Old 05-16-2017, 12:45 AM
  #9481
Total Cats: 1,184
What voltages are you seeing?
curly is offline
Old 05-16-2017, 12:49 AM
  #9482
It's not a voltage reading. It's a knock %.
​​​​​​in the pictures you can see a baseline noise threshold and some spikes that may indicate knock.
Old 05-16-2017, 01:22 AM
  #9483
If you zoom in on this picture you can see specs of aluminum on the strap and insulator. I'm putting fresh plugs in and am going to try to stay away from 30psi. And install my Det cans.
@patsmx5
Old 05-16-2017, 01:38 AM
  #9484
patsmx5's Avatar
Total Cats: 519
What timing map are you running to get that much detonation? What octane? Those plugs are hammered. I could never run more than 28 PSI on 93 Octane without detonation no matter what I did. I looked at your logs and it shows like 8-9 degrees timing at 5K and 250kPa.
patsmx5 is offline
Old 05-16-2017, 01:41 AM
  #9485
30psi was an accident lol. I can post my tune in a bit. But it's very retarded.
pulled number 2. Looked way better. Only a few specs. I'll get to the others tomorrow.
Old 05-16-2017, 01:43 AM
  #9486
https://drive.google.com/file/d/0B7v...w?usp=drivesdk
Current tune.
Old 05-16-2017, 01:46 AM
  #9487
patsmx5's Avatar
Total Cats: 519
Tunerstudio doesn't have the ECU definition I need to view that, where do I download that?
patsmx5 is offline
Old 05-16-2017, 01:48 AM
  #9488
Megasquirt Support Forum (MSEXTRA) ? MS3 pre-1.5.1 beta 1 firmware released (View topic)
Old 05-16-2017, 02:11 AM
  #9489
I wonder if my intake valve stem seals (supertech) are leaking and causing det.
Old 05-16-2017, 07:40 AM
  #9490
Total Cats: 3,075
Burning oil does lower octane significantly.
Let's see how many new views this thread gets now.
sixshooter is offline
Old 05-16-2017, 08:14 AM
  #9491
Total Cats: 2,201
Supertech valve seals are killing your turbo motors.
concealer404 is offline
Old 05-16-2017, 08:41 AM
  #9492
rleete's Avatar
Total Cats: 1,277
Superfail or Failtech?
rleete is offline
Old 05-16-2017, 08:46 AM
  #9493
Forrest95M's Avatar
Total Cats: 21
I've heard nothing but problems from supertech valve stem seals
Forrest95M is offline
Old 05-16-2017, 09:33 AM
  #9494
Number 2
Old 05-16-2017, 10:40 AM
  #9495
yossi126's Avatar
Total Cats: -14
Using this for my ignition tuning coupld with sennheiser headphones. Probably saved my engine by doing so.
Knock Detection Tool / Adapter Cable, EFI Express
Oh and a 10$ bosch knock-off knock sensor.
yossi126 is offline
Old 05-16-2017, 11:49 AM
  #9496
thumpetto007's Avatar
Total Cats: -117
Does this also work with an oem 2001 knock sensor? Thanks.
thumpetto007 is offline
Old 05-16-2017, 01:00 PM
  #9497
yossi126's Avatar
Total Cats: -14
Dunno. If the oem knock sensor has a Bosch style connector than yes. Though it's much easier to buy the sensor and hook it up to one of the valve cover bolts.
yossi126 is offline
Old 05-16-2017, 03:17 PM
  #9498
stefanst's Avatar
Total Cats: 74
I tuned for knock with a VW knock sensor and HF detcans. Works just like a standard mechanics stethoscope (which it pretty much is). Det, even around 6krpm, was pretty obvious.
I later hooked the stock sensor up to the good old Harborfreight detcans. You can barely hear anything. May have to increase the sensitivity for them.
On the other hand, OEM knock sensor, AFAIK, is tuned to Miata knock resonant frequency (around 6kHz or so?). So maybe I would only hear knock, but since my engine is not knocking, I'm not hearing much.
stefanst is offline
Old 05-16-2017, 03:55 PM
  #9499
When you say HF det cans what are you referencing. I did the HF microphone thing and extended it and bolted it to my 1.6. I just have no idea what to listen for. I'm going to hook them up tonight and see what I can hear.
Old 05-16-2017, 04:30 PM
  #9500
Total Cats: 859
Stock sensor is wideband, not tuned.
DNMakinson is offline
