setup:
1994 Miata 1.8L Stock Engine
FM2 Kit
FM Intercooler
3" FM Turbo Exhaust w/Cat.
GT2554r @ 14psi peak (3700ish rpm) then down to 12psi all the way to redline
Grimspeed MBC
Innovate MTX-L Wideband O2
RX8 Yellow Top Injectors
MS3PNP
Stock ignition System
93 Octane
5 Speed
Results:
177whp in 4th gear
169whp in 3rd Gear (Dyno Operator chose this)
Outside Temp: 92F @ 60% Humidity
Beltsville, MD
Infinite Speed and Performance
Any suggestions on whats up?
Setup:
FM2 Kit
FM Intercooler
Grimspeed MBC
MS3PNP
93 Octane
5 Speed
Results:
177whp in 4th gear
Beltsville, MD
![Name: 1sQpH6N.jpg
Size: 97.8 KB](https://www.miataturbo.net/attachments/dynos-timesheets-21/229898d1683052138-1994-gt2554r-low-numbers-1sqph6n.jpg)
I made a thread exactly like this with the first miata I turbo'd. Someone told me to advance my timing 4 degrees in boost and report back. I load a new tune, pull out of my neighborhood, roll in the gas, and my clutch lets go. You get some serious power from properly tuned timing, and it looks to me like you've got plenty of safety built into that tune timing wise.
Somewhere out there is a "give me all your timings" thread probably from pre-2010 that had some great info and timing tables, but I can't find it now. I dug up an old dyno run I made on 93 octane, bigger turbo than you, and higher compression (nb pistons): https://www.miataturbo.net/dynos-tim...0-19psi-62855/
I'm sure you can dig up others on the site to get some input on how far advanced you can safely go. Datalogging a pull in virtual dyno, then another with +2 degrees of timing from you're current tune would probably be a good start to see what power does. I suspect you'll be plesantly surprised.
*I assume no responsibility for vented blocks as a result of my terrible advise, but I've yet to blow my own motor*
Check timing (cam and ignition), Check compression, Check exhaust restriction, Check for boost leaks.
As in:
Were lazy and didn't time your MS3 with a timing light?
Did you recently do a "preventative timing belt job"
Did you nuke your ringlands from running too much nos, and now mad scientist jessie and I have to tear it down and replace those piston rings you just fried?
Did you nuke your cat from running that ridiculously rich AFR? My car shoots 2 foot flames if it gets that rich. Damn I need a flex fuel sensor.
Did you check for any number of places it could leak after your boost is being measured?
As in:
Not since the dyno baseline.
Before I turbo'd, it had great numbers across all 4 cylinders.
Haven't had any indication of loss of compression. (No smoke from exhaust,No oil burning whatsoever, Good idle/ Vaccuum Readings.)
Base timing was set correctly when I installed the MS3.
No Cat on the car and no flames either from what I am able to see.
Boost is measured off a nipple on the intake manifold.
Yea, I figured the timing map wasn't that good after I saw the numbers it put down.
The dyno operator also said the timing was most likely the issue by the shape of the graph.
Is the left timing map your timing map?
After reading the Injector Timing Table thread and it seems that to be able to properly adjust it will need to be done while on a dyno.
With its current default setting how much does it effect the performance?
Car surprisingly runs well I guess driveability wise and its done trips from Annapolis to Virginia and back with an autocross in between without a problem.
Currently picked up a used netbook (two laptops have gone down already) that I have been able to tweak the tune quite a bit (basically everything) and the butt dyno feels a bit better.
I can't post the new tune file right now since the network I am on won't allow for the netbook to be connected to it.
As in:
As in:
Total Cats: 4,102
you're telling it to finish the injection at 90° -- that's halfway through the intake stroke. That means there may not even be fuel available when the intake starts opening, depending on how long your squirts are.
I can't view MSQs at work, but if brain says it is a wreck, well, there is your problem.
Last edited by chicksdigmiatas; 07-25-2017 at 11:43 AM. Reason: Removed double quote
I'll definitely redo that. Could this possibly be why the current ignition timing map hasn't caused any driveability issues? Just got lucky?
Found out I'll be getting a lot of free time this Friday so I'm going to try to schedule some dyno time so I can properly set things up.
Hopefully my clutch foot heals in time (hurt it last night...) so I can drive over there.
I'll be sure to post the tune/results.
Thanks for the quick responses yall.
You could have gotten lucky for many reasons, but I think the safest thing to do is run ones of brain's timing and injector maps after rechecking base timing.
You may even just want to start from scratch using one of his maps because they're pretty conservative while being a solid starting point. You'll likely need to change fueling etc anyway, so might as well start fresh and use VEAL again for a drive hitting the different loads and then see where that puts you. It shouldn't take too long and it will be far less frustrating than trying to figure out why some random map you found isn't working...
Do as I say, not as I do.
Tell me again exactly where what I did was wrong? He found a random map and he's running it. Brains maps are a far better place to start.
But yeah, I should probably take my own advice sometimes lol.
Well... Can't you do that?
Total Cats: 558
You repeat what people have said to you for your specific situation, but it doesn't always pertain to the person you are repeating it to. Because you don't have the basic understanding, this may fly and get you a degree in an academic setting. Not around here.
One is a self congratulatory circle jerk, where everyone congratulates themselves for proving others wrong, but more rarely for proving themselves right.
The other calls out those that are lazy, but endeavors to teach those that make an effort and stick to it even after discouraging results.
Many of you seem to despise the former. Unfortunately it seems like many of you have more in common with it than you think.
I tend to be self deprecating because I don't have anything close to an ego about anything I do. I do draw a line between insults and humor though. Do with that information what you will.
Ps: your comment regarding academic training belies your lack of understanding on how the sciences are taught and tested. Just and fyi.
