VTCS connection help
Total Cats: 9
Hi Guys, I知 up for my emissions check and I had to put the stock ECU back in the car for the first time since installing my turbo. I知 throwing CEL P2004 Intake Manifold Runner Control Stuck Open Bank 1. I知 suspecting that I have the vacuum lines run incorrectly to the VTCS. The car runs like crap until its warmed up which would be expected. Here痴 what I知 currently looking at:
DEI liberal femininity
Total Cats: 574
nevermind. maybe I will post the diagram.
wires going to VTCS components are:
4J VTCS vacuum switch
2N VTCS Solenoid valve
There will be an actuator attached at one end of the manifold, then on the vac line you'll have:
a delay valve
the vac switch (teed in)
the solenoid valve inline
the check valve
then the vac line connects to the manifold
I believe the blue thing under the throttle body is the delay valve. the green and white is the check valve.
The VTCS line should go to the back of the manifold where your gauge is connected. The port on the top where your BOV connects is usually capped I think.
a delay valve
the check valve
Total Cats: 9
The Megasquirts not hooked up since I need to pass emissions. Normally, I don't have the check valve on that line.
