Old 05-23-2017, 09:45 PM
  #9721
The seat and the "shim" are the same thing. Gimme a minute and I'll get pictures.
Old 05-23-2017, 09:46 PM
  #9722
icantlearn's Avatar
Total Cats: 117
You don't have to do that. Ill just watch a video on it.
icantlearn is offline
Old 05-23-2017, 09:47 PM
  #9723
I'm in the middle of pulling it all apart. Easy to get a pic.
Old 05-23-2017, 10:15 PM
  #9724
Stock stack
What comes from supertech. (Singles in the photo. Doubles include another smaller spring that fits inside)
Old 05-23-2017, 10:59 PM
  #9725
icantlearn's Avatar
Total Cats: 117
So that black thing in the second photo is the shim that goes under the retainer on the right?
Old 05-23-2017, 11:21 PM
  #9726
No that's a spring seat.
Managed to toast another lifter. One of the cam lobes has some marking on it that I believe did this. Not sure if I overlooked it or whatever. Getting another lifter ordered.
**** this ****.
Old 05-23-2017, 11:33 PM
  #9727
Total Cats: 858
This is the stock shim:
OEM it's primarily there to keep the spring from wearing direction on the aluminum. With the Supertech springs, you're supposed to keep it, although now it's just a .005" spacer, because instead of the spring going on top you have this:
That's the ST spring seat. On top of that go the springs:
That's a set of the heavy doubles. On top of those go the top mount (not sure what that's called), and the two keepers go inside that. The valve stem sticks up through the hole in the center, and the grooves on the stem engage with ridges in the keepers to lock it all together.
The .005" shim doesn't sound like much, but it's adding preload to the spring. Preload is important -- I measured my exhaust manifold pressure at 350 kpa at one point. That's 50 psi pressing on the top of the exhaust valve, and since the valve has an area of a bit more than a square inch, it means that there's 50+ pounds of force trying to shove the valve open during the intake stroke. So you need a bunch of preload to keep the valve up against the seat.
(ack, stupid web site coughed up a hairball when I was editing this to add the bit about preload)
codrus is offline
Old 05-23-2017, 11:34 PM
  #9728
Originally Posted by codrus
On top of those go the retainer
FTFY
Old 05-24-2017, 01:36 AM
  #9729
Total Cats: 558
ill be flying into SF on monday. expect black skies.
PM me. My guest room is occupied next week, but the couch is available. Or if you just want a place to park where you can walk to the lakes without worrying about it. I actually need to go to SF soon anyway, so I can visit you there if you want.
sonofthehill is offline
Old 05-24-2017, 11:37 AM
  #9730
New cam has a chip on the lobe. Might also be junk. Opinions?
Old 05-24-2017, 11:41 AM
  #9731
They call him "the valvetrain destroyer"
Old 05-24-2017, 11:42 AM
  #9732
This is the 3rd cam I've looked at.
Reading around says that as long as its not a high spot its ok to run.
Old 05-24-2017, 11:49 AM
  #9733
rleete's Avatar
Total Cats: 1,277
Stone off the sharp edges, first.
rleete is offline
Old 05-24-2017, 11:55 AM
  #9734
correct
Old 05-24-2017, 12:09 PM
  #9735
RalliartRsX's Avatar
Total Cats: 22
Cam looks fine to run.
RalliartRsX is offline
Old 05-24-2017, 12:31 PM
  #9736
patsmx5's Avatar
Total Cats: 519
This. Don't want a small crack in that spot where it's chipped to spread and break the cam even more. Grind that chip out and move on.
patsmx5 is offline
Old 05-24-2017, 01:16 PM
  #9737
so just hit the edges with a diamond stone or something? Still waiting to hear back about getting a new lifter from miataroadster.
Old 05-24-2017, 01:58 PM
  #9738
bahurd's Avatar
Total Cats: 315
If you have a bench grinder a 120 grit Silicon Carbide wheel will take the sharp edges off easily without worrying about too much. Just keep it away from the journals.
bahurd is offline
Old 05-24-2017, 02:19 PM
  #9739
Do not have that. Also that+bench grinder+cam+aidan = trashed cam
Old 05-24-2017, 02:31 PM
  #9740
bahurd's Avatar
Total Cats: 315
I forgot which thread this was.... carry on. Did you use my soda straw method (actually, not mine...)?
bahurd is offline
