Crankcrankcrankcrank... '99 n/a MS3 - No Start
Old 03-28-2017, 10:43 PM
nick470's Avatar
Originally Posted by stefanst
Just one thing that may have slipped through the cracks- what is your spark mode in TS set to currently?
It's set to Miata 99-05
nick470 is offline
Old 03-28-2017, 10:57 PM
nick470's Avatar
Should I be in "log crank and cam" for every datalog? Just realized I switched it back to Miata 99-05 and kept it that way for the last log
nick470 is offline
Old 03-28-2017, 11:00 PM
nick470's Avatar
Flipped it back to Log Crank and Cam
File Type: csv
nick470 is offline
Old 03-28-2017, 11:13 PM
stefanst's Avatar
Total Cats: 74
Sorry- you're OK being in 99-05 Miata. I was just making sure you didn't try something weird there.
stefanst is offline
Old 03-29-2017, 07:56 AM
Total Cats: 4,102
sensor works, but the signal wire going back to the MS seems to be the issue -- pin 24 on the lower DB37.
Braineack is offline
Old 03-29-2017, 11:38 AM
stefanst's Avatar
Total Cats: 74
Your wiring from the sensor up to where you switched the signals is OK. Assuming you switched signals before it hits the DB37.
So now it's either a bad connection in the DB37 as Brain already said, or it could still be something wrong inside the MS3. Could be a cold solder joint on the connector (DB37) on the mainboard, or, more likely, the jumper on the board (I believe it's T_sel).
Edit: Don't forget to swap the wires back!
stefanst is offline
Old 03-29-2017, 10:17 PM
nick470's Avatar
Board looks good to me. Have continuity across the crank wire on the harness
nick470 is offline
Old 03-29-2017, 10:41 PM
stefanst's Avatar
Total Cats: 74
Then I'd give R56 another turn or two. Total of 10-11 turns. Make sure again that R52 is fully CCW.
Do you have a pullup for R45 (an additional reistor connected to the right side of it)?
Are you sure that's a brain-built unit? It doesn't quite look like his handiwork.
stefanst is offline
Old 03-30-2017, 12:31 AM
nick470's Avatar
Pullup is there. Two additional turns on r56 didnt do it. Fairly confident this is truly a Brain-built unit. He took it back for additional work after the PO connected us.
nick470 is offline
Old 03-30-2017, 10:27 AM
stefanst's Avatar
Total Cats: 74
Sorry- that's all I got. Over to the Brain. Pinky out.
stefanst is offline
Old 03-30-2017, 12:42 PM
Total Cats: 4,102
i still think there's a break between the sensor and the MS input.
