Windows 95 Upgrade
Old 03-31-2016, 11:11 PM
Windows95's Avatar
Default Windows 95 Upgrade
Hey guys. A little over a year ago I sought advice for starting my build. I've included my checklist below and where I'm at with things:
Completed
  • DIYPNP2 - Issues: Radiator fan always on, Rough idle after engine is warm
  • IAT sensor and cone filter (where MAF and oem airbox used to be)
  • LC-2 Wideband - Issues: AFR gauge is pegged
  • Injectors - 550cc from RX-7
  • Racing Beat midpipe (P/N 56435)
  • High flow cat (Magnaflow 59956)
  • eBay 2.5" to 4" muffler
Acquired PartsTo Do
  • Upgrade clutch - Leaning toward FM Level 1 Happy Meal - Will this even be necessary with the 2554 kit I have??
  • Install turbo kit - Which oil pan tap method is recommended, the one described in post #15 on Hornetball's build thread or the one described in BEGi's installation guide?
  • Get the car professionally tuned on the dyno
  • Body work!
The car is basically stock. It has P/S, A/C, and cruise. The clutch and radiator were recently replace before I bought it. Given the issues I've stated above, should I hold off on installing the turbo kit or should I just go for it? Or should I cut and run before I break something?
Attached Thumbnails Windows 95 Upgrade-80-miata_32579972161a4bf637419fd870027107a92899bb.jpg
Windows95 is offline
Old 04-05-2016, 12:50 AM
Windows95's Avatar
Anyone have an opinion on the oil tap method? If not, I think I'll just go by the book...hoping to tackle it next weekend.
Old 04-05-2016, 03:17 AM
patsmx5's Avatar
Total Cats: 524
Look up my build thread, I copied what hornetball did on my turbo setup, and it works great and was very easy to do.
patsmx5 is offline
Old 04-06-2016, 02:53 AM
Windows95's Avatar
I read through the entire thread describing your compound turbo project. That's unreal. I actually didn't see any post that described how you tapped the oil pan, but no worries, I think I have a pretty good idea. Did you go 1/2" like hornet or 3/8"?
If the former, it looks like P/N SUM-220851N from Summit would do the trick.
Old 04-06-2016, 03:18 AM
patsmx5's Avatar
Total Cats: 524
Hmm I know he told me about it, I thought I even posted a pic...
I did it with 1/2" NPT, straight fitting, and hooked the hose to it and bent the hose around to hook to the turbo.
Also I used a shop-vac to blow air into the valve cover where the oil cap goes, this puts positive pressure to blow out metal from the tap when drilling/tapping the pan. WHen done there was like 5 specs of metal in the pan, and I could stick my finger in to get them out no problem.
Yeap, here's a pic:
patsmx5 is offline
Old 05-10-2016, 09:53 PM
Windows95's Avatar
Default Tapped Pan
I finally drilled the pan last weekend. I put a brass plug in the hole until I get around to installing the turbo kit. Photos attached.
Attached Thumbnails Windows 95 Upgrade-2016-05-10-19.23.28.jpg   Windows 95 Upgrade-2016-05-10-19.22.57.jpg
Old 05-10-2016, 09:56 PM
Girz0r's Avatar
Total Cats: 323
Interesting location, Why not on the driver side?
Girz0r is offline
Old 05-10-2016, 10:31 PM
Windows95's Avatar
Not sure what you mean. That is the driver's side of the front of the pan...
Old 05-11-2016, 08:56 AM
Girz0r's Avatar
Total Cats: 323
I've never seen the front of the pan used
Spot #1
Spot #2
Spot #3
Attached Thumbnails Windows 95 Upgrade-20140802_215301.jpg   Windows 95 Upgrade-p1000168_1080x608.jpg
Girz0r is offline
Old 05-11-2016, 10:06 AM
Boost Pope
Joe Perez's Avatar
Total Cats: 6,897
Front-mount turbo, obviously.
Attached Thumbnails Windows 95 Upgrade-80-blob_906da4c157fa3fec6d7f60b92b885558f58bbc65.png
Joe Perez is offline
Old 05-11-2016, 10:19 AM
lol that's the most idiotic location I've ever seen
Old 05-11-2016, 01:30 PM
hornetball's Avatar
Total Cats: 696
I did it that way because it had great clearance for drilling with everything still installed on the car. Going on 40K miles with that drain location. Would do again.
https://www.miataturbo.net/build-thr...37/#post695144
hornetball is offline
Old 05-11-2016, 01:32 PM
if you don't have ac why wouldn't you drill in the traditional spot? its also really easy to access. just seems really weird and silly
this guy looks like he has ac too, so there's a belt there, and the drain now has to go around all that
Old 05-11-2016, 01:34 PM
hornetball's Avatar
Total Cats: 696
We both have AC. Works perfectly with AC. Pictures in link.
Old 05-11-2016, 03:23 PM
mmmjesse's Avatar
Total Cats: 44
Out of curiosity, do you have R39 installed in your diypnp?
Completed
mmmjesse is offline
Old 05-11-2016, 11:12 PM
Windows95's Avatar
I followed this assembly guide and I don't recall installing it. I can check next time I open it up.
Old 11-15-2016, 10:32 PM
Windows95's Avatar
Default Exhaust removal
A little update: I removed the exhaust manifold and everything behind it. The EGR tube was a challenge. I didn't have a flare wrench so I bought one. For reference, the nut is the same size as the O2 sensor, 22mm or 7/8". Spraying it with PB blaster wasn't enough. I had to get it nice and hot with a heat gun and stand halfway in the engine bay so I could apply pressure to the end of the wrench with my foot. At least it's off! A log-style cast iron manifold from BEGi will be replacing it. It has a bung for the EGR tube, but it looks like I'll need this 90 degree adapter as well as the ferrule fitting. If one of you guys who did an EGR delete has this laying around, I'd be happy to buy it off you.
Here is a pic of the old exhaust setup. It includes a 2.5" Magnaflow 59956 cat, Racing Beat 2.375 midpipe, and eBay 2.5" to 4" muffler tip–all with welded flanges. I'll be replacing it with a full 3" Enthuza.
Old 11-16-2016, 08:55 AM
psyber_0ptix's Avatar
Are you required to keep EGR?
psyber_0ptix is offline
Old 11-16-2016, 02:32 PM
Windows95's Avatar
Not exactly, because I have an MS2, but let me walk you through my logic. The new 3" exhaust system I'll be installing utilizes a test pipe instead of a catalytic converter. I'd love to be able to pass the smog test without a cat, and I think my chances will be higher if I keep the EGR. If not, I guess I can always replace the test pipe with a Magnaflow 59559, but it would be nice if I can avoid that. Is that realistic?
I've also read that deleting the EGR doesn't result in performance gains, so if the only advantage is saving $50 on the fittings, I'm fine keeping it. If there are other benefits I'm not aware of, I'd be interested in learning about them.
Old 04-22-2017, 07:12 PM
Windows95's Avatar
Default Manifold Installed
Bolted on the manifold this weekend.
Next round I'll be tackling the coolant lines.
Quick Reply: Windows 95 Upgrade
