Supermiata S1 build - Vegas
Old 04-10-2017, 02:01 PM
  #141
Total Cats: 1,899
Ducting will allow airflow underneath I/C to rad.
Pardon my extreme ignorance, but unless I'm mistaken, this runs contrary to everything I feel like I've ever read regarding ducting and intercoolers. If you know something I don't know, I'd love to hear more about this subject. I'm always looking to optimize my stack.
EO2K is offline
Old 04-10-2017, 03:34 PM
  #142
Total Cats: 2,387
I'm focused on engine cooling over intercooler efficiency. We will see how it works.
.31 SNR
emilio700 is offline
Old 04-10-2017, 03:52 PM
  #143
Clean and pretty piping work, as expected from you
Though a bit surprised to see flowmaster and not maggie
I think he meant he's gonna have a scooper for the rad, similar to what begi did ages ago to help the rad recover some of the airflow it's loosing to the ic
Old 04-10-2017, 10:12 PM
  #144
icantlearn's Avatar
Total Cats: 117
Im extremely interested to see how the car is going to sound. I may have to ask you for the part numbers for the resonator and the muffler when/if sound clips are up.
icantlearn is offline
Old 04-10-2017, 10:32 PM
  #145
Total Cats: 2,387
Flowmaster 13016101 & 815430S
.31 SNR
Old 04-10-2017, 10:35 PM
  #146
icantlearn's Avatar
Total Cats: 117
Thank you. Saved. You guys finally got the car back from TC eh? Pics of final product?
Old 05-18-2017, 07:21 PM
  #147
Total Cats: 2,387
10mm Alumalite
.31 SNR
Old 05-18-2017, 07:24 PM
  #148
mx5-kiwi's Avatar
Total Cats: 57
10mm Alumalite
So frustrating we cant get that here. Not for love nor money does anyone carry it. Ridiculous.
mx5-kiwi is offline
Old 05-18-2017, 07:37 PM
  #149
Junkwhale's Avatar
I was googling to find this in NZ the other day too. Wondered about stacking/epoxy-ing a some of layers of 3mm or 4mm together which does seem to be available. Not likely to be as stiff tho.
Junkwhale is offline
Old 05-18-2017, 07:39 PM
  #150
Total Cats: 2,387
If you have either nomex honeycomb or corrugated plastic, you can bond .032"~ .049" aluminum to it.
.31 SNR
  #151
mx5-kiwi's Avatar
Total Cats: 57
Not to sidetrack, so pm if you want but the 3 and 4mm stuff we can get is not hollow/corrugated in the middle like the proper "Alumalite" is.
Ours is just sold core plastic (that im aware of at least) and quite heavy. Though i do use it for undertray and stuff.
Edit: Thanks Emilio, will look in to that.
mx5-kiwi is offline
Old 05-23-2017, 05:02 PM
  #152
ThePass's Avatar
Total Cats: 1,216
That is dibond (or an equivalent), not alumalite.
Ryan Passey
ThePass is offline
Old 11-20-2017, 12:29 PM
  #153
DeepEddyRacing's Avatar
Default Shock tower brace?
Are you running this car without a shock tower brace? We have an NA8 turbo endurance racer and are looking into braces. Thanks
DeepEddyRacing is offline
Old 11-20-2017, 01:10 PM
  #154
Total Cats: 2,387
Vegas will not have a shock tower brace. It will have cage extensions to the shock towers through the firewall however. I have never been able to discern any difference in handling with a traditional shock tower brace. They do seem to lower NVH a bit on street cars though.
.31 SNR
Old 11-20-2017, 02:28 PM
  #155
Default Other stiffening mods?
Do you recommend any other stiffening mods or products like Flyin Miata sells?
Old 11-20-2017, 02:45 PM
  #156
Total Cats: 2,387
Good subject for a new thread. Race cars have cages, obviating the need for bolt on braces in most cases.
You will notice we do not offer any braces on our site nor does Blackbird Fabworx nor Trackspeed Engineering, et.al.
.31 SNR
Old 11-20-2017, 03:03 PM
  #157
Lexzar's Avatar
Total Cats: 41
Where will, and which, oil cooler will be used?
Lexzar is offline
Old 11-20-2017, 03:18 PM
  #158
Total Cats: 2,387
Setrab 600 series, 34 row under the right headlight. -10 lines via Mocal tstat plate on block.
.31 SNR
Old 12-07-2017, 04:50 PM
  #159
Total Cats: 2,387
The car is back in SoCal (woot). Renderos Racing is making a few small tweaks, taking molds off the wide steel fenders and then it comes home for us to start bolting stuff to it.
The two Setrab coolers have integrated fans. Fans will be controlled by the MS3Pro Ultimate ECU via thermocouples in trans and diff. Pumps in trunk. I had asked Tony to cut an intake in the RR qtr panel but he suggested putting the inlet in the wheel well. Better pressure differential, cleaner looking and no drag penalty. Note that it angles upwards so a screen should keep rocks out. Heat exchanger box has a water drain.
.31 SNR
Old 12-07-2017, 05:02 PM
  #160
julio's Avatar
Total Cats: 23
julio is offline
Quick Reply: Supermiata S1 build - Vegas
