Old 04-06-2017, 10:28 AM
  #221
bahurd's Avatar
Total Cats: 315
Originally Posted by Colipto
For the record - that picture is the worst of the 4, not all threads were stripped.
That's why i reached out to andrew before i installed them..
"Sorry for the late reply. Yes, the threads should be tight on the stud, tight enough that you can't install them with your hand. Same as any other threaded stud. They should wind in smoothly with a wrench, though. "
Paging Savington!
Threads should be made to the spec, not wrench or hand tight. It's why they exist.
bahurd is offline
Old 04-06-2017, 12:27 PM
  #222
Total Cats: 858
If that curly-cue is a piece of metal and, and it's not just a leftover chip from tapping/drilling that didn't get cleaned out of the hole, then there's something badly wrong. Studs should be tight, but they should not be self-machining.
codrus is offline
Old 04-06-2017, 01:07 PM
  #223
Colipto's Avatar
Total Cats: 28
Well this completely sucks. I'll probably start removing the studs when i get home tonight to see how bad the damage is. I find it very frustrating that this happened, considering i even waited a few days just to confirm with andrew something like this wouldn't happen.
Colipto is offline
Old 04-06-2017, 01:29 PM
  #224
Old 04-06-2017, 01:41 PM
  #225
bahurd's Avatar
Total Cats: 315
Here's the spec for M8X1.25 should you care to measure. Doubt you have pitch mics though.
bahurd is offline
Old 04-06-2017, 01:42 PM
  #226
Cross threaded?
Old 04-06-2017, 01:44 PM
  #227
Originally Posted by aidandj
Cross threaded?
Unlikely that it would happen to every single one of them though, right? He was using hand tools and not an impact here too it looks like so it's a bit harder to force things through if the threads aren't catching.
Old 04-06-2017, 02:00 PM
  #228
bahurd's Avatar
Total Cats: 315
Maybe the holes in the manifold are small? How long does it take for the resbond to setup?
bahurd is offline
Old 04-06-2017, 05:05 PM
  #229
Total Cats: 2,102
That should have been really obvious when you were winding them in with the wrench. I've put together half a dozen here and never once seen that or anything close to it.
Savington is offline
Old 04-07-2017, 12:20 AM
  #230
stefanst's Avatar
Total Cats: 74
Real men start threads with impact wrenches!
stefanst is offline
Old 04-07-2017, 01:46 AM
  #231
Total Cats: 858
Real men start them in the mill.
codrus is offline
Old 04-07-2017, 02:29 AM
  #232
Hey now...
Old 04-07-2017, 07:06 PM
  #233
Colipto's Avatar
Total Cats: 28
Okay, So here's what's going on. I picked up a tap (M8x1.25) and ran it through ONE of the manifold holes. I only did a few spins and that was enough to clean the threads up on there. I was able to put the other side of the stud cleanly through now. ( the side not stripped). They were not cross-threaded, I've done that before and this was not one of those cases. Did not use an impact, I've been using hand tools.
If i were to try to put the same clean stud into any of the other manifold bolt holes, they would strip, hands down. Its pretty much like this was tapped with a dull tap.
To me, and correct me if I'm wrong - this means the manifold was not tapped correctly, and i put too much pressure when installing the studs, After rechasing the threads - they are all threading in on both stud sides (even the stripped side, it was very little stripping that occurred.)
Also, my daily is probably ready this weekend and i have a-lot more free time now that i don't have a job again. This will most likely be put together very quickly once i receive the new studs I've had to order from TSE.$92.45 in case you're wondering.
Potato pics
Colipto is offline
Old 04-07-2017, 07:24 PM
  #234
Total Cats: 858
Huh, I'm surprised the manifold threads won out over the inconel in the studs.
codrus is offline
Old 04-07-2017, 07:30 PM
  #235
Manifold is 347SS. Inconel is not magically strong, it just stays strong in high temps.
Depends on what the inconel has been through. And Andrew doesn't share which one he uses. But theres a good chance it isn't as hard as 347 SS.
Old 04-07-2017, 08:23 PM
  #236
Total Cats: 858
Hm. It demolished my chineesium dies when I tried to clean up the threads on my used ones. OTOH, I guess they were used, so perhaps made harder by having been hot? Dunno. Metallurgy is hard.
codrus is offline
Old 04-07-2017, 08:24 PM
  #237
Chineseium dies != 347SS Manifold
Old 04-08-2017, 12:21 PM
  #238
So is the conclusion here that the manifold threads just weren't deep enough? Otherwise it's a bit weird that the unstripped end of the stud is only going into the one he chased out with a tap right?
Old 04-21-2017, 09:08 AM
  #239
Colipto's Avatar
Total Cats: 28
Pretty much!
Pulled Engine, Denubbed my 5 speed, 3.63 coming in. Decided to do some inspection on the rear diff job ( i dropped it off at a shop to get the job done since i didn't want to deal with the rust, when the car was running)
I have no words for this one, I bought brand new poly bushings and Miata mecca replacement diff mounts for the rear diff, proof somewhere in this thread. I see that the poly bushing in the diff carrier is installed, but not on the mecca mounts below it. Where did that go? Oh, where did that other bolt go too, There was two bolts here when i had my eye on it, why was this put together like this at a performance shop. I am trying to work it out with the shop, they said to bring it by when the car is up and running.
Left and right side pics
I know its rusty, I am planning on painting everything very soon before i drop the engine in again soon.
Rebuilding everything while i have the time
shifter feel / Car felt way too different after the torsen, i knew something was up.
Colipto is offline
Old 04-21-2017, 03:01 PM
  #240
Wow...
