TSE EFR NB2 Build Thread
Old 04-19-2017, 08:33 PM
  #581
icantlearn's Avatar
Total Cats: 117
Bahhhh! So I'm trying to retime the motor right now. The crank is at TDC but the intake cam marker isn't lining up with the timing cover. Its slightly off like 2-3*. Is it fine?
icantlearn is offline
Old 04-19-2017, 08:34 PM
  #582
Old 04-19-2017, 08:54 PM
  #583
Total Cats: 858
Make sure the slack in the belt is between the crank pulley and the intake cam, so that when you release the tensioner it takes it up there. There's an extra tooth's worth of slack, and if you get it between the crank and exhaust pulleys then it will be wrong after you tension it.
codrus is offline
Old 04-20-2017, 12:58 AM
  #584
icantlearn's Avatar
Total Cats: 117
I really want to go kill something right now. I got the car put back together and it didn't start....
It just cranks over, gives me a glimmer of hope of starting and thats it. I really don't know what I did wrong. But obviously the timing is off. so tomorrow I start over.
  #585
Timing wheel on backwards.
Old 04-20-2017, 01:00 AM
  #586
icantlearn's Avatar
Total Cats: 117
the concave side is toward the engine? isn't that right?
Old 04-20-2017, 01:01 AM
  #587
Total Cats: 858
Post a composite tooth log?
codrus is offline
Old 04-20-2017, 01:02 AM
  #588
icantlearn's Avatar
Total Cats: 117
Im gonna be honest with you. I don't know what that is.
Old 04-20-2017, 01:20 AM
  #589
Total Cats: 858
Hook up TunerStudio, go to "diagnostics and high speed loggers", set "logger type" to "composite", and click "start". (might need to click "capture to log file" as well, I don't remember) Try to start the car, then turn the logging off.
It will display three lines in the graph, which are the logic levels of the crank and cam signals and one indicating sync errors. Post the log file.
codrus is offline
Old 04-20-2017, 01:25 AM
  #590
icantlearn's Avatar
Total Cats: 117
here:
File Type: csv
Old 04-20-2017, 01:27 AM
  #591
Crank sensor signal is all fucky. Make sure its gapped correctly. should be a business card thickness away from the trigger teeth.
Cam signal looks fine.
Should look like this
Old 04-20-2017, 01:30 AM
  #592
icantlearn's Avatar
Total Cats: 117
Gap is correct
Old 04-20-2017, 01:31 AM
  #593
Ok. Well something is wrong with your crank sensor.
Old 04-20-2017, 01:32 AM
  #594
icantlearn's Avatar
Total Cats: 117
How? The car ran before I took it apart? If the trigger wheel is flipped would there be no signal at all?
Old 04-20-2017, 01:34 AM
  #595
I dont know how. But Its not right.
You might still get a signal with the flipped wheel.
You know flipping the wheel is super easy. 4 m6 bolts and the alternator belt.
Old 04-20-2017, 01:35 AM
  #596
icantlearn's Avatar
Total Cats: 117
ok. Ill flip it and see what happens
Old 04-20-2017, 01:57 AM
  #597
icantlearn's Avatar
Total Cats: 117
Aidan, I owe you. I swapped the wheel and it fired right up.
  #598
You're welcome, glad it worked.
Old 04-20-2017, 01:58 AM
  #599
icantlearn's Avatar
Total Cats: 117
If your at MRLS this year I will have a gift for you.
  #600
I'll be there
Quick Reply: TSE EFR NB2 Build Thread
