What determines INITIAL startup idle duty?
Total Cats: 62
MSPNP2, 1.4.1 firmware. The issue I have is when starting the car it will zoom to ~2700 rpm for a few seconds and then slowly come down to ~1400 over the course of another 5 seconds or so. By then it's in closed loop and evens out. But what causes the initial high idle? I can't imagine revving to 2700 while the car has barely any oil pressure is doing it any good. I thought this was potentially the cranking idle duty, but that didn't make a difference.
I don't have logs at the moment but I can get some tomorrow. Just looking for a few spots to check first.
Total Cats: 62
Anyway that's the exact option I was tinkering with but it did not seem to make a difference. Maybe I'll try larger/smaller values.
Total Cats: 859
The only other variable, assuming your CL idle values, such as targets and dashpot are correct, is the Crank-to- Run Taper that controls how many seconds the Crank Duty Steps are held.
Total Cats: 4,126
idle cranking duty/steps table. same as with warmup.
what you need to tune now is the idle initial values table (and activate it) as well as the RPM targets tables, so you can give the PID code a rough place to start
Total Cats: 62
Kidding - it was Idle Cranking Duty as DNMakinson pointed out. I just wasn't using small enough values when I tried last time. I have it set to rev to about ~1500 on cold start, with a 4 second crank-to-run taper. Everything works great now. poscats all around.
It really helps to go through all the values on your range using the idle valve test mode and noting the important rpm: idle valve relationships that are important to the initial startup values you want.
