Log with cracked "weld"
Total Cats: 859
Here is the story. We had a broken cup on the TIG and were getting trashy welds. Not so much at the flange, but the butt joints. Also, likely because he was used to making tubular headers, my Son-in-Law chose to us Si-Bronze filler, so these are really TIG brazed joints.
This crack leaks for about 2 minutes at start-up and then the heat closes it. I plan to run a while like this to make sure there are no other weak joints before we pull it and repair.
When I do repair, I will run it for a while longer before getting the ceramic re-coated.
Questions:
1) Should we grind out the bad and go back with Si-Bronze, or use real weld this time?
2) Should I cut the flange?
Any other thoughts?
Total Cats: 859
Downpipe is segregated with main solid, and waste gate sliding joint. After they join, we have a 2.5" v-band, expand to 3", then is clamped at end of XMSN with a modified FM exhaust support clamp. Then a flex joint and out the back in a conventional manner.
Total Cats: 859
It is all mild steel with the oval to round flange holes. If I re-do it will be the same and not stainless parts or filler. Main question is could / should it be repaired, and if so is PROPERLY done braze OK, or should I go with PROPERLY done weld. I also agree that, if I repair, then I must get all the bad filler out and get to virgin base metal.
Since it is braze, there will be little mixed zone and it will be easy to see when all of the old filler is ground away.
Rebuild from scratch is a definite possibility.
Total Cats: 859
What we have decided is to leave the fillet flange braze joints and grind or cut the butt brazes out and weld. Then I will pretty up the welds before re-coating.
EDIT: See post 12. We did not try to salvage this brazed manifold.
Total Cats: 859
What we really did was rebuild from scratch. Used ER70S-2 rod on the CS weld fittings. I had a picture of the finished assembly, and thought I had posted, and got comments, but I cannot find where.
Bottom line, this new one cracked also:
Crack is between 1 & 2, so not a place that is highly affected by turbo weight, in my estimation.
This time I think we will grind out the bad part and re-fill. But input is welcome. Maybe some diamond reinforcements? Seems like it should not be necessary.
Note that the white finish is Aluminum flame spray, not ceramic, so it should remove easily.
Total Cats: 859
Standard Schedule 40 Low Carbon Steel weld fittings. I think they are 0.140" thick.
EDIT... Naw, Schedule 40 is, and what I remember measuring: 0.190" thk.
EDIT 3: I looked at my receipt. Std weight, which would be 0.140.
I'm going to bed. Looks like I need to.
Hard to see much from the pic, but did you vee out the part, and do a root pass to get good penetration, then a cap on top? Right or wrong, I usually weave a bit and that seems to make for a strong weld.
It looks to me like the Tee that's holding the turbo, and the 90 that cracked that it was welded to had poor fitment/alignment which I would guess means the weld connecting them is compromised, and the crack started because of the misalignment causing a weak weld. If this is the case, you could cut a small section out there and weld in a short section that fits right on both ends, and weld that in. That gets rid of the contaminated area near the weld, and fixes the misalignment.
Zaphod
47
10-26-2018 11:00 PM
