Old 06-16-2017, 06:37 PM
  #10041
I posted a picture a ways back. It's barely wet. And just on one cylinder.
im quite sure it was honed right. The other 3 motors that were sent in with mine aren't smoking.
Old 06-16-2017, 07:45 PM
  #10042
rleete's Avatar
Total Cats: 1,277
Ya never know. Friday afternoon, and the guy is thinking about the weekend. Monday morning, and he's tired from staying up late Sunday night. **** happens.
rleete is offline
Old 06-16-2017, 07:47 PM
  #10043
Why would it only be on one cylinder?
  #10044
The "wet spot"
Old 06-16-2017, 07:53 PM
  #10045
patsmx5's Avatar
Total Cats: 519
Hey, I'm trying to help. You can't rule out everything and still have a problem.
patsmx5 is offline
Old 06-16-2017, 08:01 PM
  #10046
I'm not discounting your suggestion. Just countering it with the reasons I've been using to rule it out.
There is one last hope.
https://www.miataturbo.net/general-m...tion-gas-8955/
I'm running really rich at higher rpms. Haven't had time to really tune it in. And rich = safer than lean.
Not sure what I'll do if it keeps smoking. Probably valve stem seals again or something. Just keep replacing them until i run out of money.
Old 06-16-2017, 09:45 PM
  #10047
New ground shim back in. Clearance is right where I wanted it to be. Machine shop killed it. They even showed me how the surface grinder worked.
Hopefully will have it driving tomorrow. I think I'll have some dry time to spin some tires.
Old 06-17-2017, 01:49 PM
  #10048
SadFab CEO
hi_im_sean's Avatar
Total Cats: 1,142
Surface grinder is win.
hi_im_sean is offline
Old 06-17-2017, 03:31 PM
  #10049
Der_Idiot's Avatar
Total Cats: 28
Gotta ask, do you screw with RTV on the half-circle spots when you put the valve cover gasket on? It takes me forever to extract it all to re-seal the thing if I have to check the valve clearances..
Der_Idiot is offline
Old 06-17-2017, 03:35 PM
  #10050
Yeah. I just scrape it off with a blade and reapply.
Old 06-17-2017, 05:08 PM
  #10051
Bannisheded
fivehundredton's Avatar
Total Cats: -1
Wow you've come a long way. Sorry if you mentioned this- Just skimmed to catch up. (Don't holler and throw **** for stupid question, but) Are the rings directional and could one on number 4 be upside down?
fivehundredton is offline
Old 06-17-2017, 05:19 PM
  #10052
Rings are directional. But remember this only happens after driving hard (really hard) then idling. Normal driving is fine.
Old 06-17-2017, 06:50 PM
  #10053
Bannisheded
Total Cats: -1
How dirty is the inside of the intake manifold? If it's not the turbo or valve stem seals then. just flinging ideas to help ya' think:
-rings on 4 didn't seat as well as the others
-there's enough residue left in the intake manifold to make it to 4 and smoke
-something keeps messing up a valve seal
-you've got a weird, almost unheard of crack in the head
Old 06-17-2017, 06:52 PM
  #10054
Leakdown is ~3% on all cylinders.
intake manifold was super dirty. That like my last hope. I cleaned it out real good.
Old 06-17-2017, 06:55 PM
  #10055
Total Cats: 858
AIUI, the state of the oil control rings doesn't really show up in leakdown tests.
codrus is offline
Old 06-17-2017, 06:56 PM
  #10056
This is true. My thought was that if something had caused #4 to break in incorrectly it would also show in the compression rings.
Old 06-17-2017, 06:58 PM
  #10057
icantlearn's Avatar
Total Cats: 117
if the gap is big enough for oil to get by I would think it would show up in a leak down test right?
icantlearn is offline
Old 06-17-2017, 07:13 PM
  #10058
Compression rings != Oil control rings.
Old 06-17-2017, 07:18 PM
  #10059
icantlearn's Avatar
Total Cats: 117
If the oil was able to get into the combustion chamber then it was able to get past the compression rings.
Old 06-17-2017, 09:18 PM
  #10060
patsmx5's Avatar
Total Cats: 519
Not for the oil rings at least. If they fail, it coats the comp rings in oil all the time and you show good compression, like driving around doing a wet compression test all the time. The motor I built years back where I literally reused the old rings, it had 140 or so compression, but burned a quart every 200 miles or something crazy like that.
patsmx5 is offline
