Old 06-09-2017, 09:08 PM
  #10001
Total Cats: 558
Fair enough, but you got rubber o rings. At least grease the shaft and inside of the new bushing.
sonofthehill is offline
Old 06-09-2017, 09:09 PM
  #10002
I'll try that. I need something that won't wear as much.
Old 06-09-2017, 09:37 PM
  #10003
Total Cats: 558
Old 06-09-2017, 09:40 PM
  #10004
Total Cats: 558
I also use the valve stem portion of a bicycle inner tube sandwiched between the can and the bracket as a redundant seal.
Old 06-11-2017, 01:58 AM
  #10005
It was definitely the wastegate. It is back to pulling nice and hard. And spooling way faster.
Pulled the turbo/manifold. No oil that we can see. Ports look clean too. Will take some pictures.
Next will be the intake manifold, and look down the plug holes. And if no oil then I have no idea, and will keep driving it.
Maybe check the exhaust too.
Old 06-11-2017, 02:35 AM
  #10006
Cylinder 1:
Cylinder 2:
Cylinder 3:
Cylinder 4:
Old 06-11-2017, 03:33 PM
  #10007
Intake manifold is off. It has a **** ton of carbon build up because I didn't clean it before install. But no smoking gun.
Some oil on all the port walls. But the valves appear to be clean. I swabbed them all with a qtip and nothing.
Using the boroscope there might be a wet spot on cylinder 4 but it's really hard to tell with such a shitty camera. I'll attach a picture anyways.
So I shut the car off while it was smoking, and can't find oil anywhere except the port walls, intake manifold, and maybe on piston 4.
This sucks.
In good news. Albert made me a baller new injector harness.
Old 06-11-2017, 04:44 PM
  #10008
williams805's Avatar
Total Cats: 27
And you don't even have oil squirters. Bummer.
williams805 is offline
Old 06-11-2017, 08:55 PM
  #10009
mmmjesse's Avatar
Total Cats: 44
seems gay. when is the partout?
mmmjesse is offline
Old 06-11-2017, 09:37 PM
  #10010
Can't come soon enough.
Broke my exhaust clamp downpipe brace. We'll see if the replacement lasts any longer.
Hacked together my leakdown tester to use on the bottom port of my wastegate. This is a fresh new bushing.
Interested to see how it deteriorates.
Old 06-11-2017, 11:37 PM
  #10011
Congrats on 10k posts in your thread!
#goals!
Old 06-11-2017, 11:38 PM
  #10012
That's how you get mod status
Old 06-11-2017, 11:55 PM
  #10013
icantlearn's Avatar
Total Cats: 117
how did you manage to break it? impact?
icantlearn is offline
Old 06-11-2017, 11:56 PM
  #10014
Driving flatout
Old 06-12-2017, 01:52 AM
  #10015
Couple more videos from autox.
Old 06-12-2017, 11:24 PM
  #10016
Total Cats: 558
That's not all it takes.
I am interested to see how the bushing holds up too. Mine still seals, so far
You greased it right?
Old 06-12-2017, 11:26 PM
  #10017
Let me do a track day in it and we'll compare
I did
Old 06-14-2017, 09:48 PM
  #10018
I did a thing.
6 speed. 3.9. 168k 3 owner. Hardtop. Abs, cruise, all the fixings.
Even includes a roll bar
Old 06-14-2017, 09:51 PM
  #10019
wackbards's Avatar
Total Cats: 266
I did a thing.
Color me jelly. I want a green NB to compliment my green NA.
wackbards is offline
Old 06-14-2017, 09:59 PM
  #10020
icantlearn's Avatar
Total Cats: 117
use that one to tow the NA to laguna. that would be most savage.
