My way-over-budget...budget build thread - 99 Turbo
Well, after a year and a half of wrenching, my 1999 Miata build is nearly done. In an attempt to give back to the forum, here's a rundown of the build and a brief pictorial.
The project was NOT intended to be a big dollar/big HP build and ended up being much more costly than expected (doesn't it always); had i known where it was all headed, I would have chosen a few things differently. For example, higher comp pistons, better flowing turbo/exhaust setup, etc. That said, and all things consider, I'm please with the current results and the things I've learned throughout the process. There's more tuning to be done for sure, but I'm still learning that as well.
Enjoy!
Engine Internals / Accessories:
- Manley 14011-4 H-Beam Connecting Rod Set
- Weisco Pistons K553M835 (0.02 over / 8.4 comp ratio)
- ARP Main Stud Kit (218-5401) and Head Studs (2184701)
- Boundary Engineering Oil Pump Stage 1
- SuperMiata Harmonic Damper
Head:
- Sealed Power VS855 Valve Springs
- Supertech Valve Seals Miata
Engine Control / Spark:
- LS2 Coil-On-Plug
- Supermiata Trigger Wheel 36-2
- MegaSquirtPNP G2
- BKR7EIX
- Speed Density setup
Fuel:
- Injector Dynamics Fuel 1050X injectors
- Deatschwerks dw300 (hard wired)
Turbo/Exhaust:
- ebay GT35R (Stage III Ceramic Ball Bearing T04E GT35 Spec T3 5 Bolt .70 .63 AR)
- ebay T3 log Manifold
- Precision Turbo PTE PW39 39MM External Wastegate (dumps directly next to trans)
- Customer turbo elbow
- Flyin Miata Turbo Downpipe (Lower Section) w/ 2.5 boost actuated dump
- Flyin Miata 2.5" Resonated Turbo MidPipe with Milspec 3" 100 cell Catalytic Converter
- 2.5" 63mm Exhaust Control Valve Set boost Actuator CLOSED Style Stainless Steel
Intercooler/Cooling:
- KOYO V-Core Radiator
- ebay 29x9X3.0 intercooler
- ebay universal 2.5inch intercooler tubing kit
- ebay universal SQV Blow Off Valve
- Rival Autosport Type 1 Universal Aluminum Hood Louver
Transmission/Clutch:
- 6 Speed Swap
- Shifter Rebuild Kit (5xRacing)
- Flyin Miata Happy Meal Clutch (Level 1)
- Flyin Miata 10.3 lb flywheel
- Stainless Steel Braided Clutch line
Drivetrain / Body:
- 3.9 Torsen Swap
- FC RX7 Rear end Housing
- Delrin Rear Differential Bushing
- Delrin Door Bushing
- Mazda Competition Motor Mount
Suspension/Wheels:
- Flyin Miata V-MAXX Classic Coilover
- Flyin Miata Front and rear sway bars (1.0" front and 0.625" rear)
- Flyin Miata Frame Rails Reinforcement Kit
- 15x8 Jongbloed w/ Toyo 225 R1Rs
Other:
- Jeggs oil catch
- Innovate LC-2 Digital Wideband
- 5X Racing Miata Oil Pressure and Water Temp Gauge Kits
- huge amount of OEM seals, gaskets, nuts, bolts, bla bla bla
And thanks to everyone who's posted helpful content on the forum. Without it, this project would not have been possible.
Special thanks, in no particular order:
- Reverant
- Braineack
- 18psi
- Savington
- stefanst
- patsmx5
- thecarpassionchannel (youtube)
June 2016 - With just under 98k miles, the car arrives home. It was intended as a casual toy to putts around in on the weekends.
In under a week of ownership, wheels and roll bar arrived. A month or so later, I started ordering the FM suspension parts mentioned above.
November 2015 - After driving the car for about 5 months, I noticed the oil pressure gauge flutter. Long story short, I apparently had a small oil leak that i didn't catch in time. The somewhat noisy rod bearings only became worse at this point. Since the winter was about to set in, i decided to pull the motor. This being my first deep dive into an engine of any sort, it was nerve racking.
Gross
Here's a comical attempt at trying to hold the crank bolt in place with some extra metal i had in the garage.
FAIL
January 2016 - Picked up the block from the machine shop.
Engine parts also began arriving
February 2016
March 2016 - disassembling the head on the living room floor.
May 2016 - The engine is slowly coming together.
June 2016 - Head back on the block. Turbo mounted
Additional Items on (please ignore that stupid turbo head shield)
Cat helping
July 2016 - It's back in the car!
My cat providing direction on intercooler piping routing
August 2016 - Finishing up the interior wiring (with additional guidance)
September 2016 - It runs! For the next few months I worked on getting the tune "correct" and adding other parts. Most of the time the car just sat in the garage due to crappy weather.
May 2017 - Swapped the rear end to a 3.9. The 6 speed combined with the stock 4.3 open rear was a nightmare.
May 2016 - The final product (for now):
Edit: Removed VD dyno graph and log. I suspect the hp numbers were a bit inflated.
Thanks!
Enjoy!
Head:
- LS2 Coil-On-Plug
- MegaSquirtPNP G2
- BKR7EIX
Fuel:
Turbo/Exhaust:
- 6 Speed Swap
Drivetrain / Body:
- 3.9 Torsen Swap
Suspension/Wheels:
Other:
- Jeggs oil catch
- Reverant
- Braineack
- 18psi
- Savington
- stefanst
- patsmx5
Gross
FAIL
February 2016
Cat helping
Thanks!
Oh. That's what my car would actually look like if the paint wasn't shiet and it didn't have dings everywhere...
Awesome build. Hopefully I get to see it in person while I'm around town.
I'm guessing you bought stefanst's kosei's?
Congrats on getting everything running. Are you planning on doing the coolant reroute soon?
Lol. Right? It recently dawned on me that I haven't touched the waste gate preload. I'll be messing with that today. I have a strong inclination it's set way too soft. Fingers crossed it helps!
Especially if you still have AC installed, the condenser has an impact on airflow. One data point (of many) in a recent build thread: https://www.miataturbo.net/build-thr...t-90646/page2/ No track work, just interstate cruise.
Interesting. I'll strongly reconsider it. Let me do some reading.
Side note: shortening the wastegate arm actually hurt spool/power
A vendor here sells them. I really need to install mine. I've been lucky so far with driving temps. I'm still running lulz power (170ish rwhp) so it's a wash, but it'll need to go on rull soon since I have AC as well.
Here's the link: https://www.miataturbo.net/miata-par...r-mount-88962/
Update:
I ordered a new (better fitting internal wastegate actuator). It includes a few springs including a 1.5 bar that I plan on installing.
That said, i don't think it's going help. I found that:
- When completely CLOSING my boost controller, the wastegate still opens at ~22psi (intake pressure). That's with standard preload on a 14psi spring that came with the current actuator.
- This means back pressure in my turbo/exhaust must be so high that it's overcoming the spring, opening the flapper, and bleeding off boost - even without boost pressure assisting to press on the spring down.
- Thus, I think one of my biggest issues at the moment is too restrictive of a post-turbo exhaust (the ebay turbo elbow, the 2.5 inch piping, and the inclusion of a catalytic converter).
Update:
Bonus: Anyone want to guess why my tunerstudio logs won't capture a psi reading greater than 22.9psi? I'm pretty sure my map sensor is the standard 2.5bar mpx4250.
- The new wastegate (with a 1.5bar/22psi spring) did nothing for spool or power.
- I found an exhaust leak (pre-turbo) that I'll be fixing this weekend.
- I orded a Flyin' Miata cast log manifold to replace my current eBay one.
