Valve stem seal installation tool
So after watching a few videos of people installing valve stem seals on their Miatas with the head still on, I noticed a few people use this () tool.
However in the Amazon reviews, one reviewer states that the tool is too big to fit in the Miata head.
Has anyone tried using/used this tool to remove their keepers?
I Have the Lisle 36050 tool. Got it from amazon too. It works a treat.
Removing the keepers was the easy part. Replacing them was directly proportional to the amount of movement in the valve. some of them first go.....whenthere was no movment.
others took a few goes. as well as repostioning the rope to make sure there is minimum amount of movement in the valve.
I also lost grip on one valve & it threw the tool into the bonnet & ended up on the garage floor. Thankfully the magnet is super strong & had the keepers still inside the tool. but the retaining plate for the spring had disappeared.....eventually found. LOL
