The definitive "How do I catch can?" thread.
Old 07-03-2016, 10:47 AM
  #161
ryansmoneypit's Avatar
Total Cats: 458
Steel or copper wool?
ryansmoneypit is offline
Old 07-03-2016, 10:52 AM
  #162
nitrodann's Avatar
Stainless steel
The chambers consist of walls which are 5mm narrower than the can, and go from floor to ceiling, the issue with a can such as the one below is that when the contents reaches the baffle the can is effectively full.
In this design, how does blowby get past the oil/wall? This is why multiple holes or vertical slots are common.
Dann
Attached Thumbnails The definitive "How do I catch can?" thread.-80-170047_definitive_how_do_i_catch_can_thread_80_20151113_221122_5b560fbacd689123b386ceb8f1188d.jpg   The definitive "How do I catch can?" thread.-80-catch_can_b91787b341c7e6f0d78f6d60e590b878b8b6c0a3.jpg
nitrodann is offline
Old 07-03-2016, 10:55 AM
  #163
Total Cats: 458
Stainless steel
ni
Dann
It has a perforated false floor. This let's the contaminates fall and seperate from the filter media.
  #164
nitrodann's Avatar
Bonus photo.
So it has the effective capacity of the floor only?
Attached Thumbnails The definitive "How do I catch can?" thread.-80-img_20140331_180315_2be6739d78765b3ba4e766323a1f2ae8f9f5da4b.jpg
Old 07-03-2016, 10:59 AM
  #165
Total Cats: 458
It holds about 500 maybe 700cc before it reaches the divider wall, and also has a drain.
I figure if you need to catch more than that, you have other problems.
I wasn't knocking your design. Your post was just super vague. Just a picture of a welded can.
Old 07-03-2016, 11:02 AM
  #166
nitrodann's Avatar
Im not knocking yours either. Catch can design is pretty awkward for the reasons we are discussing, I respect your opinion way far enough to take your criticism seriously.
This whole can is only 700cc, really for street car guys with bolt on mods, not for racecars/built engine 20+psi folk.
But for real, do you think it has appeal in the states, worth figuring out international shipping and posting on US pages? Sells here for 300aud, around 230usd with everything.
Dann
Old 07-03-2016, 11:16 AM
  #167
Total Cats: 458
Dann
I gave up on the idea. Between Morosso, Mishimoto, and the people who don't know right from wrong it seemed like a saturated market with minimal profit.
Old 07-03-2016, 07:53 PM
  #168
nitrodann's Avatar
Attached Thumbnails The definitive "How do I catch can?" thread.-80-jnxfdhk_75b0fa4068adb1b12055a944e9443e7b995f5c05.jpg
Old 07-03-2016, 08:32 PM
  #169
rleete's Avatar
Total Cats: 1,284
Skynet is everywhere.
rleete is offline
Old 08-10-2016, 09:18 AM
  #170
robertw's Avatar
Total Cats: 59
My setup works well enough on the street, but at the track the catch can filled up and oil made its way to the intake at the turbo. So I'll have to take the intercooler out to try cleaning it. I get a lot of crank case pressure at the track it seems, oil weeps out of the valve cover oil cap, and my dip stick pops up after a few hard laps. I've read through the crank case pressure threads, this thread, and I'm still not sure what I should do lol.
robertw is offline
Old 08-10-2016, 10:22 AM
  #171
Total Cats: 458
Where are your breather lines connected ? Can't tell from the pic.
Old 08-10-2016, 11:08 AM
  #172
deezums's Avatar
Total Cats: 201
Are there any more ports on that catch can? Kinda a weird place to put it, usually if you have only one can it's between the intake manifold and valve cover...
I would disconnect the PCV while at the track, cap the intake manifold line and run both valve cover vents to the catch can. Probably put a breather filter, instead of routing it back to the intake by the turbo. Should give you double the flow, without modding the valve cover. Might still fill with oil, maybe drain it between sessions. At least it won't be dumping into the turbo.
You've also got a FWD valve cover, all in the wrong orientation. It's easy to see how it could dump oil under acceleration. I really want to trade my escort cover for a miata one for that reason.
deezums is offline
Old 08-10-2016, 01:07 PM
  #173
robertw's Avatar
Total Cats: 59
pcv to IM, and VC breather is at the rear with a clear hose to the catch can, and then out from the catch can to the intake before the turbo (clear hose). I used clear hose to see if oil is in the lines.
I'm using the gtx pcv, and from my understanding the pcv was necessary, so I ran that. I guess I'll try running my old VC with the pcv and see if that can lower the crank case pressure and split less oil out.
robertw is offline
Old 08-10-2016, 01:13 PM
  #174
williams805's Avatar
Total Cats: 27
This^. You need more vent. The pcv is not doing anything under boost so might as well put it to use on the track.
williams805 is offline
Old 08-10-2016, 01:17 PM
  #175
Total Cats: 458
Also lost of stuff on adding filter media, and opening the breather ports on a stock valve cover. I run both left and right ports to the tank, then to the turbo inlet. Along with the vc mods.
Old 08-10-2016, 01:25 PM
  #176
robertw's Avatar
Total Cats: 59
I drift the car so I'm constantly on throttle hard, then off, back on, and so forth. My understanding was that without the pcv I could potentially pull oil / oil vapor into the combustion chamber and lower octane as a result. That's the reason I felt the pcv was necessary, but maybe I misunderstood.
robertw is offline
Old 08-10-2016, 01:26 PM
  #177
You misunderstood. The oil vapor gets pulled in through the PCV valve from the valve cover. Thats why you run a catch can there.
Old 08-10-2016, 06:11 PM
  #178
Total Cats: 27
Yeah, just cap off the pcv valve on the intake for the track.
It won't be pulling vacuum on crank off throttle any more, but you need more vent so that seems like the priority for track usage.
My system is routed like yours except I have a catch can between vc and pcv. Also my fresh air side has been opened up a bit and larger line on that side. I don't have problems with dip stick poping out at 14psi manifold pressure, but I don't track either. Before I opened up the fresh air side the dip stick would pop up.
Old 08-10-2016, 06:53 PM
  #179
HHammerly's Avatar
Total Cats: 63
You will have more oil venting if you just disconnect the pcv line btw.
I know that this pretty ugly right now but it works on the track runing 15psi, i am getting no oil on the catch can and since the photo have removed the can drain line. Again no oil on the catch can after 1-1/2" hours, i will be doing 3 hours track on the 27th
esentially i left the pcv line with the can as before for dd and added the following on to the exhaust side vent:
1) installed a second air inlet and cover like the oem piece on the center chamber steel cover.
2) made (6) 1/4" holes between the top of the center chamber and the bottom of the exhaust chamber.
3) welded the eom vent shut.
4) cut a 1/2"x 2" slot on the top of the exhaust chamber .
5) built a third chamber over the exhaust chamber.
6) put a -10 vent fitting and hose.
HHammerly is offline
Old 05-04-2017, 01:00 PM
  #180
Eunos91's Avatar
Total Cats: 93
Does anyone else have problems idling after reworking the crankcase ventilation system? I did enlarge the tiny hole on the driver's side and welded a threaded -10AN fitting to the valve cover. Since I'm still running N/A, I put a small breather filter on the fitting for now.
on the passenger side I'm running full -10AN lines as well. They are routed from the valve cover through a metal check valve, into a catch can, and from there to the inlet manifold
the problem is: even with the idle screw fully closed and the idle valve unplugged, it still idles at around 3000 RPM. The engine is simply pulling too much air through my ventilation system. My current plan is to put a restrictor into the line between the valve cover and the catch can. Thus I hope to choke the engine enough to keep the idle down where it belongs. At the same time this would hinder PCV, though.
Eunos91 is offline
Quick Reply: The definitive "How do I catch can?" thread.
