Old 07-09-2017, 12:35 AM
  #10161
Total Cats: 558
Very nice!
sonofthehill is offline
Old 07-09-2017, 03:05 AM
  #10162
Scaxx's Avatar
Total Cats: 884
Powwwwwwer!!!!
****, I just realized we didn't hang out fourth of july! Did you end up coming up to Seattle?
Scaxx is offline
Old 07-09-2017, 03:16 AM
  #10163
Yeah but I didn't bring the Miata. Brought the dog instead.
Old 07-09-2017, 11:37 AM
  #10164
Scaxx's Avatar
Total Cats: 884
Darn, maybe next time. Hopefully Katy and I'll be coming down to Oregon this summer, ****'s been way busier than I predicted. Then again it always is.
Scaxx is offline
Old 07-09-2017, 01:00 PM
  #10165
turbofan's Avatar
Total Cats: 1,021
MRLS! MRLS!
turbofan is offline
Old 07-11-2017, 10:46 PM
  #10166
Total Cats: 104
Looks like torque went to infinity just after 5k rpm.
Leafy is offline
Old 07-11-2017, 10:51 PM
  #10167
Spun tires on the dyno. duh.
kidding. lost tach right there. We tried another run and lost it in the same place. Will use an optical signal if we go back with e85.
Old 07-12-2017, 12:46 AM
  #10168
Old 07-12-2017, 01:25 AM
  #10169
icantlearn's Avatar
Total Cats: 117
MMMMMmmmmm. I love a nice clean dash.
icantlearn is offline
Old 07-12-2017, 10:13 AM
  #10170
shlammed's Avatar
Total Cats: 51
nice power. new IG follower.
Now that the big work is done, you can wash your car inside and out (not that Im one to talk)
shlammed is offline
Old 07-12-2017, 10:15 AM
  #10171
I've actually never cleaned the inside of the car. Coming up on 3.5yrs of ownership.
Old 07-12-2017, 10:33 AM
  #10172
mreakus's Avatar
Total Cats: 15
I just threw up in my mouth a little bit.
mreakus is offline
Old 07-12-2017, 10:37 AM
  #10173
Originally Posted by Chiburbian
Index:
6758 is purchased: https://www.miataturbo.net/build-thr...6/#post1351579
EFR Arrives: https://www.miataturbo.net/build-thr...1/#post1352925
(adding to this as I catch up on build thread)
I'll add this to the first post if you update it more.
Old 07-12-2017, 10:38 AM
  #10174
Total Cats: 2,201
Let's hang out.
concealer404 is offline
Old 07-12-2017, 02:16 PM
  #10175
mreakus's Avatar
Total Cats: 15
Let's hang out.
​​​​​​​Hands in -
mreakus is offline
Old 07-12-2017, 02:57 PM
  #10176
Chiburbian's Avatar
Total Cats: 202
I'll try and work on it one of these evenings soon.
Chiburbian is offline
Old 07-14-2017, 10:56 AM
  #10177
Spent a while on the phone with Mike from Southeast Power Systems. Good guy. Awesome understanding of turbo stuff.
We think my drain line is not sufficient. Its a 10AN hose with a straight 10AN fitting and a 45* 10AN fitting. But because a 10AN fitting has to fit inside a 10AN hose the ID is actually less than .5" on my fittings.
I'm going to have to spend some time under the car redesigning the oil drain, but hopefully can come up with something that works a little better. Thinking a flange with a straight tube that comes off the turbo, with a hose clamped rubber line. Then if I can swing it some sort of AN fitting on the drain. I'm thinking about getting some line to flare, and working with that. I could do a custom angle off the 10AN bung, and then bead roll the other end and slip a hose over.
Either way, its not hurting the turbo right now, so my track day on August 3rd is still on. Well see if I get to it by then.
Old 07-14-2017, 11:17 AM
  #10178
Told him this at least a dozen times now.
But I forgive him for all of the filth because he's a man now, running man boost
Old 07-14-2017, 11:24 AM
  #10179
dleavitt's Avatar
Total Cats: 223
Looking forward to seeing it in action! Will you be taking passengers on the 3rd? I'd love to ride along if you'd be willing.
dleavitt is offline
Old 07-14-2017, 11:25 AM
  #10180
Sure. I'll be there instructing. Should be able to take you out for a few laps.
